DAZ|Studio F.A.Q (Last Updated: 2025 Jan 19 2:48 pm)
Quote - glass dont work.
That's the one, problem is the new 'If Else' brick in DS4 doesn't/can't emulate the old DS3 'If Then Else' brick, there have been internal name changes and now some of the connections (output as well as input) aren't being made, in other words a total cluster**** by the devs.
If you mean render in the active viewport then no it can't. That was the default setting for the older versions but people kept asking, "How do I make the render a different size?". The answer was to render to New Window so it only makes sense that they dropped the old way and made rendering to New Window the default option.
Actually you can render in the active window by using the "spot render veiwport tool". The icon is a camera with a mouse pointer. I use that when I want to check only a small area of my scene but you can just click and drag it over the whole scene too. The only thing is that it doesn't save the rendered scene if using the spot render veiwport tool.
Any way to render a scene in the Daz4 window w/o getting a window asking me where to save it? Daz3 you press render and it processed right in front of you..
Thanks for much needed help!
Win10 Poser 2014/Poser 11 Daz3D
