Fri, Jan 10, 8:22 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 10 5:08 pm)
Subject: free Daz Studio pro not working
drifterlee ( ) posted Sat, 11 February 2012 at 10:06 AM · edited Thu, 09 January 2025 at 8:40 AM
I'm a Poser user, and used to Poser's interface. I got the free Daz Studio Pro but I can't get anything to work. I watched the video, and they show the sides of the interface opeing up into another interface, I can not get it to do this, not can I render or do anything. I click on tabs and nothing happens. What am I doing wrong? All I can do is bend genesis and move him around. Do I have a corrupt file? Daz told me just to "Clear my cache and redownload - an answer they seem oi give for everything I've asked them. Can you hekp? Thanks so much. I really wold like to try Daz Studio. Cheers, Sherrie
vitachick ( ) posted Sat, 11 February 2012 at 10:11 AM
And you wonder why it's free??? When I use Daz I stick with version 3..NP...Daz4 interface was changed and really annoying. I did d/l Daz4 but have not used it yet...
Win10  Poser 2014/Poser 11 Daz3D
DustRider ( ) posted Sat, 11 February 2012 at 11:21 AM · edited Sat, 11 February 2012 at 11:23 AM
Sherrie - It does sound as if you may have a corupted download if the interface looks a lot different. Could you post a screen capture of what DS4 looks like whan you open it?
The interface is a lot different than Poser, but once you understand how to do the basics, it gets much easier. The image above is what the default interface should look like when you open DS4 (only minus a lot of the stuff mine shows - I've already accumulated way to much stuff) .... Oh I should ask are you on a PC or Mac? This view is on a PC running Vista 64bit.
The new  Version of DS4 comes with a couple of ready to render scenes. On the right of the image above (click on it to see a larger view) you can see the preset scenes on the right. You sould have the three cenes on the bottom row, if you don't then you definitely need to download DS4 Pro again.
Note: Make sure all of the categories/tabs on both the left hand and right hand side of your screen are highlighted like the image above. DS4 is context sensitive, what you are able to see/do is very dependent on what you have selected. The 4 main tabs/menues (Actors, Wardrobe & Props ...Pose & Animate ...etc.) will change what is available in the side tab menues below).
I'm sure all this was about as clear a mud, bat at least it's a starting point to get us kind of on the same page.
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
drifterlee ( ) posted Sat, 11 February 2012 at 11:52 AM
Thanks Duster. No, my interface has only Genesis in it. NO side bars. I will redownload it. Thank you.
DustRider ( ) posted Sat, 11 February 2012 at 12:07 PM
Good luck .... feel free to ask questions. I should thank you as well ..... I knew they had included the ready to render scenes but hdn't looked at them .... very interesting, a limited version of a make art button (of course everyones art looks the same)
drifterlee ( ) posted Sun, 12 February 2012 at 11:17 AM
I unistalled all versions of Daz Studio, then reinstalled Daz Studio 4 Pro. It still does not work. I have asked Daz and asking them is a waste of time. They just say "redownload". Which I have done. What could be wrong? Is there a secret button I'm no pushing?
Xerxes0002 ( ) posted Sun, 12 February 2012 at 11:34 AM
Drifterlee can you post a scren shot? (Shift Printscreen, then past it into your photoapp or IrfanView)?  Then we can see it.
Also when you uninstalled did you see if there where any left over files in the directory (or if the directory was left?)
DustRider ( ) posted Sun, 12 February 2012 at 11:57 AM
Did you delete the previous download before getting the new download? I've had problems with windows not overwriting the old file with a new download. Really frustrating with large downloads! It's even more frustrating because sometimes the new download overwrites the old file with no problem, other times you can't without completely deleting any trace of the old file!
Another problem might be a configuration file that isn't getting deleted, I'm not sure where that might be hiding (I would think in C:Program FilesDAZ 3DDAZStudio4).....I just happened to think, if it is a preferences file, you might be able to enable the tabs by going to Windows>Tabs> then selecting the tabs you need (Smart Content, Shaping, Surfaces for the tabs on the left).
