Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 4:22 pm)
I would try selecting the tunic, and under the Figure Menu select Copy Joints From, and select Anastasia...
"Oh - the manual says that? I have never read the manual - this must be why."No joy.
Looking at the tunic and the arm, the shoulder on the tunic is longer than GNDA2's arm. At the middle of the tunic arm there are 2 indentions. This is where the the tunic bends on V4 (and the WW conversion for V3). See attached file.
On a separate note, I have no idea what where that little green spot behind the Tactical Officer came from.
He tried and it didn't work.
I'm surprised that the WW plugin didn't take care of it; the pants and boots look great. I take it the Anastasia plugin is being used?
Hopefully Phil comes back, and has something...dare I say...up his sleeve. If you want to try the joint editor in the meantime, I'd move the tunic's forearm/shoulder joint center up the arm...
"Oh - the manual says that? I have never read the manual - this must be why."I went with WandW's suggestion. It made no difference. The bend is still in the wrong place.
The attached image has from left to right
Sydney G2 - Weightmapped (courtesy of PhilC's script)
V3 Non Weight Mapped - Haven't gotten to it yet.
V4 Weight Mapped. (Third Degree Agna, Gunnr, Hrist, Mist, Nott, Gioia, etc characters are big girls.)
Quote - He tried and it didn't work.
I have been using WW since almost the begining & this is the first time it has had major issues.
You may be right about the joint editor. The joint editor has been very frustrating experience for me thus far.
On the other hand, if it was easy, I'd have figured it out by now.
Just a thought; have you tried converting it to plain old Alyson 2?
To try the joint center adjustment, put using the side camera with her arm bent, open the Joint editor window (cntrl-shift-J) and grab the center of the cross-hairs and move them to where the joint should be. It should coincide with those on Anastasia, so you can select her to compare (just don't ajust her!). Also check the joint center locations with the front and top cameras. Then you can transfer it to the other arm using Symmetry.
If it doesn't work, there is probably a problem with the grouping.
hborre, He's using Phil's weightmapping script to weight map the characters. Not a great deal of improvement as is, but it opens the ability to easily adjust the maps. Rerigging from scratch is only needed if one intends to legally distribute the WM rig for a non-open-source figure...
"Oh - the manual says that? I have never read the manual - this must be why."I've been out all day and am only back to this now.
Could you please tell me:-
The figure that the original costume was made for.
The exact names of the "from" and "to" figures selected in the Wardrobe Wizard GUI.
If the "to" figure contains weight maps did you select the option to copy them to the clothing?
If and only if you have the authority to .... please send me a copy of the original costume so that I can run it through here.
Thanks.
Quote - I've been out all day and am only back to this now.
Thanks.
The outfit is courageous for V4 at DAZ.
https://www.daz3d.com/i/shop/itemdetails/?item=6769
The WW settings were V4 to Anastasia (The WW files you made available to all of us.)
Yes, the copy weight maps was selected. That was what I messed up the first time I attemped to convert it. I deleted all files & forced a reanalysys.
I do not have the authority to send you the original file.
This is the result of converting a test shirt from V4 to Anastasia_WW.
I'm not sure quite what you mean by, "The WW files you made available to all of us." Was that a beta copy? I'm not inferring that you have something that you shouldn't just that my memory in these things gets vague at times.
If you have purchased the Wardrobe Wizard support files for Anastasia then I'll be very happy to email you a current link to ensure that your files are correct. I can also send you this test shirt so that if required we can continue to sort out the issue using the same set of files.
Quote - This is the result of converting a test shirt from V4 to Anastasia_WW.
Poor word choice after being up for 39 hours.
The one I bought off your website was what I was talking about. The readme is dated 28 Dec 2011. The file dates are between 30 Nov 11 to 26 Dec 11.
My email is hbryan1@elp.rr.com
I suspect I'm going to have to play with the joints.
Here you go....
1) Yes, the bend moves back to where it should be.
Thank you for your help on this.
I have been attempting to convert a outfit from V4 to GNDA2 via Wardrobe Wizard.
After a couple of false starts, I have managed to get the outfit converted with only one issue left.
See Attached image.
When I bend Anastasia's arm, the tunic moves with it. however the bend point for the tunic is farther down than the elbow of Anastasia.
I am stumped as to what I need to do next. Simply adjusting the X axis on the shoulder body part doesn't work.
Any suggestions would be greatly appreciated. I have been digging around in the manual, but I am not sure what I am looking for. For some reason, my copy of the user manual doesn't know what I am looking for.
