Sun, Jan 5, 7:58 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
Subject: Daz4 rendering
vitachick ( ) posted Wed, 07 March 2012 at 4:59 AM · edited Sun, 05 January 2025 at 7:40 AM
Any way to render a scene in the Daz4 window w/o getting a window asking me where to save it?  Daz3 you press render and it processed right in front of you..
Thanks for much needed help!
Win10  Poser 2014/Poser 11 Daz3D
Bejaymac ( ) posted Wed, 07 March 2012 at 5:42 AM
Nice to know I'm not the only one that doesn't like it, but sadly I haven't found any way to turn it off either.
vitachick ( ) posted Wed, 07 March 2012 at 9:01 AM
Shoot the programer is what I say...
Bejaymac ( ) posted Wed, 07 March 2012 at 2:37 PM
Don't tempt me as I already don't like one of them, he changed a couple of bricks in the DS4 ShaderMixer and now some older ShaderMixer presets no longer work, including one that comes with DS4.
dyret ( ) posted Thu, 08 March 2012 at 2:56 PM
glass dont work.
Bejaymac ( ) posted Thu, 08 March 2012 at 5:10 PM
Quote - glass dont work.
That's the one, problem is the new 'If Else' brick in DS4 doesn't/can't emulate the old DS3 'If Then Else' brick, there have been internal name changes and now some of the connections (output as well as input) aren't being made, in other words a total cluster**** by the devs.
jestmart ( ) posted Thu, 08 March 2012 at 9:29 PM
It sound like you have the render to file box checked.  Select render to new window instead.
vitachick ( ) posted Fri, 09 March 2012 at 3:22 AM
Quote - It sound like you have the render to file box checked.  Select render to new window instead.
I tried render to new window. It still is asking me where do I want it rendered and saved to...
LBAMagic ( ) posted Fri, 09 March 2012 at 3:32 AM · edited Fri, 09 March 2012 at 3:33 AM
Try these settings for "Render To"
vitachick ( ) posted Fri, 09 March 2012 at 5:13 AM
Ok I have done that.  Silly question is after render is done close the window and everything is rendered to exsisting window?
LBAMagic ( ) posted Fri, 09 March 2012 at 5:23 PM
Hi vitachick. Sorry I don't quite understand the question. However when you do a render a window should pop up showing the image as it's rendering and then you save it to your render library or select a folder to save it to.
vitachick ( ) posted Fri, 09 March 2012 at 7:31 PM
Ok Thanks...Was advised that Daz4 cannot render in exisitng window like Daz3 does.
jestmart ( ) posted Sat, 10 March 2012 at 12:55 PM
If you mean render in the active viewport then no it can't.  That was the default setting  for the older versions but people kept asking, "How do I make the render a different size?".  The answer was to render to New Window so it only makes sense that they dropped the old way and made rendering to New Window the default option.
LBAMagic ( ) posted Sat, 10 March 2012 at 5:39 PM · edited Sat, 10 March 2012 at 5:40 PM
Actually you can render in the active window by using the "spot render veiwport tool". The icon is a camera with a mouse pointer. I use that when I want to check only a small area of my scene but you can just click and drag it over the whole scene too. The only thing is that it doesn't save the rendered scene if using the spot render veiwport tool.