If nothing above seems to work, try posting a request for help in the Commons in the DAZ forums. It's where most people go, and you should get help pretty quikly. I would think that someone else has had a similar problem.
drifterlee ( ) posted Sun, 12 February 2012 at 12:54 PM
Here is my Daz screen. NOne of the tabs, or arrow do anything. I did delete all the stuff from the old installations. Put the entire Daz3d folder in the trash before reinstalling the new version.
SickenlySweete ( ) posted Sun, 12 February 2012 at 1:15 PM · edited Sun, 12 February 2012 at 1:27 PM
go to windows, select style  and workspace for  layout changes...
did you install the darkside style that came with the program?
www.bloodyrosesdesigns.com
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
DustRider ( ) posted Sun, 12 February 2012 at 1:21 PM · edited Sun, 12 February 2012 at 1:30 PM
Great - this makes it easy! Just click on the little tiny white arrow heads the red arrows are pointing at in the image above, and you should be good to go!
Opps! Crosspost, I'm too slow on the keyboard!
drifterlee ( ) posted Sun, 12 February 2012 at 3:54 PM
I clicked on those arrows. NOthing happens.
Xerxes0002 ( ) posted Sun, 12 February 2012 at 6:50 PM · edited Sun, 12 February 2012 at 6:56 PM
EDIT I noticed sometimes the service DAZ Content manager doesn't start, when it doesn't (like after I changed my item below and restarted DS4), then no content seemed to come up, nothing to click on.  click on the start menu and type in services and see if daz content manager is 'started' if not right click and say start. then rerun ds4 and see if things work any better.  END EDIT
Also try this in case its corrupted.  Go to the Window menu, then workspace, then layout.  What comes up for me by default is Hollywood Blvd, check to see if thats what it is.  Try selecting something else and see if that has any effect.
RHaseltine ( ) posted Mon, 13 February 2012 at 6:56 AM
What video card do you have? DS depends on OpenGL, where Poser has a software mode as a fall back.
drifterlee ( ) posted Mon, 13 February 2012 at 12:39 PM
I have a Geforce- forgot what number - but it runs Vue 10 and Poser 2012/
vitachick ( ) posted Mon, 13 February 2012 at 1:32 PM · edited Mon, 13 February 2012 at 1:33 PM
I had similar problem...Make sure you selete all Daz4 items...I even went to registry
(regedit) searched for Daz4 and deleted...Searched HD and did the same. I also reinstalled not where they said but to my G:Program Files  Daz Studio..I want Daz4 where Daz3 is......Works ok now!
I really don't like them telling me where I have to install...
drifterlee ( ) posted Mon, 13 February 2012 at 4:19 PM
Thanks. I'll try that!
keppel ( ) posted Tue, 14 February 2012 at 12:44 AM
I had a simliar problem with an install of Poser 8 where the content libraries would not display and it turned out that I had to update my version of Flash.  I don't know if DAZ Studio works the same way but it might be worth checking that you have the latest version of Flash installed.
My Renderosity Store
Virtual Furnishing
My Portfolio
leehilliard ( ) posted Thu, 16 February 2012 at 3:43 AM
try going into your content preferences 'scan for daz/poser files on your hard drive'it'll ask how you want it organized and if you want the files metadata (click yes that way you can see what type it is in the interface).it's also in the interface so you can scan for new data without leaving the main screen.
vitachick ( ) posted Thu, 16 February 2012 at 5:42 AM
Daz3 has that option but don't see it in Daz4
leehilliard ( ) posted Sun, 19 February 2012 at 5:04 AM
open up daz .click content ,then at the to right corner right next the search function left click.the options are there.
vitachick ( ) posted Sun, 19 February 2012 at 5:26 AM
Ah...sry...Yes I see it...Daz4 has alot of getting use to.
drifterlee ( ) posted Sun, 19 February 2012 at 1:36 PM
Well, I still can't get it to work, so I don't know what to do. Reinstall again I supppose.
vitachick ( ) posted Thu, 23 February 2012 at 6:38 PM
http://forum.daz3d.com/viewtopic.php?p=3298879&flatnum=1
Here is another thread...Same problems
drifterlee ( ) posted Fri, 24 February 2012 at 12:31 PM
Thanks!
