Wed, Jan 8, 5:48 PM CST
Subject: Wings3D help requested: Making a proxy for dynamic hair simulation
operaguy ( ) posted Thu, 05 January 2012 at 2:23 PM · edited Sun, 22 December 2024 at 10:09 PM
I want to make a low-poly 'proxy' model, just the .obj, to fit over V4's head and neck. Collision would be checked "on" for this proxy, checked off for the actual head and neck.
Then, when dynamic hair sim calculates with collision on, the sim engine only has to calculate, say, 200 faces, not 14,000.
This is good enough for a medium or long shot.
Obviously the proxy is turned invisible before render.
I exported as .obj the head and neck of my "dialed up" V4.
I ran Wings3D and imported. You can see the two 'groups" are not welded, even though I said to do that in my Poser export.
I think my next move is to combine/weld/merge the neck and head, then to "decimate" (is that the right term?) the model from 14,750 faces down to a few hundred.
I could not find the command to "weld" nor "decimate".
Would any Wings people be willing and able to help me?
I'd publish the model as a freebie, but it is a "purpose built" face and shaped head, so not strictly applicable to general v4 hair simulation proxy usage. So I'll post a thread demonstrating the concept once I get it going.
::::: Opera :::::
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 2:33 PM
i'm using wings version 99.5,
if i were to combine these two groups i would select the hole material
top of the neck and bottom of her head
and use the "bridge" command for 'faces'.
  • for bridge to work, each face has to have the same number of verts
operaguy ( ) posted Thu, 05 January 2012 at 2:40 PM
thank you for responding.
i am in 1.4.1
I could not find "bridge" but I did find "weld." Chosing "all" and applying weld resulted in the error message "WELD could not be resolved."
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 2:45 PM
the Bridge command should be on the Faces right-click menu.
i'm lost in wings after they hid the hole material, decided it was better to stick with one version and learn it as best i could.
geep ( ) posted Thu, 05 January 2012 at 2:47 PM
Quote - - for bridge to work, each face has to have the same number of verts
FYI - Same number of vertices NOT required for Wings 1.4 to create a "Bridge."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 2:48 PM
here's a screenshot 😄
geep ( ) posted Thu, 05 January 2012 at 2:52 PM · edited Thu, 05 January 2012 at 2:54 PM
Attached Link: Wings 101 - A tutorial by Dr Geep
@ Misty 😄
Making a "Hole" is as easy as 1, 2, 3 in Wings 1.4.
Please see my tutorial "Wings 101" and the page shown here (excerpt from the tut).
cheers
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 2:53 PM
> Quote - > Quote - - for bridge to work, each face has to have the same number of verts > > FYI - Same number of vertices **NOT** required for Wings 1.4 to create a "Bridge." > > cheers, > dr geep > ;=]
that would be kewl.  😄
the last version i d/lded was 1.2, it doesn't have that feature.
geep ( ) posted Thu, 05 January 2012 at 2:55 PM
Suggest you get 1.4 :biggrin:
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 2:57 PM
does the LoopCut work in 1.4?
thanks.
Happy New Year!
did Naysayguy over do it with the bubbly ?
geep ( ) posted Thu, 05 January 2012 at 3:01 PM · edited Thu, 05 January 2012 at 3:04 PM
In a word ... Yup. :biggrin:
cheers,
dr geep
P.S. re da NaySayGuy - Yes, NSG always over does it with the bubbly. 👎
It costs me an arm and a keg, er ... leg. :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
LaurieA ( ) posted Thu, 05 January 2012 at 3:02 PM · edited Thu, 05 January 2012 at 3:03 PM
Lara, there is no hole material in 1.4.1...lol. Good thing too - that would just confuse the hell outta me :P
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 3:05 PM · edited Thu, 05 January 2012 at 3:07 PM
Whaaaaat?  but, but.  i depend on it so much, i'd have to rethink everything.
what kinda new stuff did they add to uv mapping?
SamTherapy ( ) posted Thu, 05 January 2012 at 3:10 PM · edited Thu, 05 January 2012 at 3:11 PM
Quote - Whaaaaat?  but, but.  i depend on it so much, i'd have to rethink everything.
There's no Hole Material but there is "Hole", which is exactly what it says, a hole. :)
I don't use Wings UVMapping, I think it's bloody awful.
@ OG, you can easily weld verts in UVMapper Pro, also.
geep ( ) posted Thu, 05 January 2012 at 3:11 PM · edited Thu, 05 January 2012 at 3:12 PM
Everything? .......... Nah ... just a few minor tweaks (pun intended) :lol:
Works just about the same ... check it out.  I think you'll like it.
Check out my tuts in the Wings Forum for some of the nitty-gritty. :biggrin:
cheers
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 3:12 PM
really?  i luv wings uvmapping.
d/l version 1.4.1 as we type.
geep ( ) posted Thu, 05 January 2012 at 3:13 PM
Good girl ... GO FOR IT ... You won't be disappointed.
