Thu, Feb 13, 3:01 AM CST
Subject: Need help w/ applying normal maps...
MatCreator ( ) posted Wed, 18 April 2012 at 7:30 AM · edited Thu, 13 February 2025 at 2:48 AM
For the life of me, I can't figure out what I'm doing wrong that my normal maps won't render properly in Poser Pro 2010... A setting of 1 doesn't show any affect, and anything over 1 causes black splotchy lines to show where the map should indent... I imagine it's something rather simple, but it's evading me...
There are 3 kinds of people in the world. Those that can count, and those that can't..
MatCreator ( ) posted Wed, 18 April 2012 at 7:31 AM
And here are the material room settings...
MatCreator ( ) posted Wed, 18 April 2012 at 7:32 AM · edited Wed, 18 April 2012 at 7:34 AM
And the actual render =/
Would like to release the skin for free, but can't get past setting up the materials to render properly for best results/effect... Any help would be greatly appreciated...
kalrua ( ) posted Wed, 18 April 2012 at 8:09 AM · edited Wed, 18 April 2012 at 8:10 AM
Hi
Normal map, set gamma to 1.
Gradient bump: 1.5-----> too hight for pp2010 (Z depht normal), set to 1
MatCreator ( ) posted Wed, 18 April 2012 at 8:42 AM
I DID set gamma to 1 using the script, double checked it and it is indeed at 1...
Teyon ( ) posted Wed, 18 April 2012 at 8:56 AM
That looks like a shadow issue. I'd check your lights shadow settings.
Also - why did you need to set it to 1.5? I find setting the GB value to 1 leaves it pretty much spot on.
hborre ( ) posted Wed, 18 April 2012 at 8:56 AM
Your gamma on the render settings should be 2.2. The gamma on the normal map in the material room should be 1.
Teyon ( ) posted Wed, 18 April 2012 at 9:14 AM
Quote - Your gamma on the render settings should be 2.2. The gamma on the normal map in the material room should be 1.
Didn't even notice that! Good catch. :)
MatCreator ( ) posted Wed, 18 April 2012 at 10:05 AM
I set the normal at 1.5 because at 1 it isn't showing at all... It's either not showing at all or showing w/ the shadow, so I'll check again, brb...
hborre ( ) posted Wed, 18 April 2012 at 10:13 AM
Don't expect the normal map to be a replacement to displacement, they are 2 different things.  Normals are more like bump maps, they will not alter the mesh in any way and is a good way to give high res looking detail to low poly objects.
MatCreator ( ) posted Wed, 18 April 2012 at 10:32 AM
Not thinking to replace the displacement (I'm actually having the same trouble getting the displacement to show as well, LOL), but I should see "something"...
I started from scratch, didnt use any lights (I'm ussing BB's dome/VSS set up), and here is the result...
MatCreator ( ) posted Wed, 18 April 2012 at 10:33 AM
The render settings...
MatCreator ( ) posted Wed, 18 April 2012 at 10:34 AM
And the material settings...
(Big ups on the super quick response, it is greatly appreciated =)
MatCreator ( ) posted Wed, 18 April 2012 at 10:35 AM
Also, the main preview of the mateial is totally blacked out, is that because this time the scene has no lights or is that a premonition of drama to come?
bagginsbill ( ) posted Wed, 18 April 2012 at 11:28 AM
You didn't use any lights and it looks like the dome is white.
This means that the illumination is the same in all directions.
Do you understand the implications of that?
It means that the brightness of light reflected from a surface will be the same no matter which way it points. And normal mapping changes nothing but which way the surface points. You are using a lighting setup that makes it impossible to observe the effects of a normal map.
Also, when testing normal maps, you should not confuse yourself with color maps as well. We can't tell squat from your picture, because in the same places where the N-map is supposed to be doing something you have the C-map doing something. Very hard to tell what is or is not happening.
SamTherapy ( ) posted Wed, 18 April 2012 at 12:47 PM
And - unless this has changed in later versions - you won't see jack with Displacement if you keep your Min Displacement bounds at zero.  Set them to at least the value of your displacement, preferably higher to prevent clipping.
MatCreator ( ) posted Wed, 18 April 2012 at 1:41 PM · edited Wed, 18 April 2012 at 1:43 PM
But Ted, in the 1st post the scene did have lights, and the dome does have an .hdr "attached" to it. What you see as the background is actually a "stage prop" w/o textures applied.
Now I totally get you on being able to follow/seperate what's going on between the color and normal map (as you guys can see I use the color map w/ a hsv node to remove the color and set the color map to a bw image for a bump map), but as the creator I know that the image is not showing right...
The red veins are cracks/recesses in the skin, and "should" show as such, but I'm not getting anything like that visually. After fixing the materials a bit however, I do see that the bump map is having some effect, and that's good...
