Thu, Jan 23, 11:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: How can I open 3D Studio Max (V-Ray) files with poser pro 2012
povilasn ( ) posted Wed, 04 January 2012 at 10:12 AM · edited Sat, 10 August 2024 at 6:39 AM
Hello,
I found, that I can export from poser pro 2012 for 3D Studio Max, is it posible to open stuff and scene whitch where creatied for 3D Studio Max.
Sorry I'm new in poser.
Thanks for your help.
Medzinatar ( ) posted Wed, 04 January 2012 at 10:41 AM · edited Wed, 04 January 2012 at 10:47 AM
While it possible to export certain scene elements from MAX (in OBJ or 3DS and sometime Collada), the VRay shaders do not directly translate.  VRay is a specialized rendering system with it's own material definitions.
Also, if the scene contains objects in VRmesh format, those only export as a point cloud and are not readily usable in Poser
MacMyers ( ) posted Wed, 04 January 2012 at 11:21 AM
To my knowledge the only thing that opens .MAX files is MAX.
            “So, roll me further B_t__h!”
povilasn ( ) posted Wed, 04 January 2012 at 11:28 AM
Is it possible to convert them for poser?
LaurieA ( ) posted Wed, 04 January 2012 at 12:28 PM
Quote - Is it possible to convert them for poser?
No.
FrankT ( ) posted Wed, 04 January 2012 at 1:25 PM
not unless you have a copy of Max to do the conversion.
My Freebies
Buy stuff on RedBubble
povilasn ( ) posted Wed, 04 January 2012 at 3:26 PM
Than's. i do not, but think will find someone
lmckenzie ( ) posted Thu, 05 January 2012 at 12:21 AM
Supposedly the demo version of Max will allow you to export in .obj format that Poser can use. If the model has bitmap textures eg. .jpg images, you can use those. The VRay or MentalRay shaders used in Max aren't going to be useful.
MacMyers ( ) posted Thu, 05 January 2012 at 5:57 AM
I have a friend do it for me. Though I'm not sure  if his copy is legal or not.
povilasn ( ) posted Thu, 05 January 2012 at 6:22 AM
You are lucky, I'll look for one who has :)
skywaver ( ) posted Thu, 05 January 2012 at 7:12 AM
Doesn't 3DS MAX's VRAY has material converter from general material to VRAY material?
In case of CINEMA4D's VRAY, just convert poser material to vray material with one click
then I can render poser scene or object at C4D with vray...
povilasn ( ) posted Thu, 05 January 2012 at 7:31 AM
Yes, but I need convert not a poser matirial fo 3ds max, but 3ds max for poser
skywaver ( ) posted Thu, 05 January 2012 at 10:00 AM · edited Thu, 05 January 2012 at 10:02 AM
Oh, it's easy to convert 3DS MAX object to POSER.
Just export your 3DS MAX object with OBJ file format for POSER. You can see 'POSER'
preset obj. file when exporting OBJ.file from 3DS-MAX obj export window.
Of course export material library and texture at the same folder at where OBJ. mesh file saved.
Then at POSER, select File -> import -> wave front OBJ. Select your 3DS-MAX generated obj. It's all done. I love editing external meshs at 3DS-MAX and import
them to POSER oftenly because of 3DS-MAX's powerful mesh-element selection :)
MacMyers ( ) posted Thu, 05 January 2012 at 10:23 AM
You have to have a copy of a pretty expensive program to do that.
povilasn ( ) posted Thu, 05 January 2012 at 10:25 AM
great, if I'll have some question, I'll write later
great thanks
skywaver ( ) posted Thu, 05 January 2012 at 11:15 AM
Almost Autodesk product including 3DS-MAX has 30 day- trial version for free. You can also try academic version. Trial version can be downloaded at http://usa.autodesk.com/3ds-max/trial/
povilasn ( ) posted Thu, 05 January 2012 at 12:37 PM
Thanks one more time
povilasn ( ) posted Fri, 06 January 2012 at 12:00 PM
I found that as teacher I can legal download 3ds max not just for 30 day :) Jus on quick try, may be some one can tell me how export the object or scene fruom 3ds max in OBJ?
MacMyers ( ) posted Fri, 06 January 2012 at 12:40 PM
Theoretically:?
File - Export - .obj
FrankT ( ) posted Fri, 06 January 2012 at 1:14 PM
Quote - Theoretically:?
Actually, not just theoretically.
My Freebies
povilasn ( ) posted Fri, 06 January 2012 at 1:27 PM
Yes, I found that Fie which was in icon ;)
