Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
"Animating" in your tab. In this case you can turn the camera, it will not affect the simulation.
― Marcus Aurelius,
Quote - To avoid mess with the camera during simulation simply uncheck
That is SO good to know! Thanks for that tip - going to uncheck some stuff, now... LOL
HUGS!~
Take a look at this dress, it is parented to Antonia's chest and the small red line is the constrained group I made to hold this dress on her.
What is important to,avoid to turn V4 AFTER your final simulation pose.
Turn the camera with Animation OFF when you check for details.
― Marcus Aurelius,
Try step by step
Load V4, Put your slider to a frame ( example15 ) Load the sheet, Parent the sheet to her waist ( or whatever)
Pose her, go to the cloth room
Now put the upper line ( like you see on my example) as contrained group,
Set up your simulation setting values
Don't forget, Colide against V4 and REMOVE center of mass , now calculate simulation.
There is no reason why it should not work...:(
― Marcus Aurelius,
When you want to delete frames, click on the key from your animation slider
You got this pop up.
― Marcus Aurelius,
Ok so when i start the draping it begins to rotate my figure. Now i beleave in the scene before i had the sheet parented to my figures waist. Could that be the problem? If so how do i un parrent it to her waist? If not that what am i doing wrong lol