I guarantee it. 👍
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 3:15 PM
did they make a new .pdf version of the manual?
the one i have is pretty ancient.
geep ( ) posted Thu, 05 January 2012 at 3:16 PM
Quote - did they make a new .pdf version of the manual?
Hmmm me, too.
Don't know. :sad:
cheers,
dr geep ... :o]
edited 10/5/2019
MistyLaraCarrara ( ) posted Thu, 05 January 2012 at 3:19 PM
how would you connect 2 verts over the area that used to be a hole material?
PrecisionXXX ( ) posted Thu, 05 January 2012 at 3:45 PM · edited Thu, 05 January 2012 at 3:49 PM
Not having wings fired up, but my guess would be bridge the faces, then go in and change to hole.
1.4 is different, but not that different.  Being able to change selection modes from the menu is handy, as is the, not sure what they call it, but picking mode just by putting the cursor over a face, vertex or edge and have it go into the mode you want.
I like Wings.
The "I" in Doric is Silent.
PrecisionXXX ( ) posted Thu, 05 January 2012 at 3:52 PM
DId you do a tut on the UV mapping, Geep?  It's always looked pretty powerful to me, but I could never follow a video tut and get anything out of it.
operaguy ( ) posted Thu, 05 January 2012 at 4:32 PM
but.....................Decimate?
that is the main thing I need to learn how to do. How do I turn a 14,000 face model into 200 faces for my purpose?
::::: Opera :::::
LaurieA ( ) posted Thu, 05 January 2012 at 4:41 PM
Wings doesn't do decimate. Unless I'm really stupid and blind :P.
geep ( ) posted Thu, 05 January 2012 at 4:59 PM
Quote - DId you do a tut on the UV mapping, Geep?  It's always looked pretty powerful to me, but I could never follow a video tut and get anything out of it.
UV Mapping using ... ?
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 05 January 2012 at 5:09 PM
Attached Link: "Wings 101" - a tutorial by Dr Geep
> Quote - how would you connect 2 verts over the area that used to be a hole material?
Please refer to the graphic above (excerpt from Wings 101) ... and then ...
  1. Fill in the "Hole"
  2. Select the vertices to be connected
  3. "Connect ("C") the vertices.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
operaguy ( ) posted Thu, 05 January 2012 at 5:17 PM
Thanks Laurie, i looked into every menu, and there is no searchable manual and i couldn't find anything on decimate, and wondered too if I were going blind!.
No problem, Wings is still very fine!
Now to find the solution. Here is my starting point...
http://www.shapeways.com/tutorials/polygon_reduction_with_meshlab
If anyone else actually knows a way to decimate in Wings, please post!
::::: Opera :::::
PrecisionXXX ( ) posted Thu, 05 January 2012 at 5:56 PM
Quote - > Quote - DId you do a tut on the UV mapping, Geep?  It's always looked pretty powerful to me, but I could never follow a video tut and get anything out of it.
Wings
wolf359 ( ) posted Thu, 05 January 2012 at 5:57 PM
Hi John If you have any version of DAZ studio From 2.3 or higher ,installed you can skip wings3D entirely and just export your Low res  V4 head from Daz studio using the "LOD" settings of 1 or 2 K Just open the scene tab in DS and uncheck visibility for everything except the head & neck I just tried it and here is my uber low res V4 head in poser6 ready to run a hair sim. Might be worth a try for you
Cheers
My website
operaguy ( ) posted Thu, 05 January 2012 at 6:05 PM
Hi Wolf!
Thanks for responding.
Can i import a 14,000 face .obj inte DStudio, then export with a 1k setting? or does the process you described actually require the Daz LOD model to start with? I ask because crazy as it sounds, I want the proxy to match my dialed-up v4 character as much as possible.
::::: Opera :::::
operaguy ( ) posted Thu, 05 January 2012 at 6:31 PM
WOW!
from 15,000 faces to 307 faces in an instant.
This is a beautiful resource.
http://meshlab.sourceforge.net/
::::: Opera :::::
wolf359 ( ) posted Thu, 05 January 2012 at 6:32 PM
"Can i import a 14,000 face .obj inte DStudio, then export with a 1k setting? or does the process you described actually require the Daz LOD model to start with? I ask because crazy as it sounds, I want the proxy to match my dialed-up v4 character as much as possible."
Well you will  need to export an actual V4 Figure from DS to use the LOD function
not an imported.obj file.
I am not sure about retaining the face morphs as I literally have no morph++ packages for V4
As I only use Default characters for my types of animation /simulation projects.
perhaps someone else could chime in.
Cheers
My website
SamTherapy ( ) posted Thu, 05 January 2012 at 7:09 PM
OG, DAZ were offering different res versions of V4 for free a while back.  Don't know if they still do but if you don't already have 'em it may be worth looking on their site.
Looks like you found a solution but they could be useful to have around anyhow.
LaurieA ( ) posted Thu, 05 January 2012 at 7:49 PM
WOW!
::::: Opera :::::
LOL..that or AccuTrans was gonna be my next suggestion :P
Cybermonk ( ) posted Thu, 05 January 2012 at 9:47 PM
Blender has a decimate modifier and its easy to use.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
