Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
While it possible to export certain scene elements from MAX (in OBJ or 3DS and sometime Collada), the VRay shaders do not directly translate. VRay is a specialized rendering system with it's own material definitions.
Also, if the scene contains objects in VRmesh format, those only export as a point cloud and are not readily usable in Poser
Supposedly the demo version of Max will allow you to export in .obj format that Poser can use. If the model has bitmap textures eg. .jpg images, you can use those. The VRay or MentalRay shaders used in Max aren't going to be useful.
Oh, it's easy to convert 3DS MAX object to POSER.
Just export your 3DS MAX object with OBJ file format for POSER. You can see 'POSER'
preset obj. file when exporting OBJ.file from 3DS-MAX obj export window.
Of course export material library and texture at the same folder at where OBJ. mesh file saved.
Then at POSER, select File -> import -> wave front OBJ. Select your 3DS-MAX generated obj. It's all done. I love editing external meshs at 3DS-MAX and import
them to POSER oftenly because of 3DS-MAX's powerful mesh-element selection :)
Almost Autodesk product including 3DS-MAX has 30 day- trial version for free. You can also try academic version. Trial version can be downloaded at http://usa.autodesk.com/3ds-max/trial/
Quote - Theoretically:?
File - Export - .obj
Actually, not just theoretically.
My Freebies
Buy stuff on RedBubble
Hello,
I found, that I can export from poser pro 2012 for 3D Studio Max, is it posible to open stuff and scene whitch where creatied for 3D Studio Max.
Sorry I'm new in poser.
Thanks for your help.
