Sun, Feb 9, 11:24 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
Subject: Cloth Room question! Again lol
meltz ( ) posted Wed, 14 December 2011 at 6:48 PM · edited Sun, 09 February 2025 at 11:22 AM
Ok so when i start the draping it begins to rotate my figure. Now i beleave in the scene before i had the sheet parented to my figures waist. Could that be the problem? If so how do i un parrent it to her waist? If not that what am i doing wrong lol
willyb53 ( ) posted Wed, 14 December 2011 at 7:55 PM
quick question:
did you move the camera when you applied the pose at whatever frame you applied it at?
bill
meltz ( ) posted Wed, 14 December 2011 at 8:05 PM
the first scene i did went great, then i re posed my figure for the next picture and did change the camera, so yes i guess =-)
willyb53 ( ) posted Wed, 14 December 2011 at 8:10 PM
That can happen.  I have gone all the way around at times and had animation spin.  but for your final render you repositon camaera every time so.....
Bill
TheAnimaGemini ( ) posted Thu, 15 December 2011 at 1:13 AM
Unparent stuff is easy,
― Marcus Aurelius,
TheAnimaGemini ( ) posted Thu, 15 December 2011 at 1:14 AM
Go to set parent and parent the stuff to Universe or where ever you want to parent.
― Marcus Aurelius,
TheAnimaGemini ( ) posted Thu, 15 December 2011 at 1:16 AM
To avoid mess with the camera during simulation simply uncheck
"Animating" in your tab. In this case you can turn the camera, it will not affect the simulation.
― Marcus Aurelius,
TheAnimaGemini ( ) posted Thu, 15 December 2011 at 1:18 AM
When you want to repeat the simulation, because you change something
This could help :)
At the bottom "Clear simulation"
― Marcus Aurelius,
RobynsVeil ( ) posted Thu, 15 December 2011 at 4:35 AM
Quote - To avoid mess with the camera during simulation simply uncheck
That is SO good to know! Thanks for that tip - going to uncheck some stuff, now... LOL
HUGS!~
Metaphor of Chooks
meltz ( ) posted Fri, 16 December 2011 at 10:25 AM
Still no luck. I even deleated the sheet and created a new one. but when i place it over the V4 and set my sim up, once the sim begins V4 startes to rotate while the sheet falls towards her. What am i doing wrong here =-(
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 10:59 AM · edited Fri, 16 December 2011 at 10:59 AM
Is the sheet parented? You need to make a constrained group.
Take a look at this dress, it is parented to Antonia's chest and the small red line is the constrained group I made to hold this dress on her.
What is important to,avoid to turn V4 AFTER your final simulation pose.
Turn the camera with Animation OFF when you check for details.
― Marcus Aurelius,
meltz ( ) posted Fri, 16 December 2011 at 11:34 AM
Im doing all of this its just not working. I even deleatedthe sheet and made a new one. Im going to go deleate it again and try one last time here!
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 11:46 AM · edited Fri, 16 December 2011 at 11:46 AM
Try step by step
Load V4, Put your slider to a frame ( example15 ) Load the sheet, Parent the sheet to her waist ( or whatever)
Pose her, go to the cloth room
Now put the upper line ( like you see on my example) as contrained group,
Set up your simulation setting values
Don't forget, Colide against V4 and REMOVE center of mass , now calculate simulation.
There is no reason why it should not work...:(
― Marcus Aurelius,
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 11:50 AM
Could you please post some images with your scene and settings? Maybe this way we can find out what you did wrong :)
― Marcus Aurelius,
meltz ( ) posted Fri, 16 December 2011 at 11:51 AM
Remove center of mass? Where doo i do that at?
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 11:59 AM
When you are in the cloth room. You have to choose against what the sheet has to colide.
There you can add V4 and remove everything what is not needed.
― Marcus Aurelius,
meltz ( ) posted Fri, 16 December 2011 at 12:03 PM
Yup i do that!
meltz ( ) posted Fri, 16 December 2011 at 12:10 PM
How do i clear my frames, maybe thats why shes rotating. Cause when i move the frames it shows her rotating =-( I dont want any anamation, just her laying there and having the cloth fall onto her =-(
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 12:20 PM
I would suggest you to make a new scene. Save the pose you did for her, make a new scene, load V4, the sheet and put your slider to the frame 20. Now put her in pose and go to the cloth room. :)
When you want to delete frames, click on the key from your animation slider
You got this pop up.
― Marcus Aurelius,
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 12:22 PM
Select the animation for V4 and delete the frames( green boxes)
― Marcus Aurelius,
meltz ( ) posted Fri, 16 December 2011 at 12:26 PM
Worked =-) i deleated my key frames and bingo =-)  Thanks so much for helping out on this subjet =-)
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 12:38 PM
Yuhuu :) Fantastic, glad I could help you :)
― Marcus Aurelius,
