Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 9:35 am)
It may depend on the default UV mapping currently applied to the objects. Have you created new UV mapping for the objects?
However I'm not entirely sure exactly how you have the scene set up. When you say that one side is invisible do you mean invisible in preview? If so that is to be expected if the polygons are facing away from the camera. They will become visible when rendered.
Are the two planes very close together? If so one may be causing interference with the other.
If you think I can help I'll be happy to look at what you have. Just save the scene and email me the PZ3 and the file texture in a zip. That way I'll be able to see exactly what you have and be able to give you a more accurate answer.
UV Mapping, I believe. Drop your object into a mapping prog and map it planar.
Save. That should do the trick.
Edit:
You could also try Cylindrical. That should give you the same alignment for front and back.
Thanks for all of the suggestions peeps. I really appreciate it. gives me some things to work on and hopefully I can learn something. I probably won't because I didn't realize it render correctly from both sides even if it doesn't show correctly in the preview. Thus I can Get by with that small bit of knowledge without actually having to better myself in any way.
It's a mapping issue for sure... and Carrara sets display ok in Carrara... but not in anything else apparently.
Phil. I would never presume to waste your valuable time with my nonsense but it certainly speaks well of you (once again) that you'd even offer!
I was using 2 planes in the "example". I haven't come up with a good way to make muzzel flashes, fireballs etc. other than mapping an image to a plane and then duplicating the object, rotate to 45°, 90° etc...etc... so it's fisible from all sides.
My Gallery image "Splash one" shows how poorly this works however.
Thanks again all.
“So, roll me further B_t__h!”
Before you jump on me for being too lazy and dumb to figure this out... please keep in mind that I actually AM too lazy and dumb to figure this out.
I've been creating dumb flat objects in Carrara 8 Pro and texturing them with an image. It works Great on ONE side..... the other side is invisible.
So I created a thin cube with 2 sides and two textures. Both sides visible... but misaligned.
So I created 2 flat planes, each with a separate texture....played around rotating them so both sides are visible. Misaligned no matter how flipped etc. Also tried using flipped textures.
Poser Pro 2012.