Sam, when I get the normals working I will take your advice and apply it for the displacement.
Of course, this could all be for nothing, maybe I have a misconception of what I "should" be seeing in the 1st place =/
Anyways, I have added a texture to the stage prop and added BB's vss outdoor "field" light preset... Still no cracks as expected...
Miss Nancy ( ) posted Wed, 18 April 2012 at 1:49 PM
if others didn't mention, some errors in  shader tree, e.g. diffuse + specular > 1, refl lite mult is checked.  some problems in render settings, e.g. HSV 2.2 is used instead of gamma 2.2.  this render may also not warrant shade rate 0.1 and pix samples 18.  maybe 0.5 and 6 would be adequate at this point.  somebody double-check if shading rate of 0.2 in object properties over-rides shading rate of 0.1 in render settings, or vice versa.
hborre ( ) posted Wed, 18 April 2012 at 2:13 PM
If you are looking for bulging veins, you are better off with displacement rather than normal or bump mapping.  You want to slightly alter the mesh so you may see the bulges from all angles. Much like the vein mapping for M4 which is simply displacement.  The surface displaying bump and normal mapping, pretty much, must face the camera to show a difference.
bagginsbill ( ) posted Wed, 18 April 2012 at 3:13 PM · edited Wed, 18 April 2012 at 3:15 PM
I am writing really fast so sorry if I did not read carefully. What I heard:
Normals are producing no effect at 1
later
Normals are not producing what I expect
These are different statement. Which is it.
My concern is that I cannot see what is being produced with the C-map in place. So I can't tell you which of the many things I might tell you until I see something specific.
Meanwhile I'm guessing:
There is a lack of consistency about the polarity of the green channel in normal maps. For some, 0/1 is down/up, for others 0/1 is up/down.
If you have the wrong polarity, crevices become ridges and ridges become crevices.
If you say you have no effect, ignore this.
If you say you have the wrong effect, pay attention to this.
Could you simply render with white color, diffuse value = .5, and lets us see what the normal map is doing without the obfuscation of color map data?
If it is a green polarity problem, we will be able to see that. If that is the problem I have a simple node solution that will reverse the polarity in Poser. Or you can fix it in the tool where you made the normal map. (Not all tools let you choose the polarity)
vilters ( ) posted Wed, 18 April 2012 at 4:23 PM
Disconnect the color map from the Diffuse.
i allways check bump, displacemet maps on pure neutral gray figures.
it is the only way to see what is going on in bump, displacement, normal maps.
One at the time.
Afterwards, combine, one by one.
bagginsbill ( ) posted Wed, 18 April 2012 at 4:32 PM · edited Wed, 18 April 2012 at 4:32 PM
If it's the green-channel polarity problem and needs flipping, here is how.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3387795&ebot_calc_page#message_3387795
I am getting on an airplane soon.
millighost ( ) posted Wed, 18 April 2012 at 5:28 PM
As a rule of thumb: dents in your normal map have red on the left side and green on the lower side in the preview. From the little preview it looks the other way around for the green. So you have creases when the object is lit from the side, and hills when lit from above with regards to the uv-orientation. Unless your UVs are flipped, of course (very uncommon). Try bagginsbill's suggestion.
MatCreator ( ) posted Wed, 18 April 2012 at 9:05 PM
Wanted to jump in and thank you guys for the help =)
But I'm away from the helm, so I'll marinate on this and go thru as advised, and post manana...
That's plenty to swallow, I'm SOOOOOOOOOO glad there are people like you guys around to explain these things, for me, it just doesn't click naturally this "stuff" you say...
Again, many thanks.....
MatCreator ( ) posted Tue, 22 May 2012 at 8:35 PM · edited Tue, 22 May 2012 at 8:37 PM
A TREMENDOUS shout of thanks to all to have helped me through this "slight" dilema, w/o people like you, the community would be a decaf, short, 1/4 pump sugar free mocha, nonfat, no whip, no foam mocha latte =P
I have completed the materials, and with good results too. In the end, I think what I needed to do was use the color math nodes to reverse the direction of the normal maps, and that gave expected results...
A HUGE special thanks to hborre who took the time to actually create a Poser Pro 2012 SSS version .mtl file, fixing the displacement and normal maps to give "expected" results.
Shown here is a VSS/IDL Poser Pro 2010 set up... Thgis is more or less what I was going for. I noticed that increasing the bump value "distracted" the -umph- of the normal map, so it took quite of bit of play =/
MatCreator ( ) posted Tue, 22 May 2012 at 8:39 PM
Attached Link: freestuff
The texture/material is in my freestuff, feel free to take advantage, I have a few more on the way as well...
monkeycloud ( ) posted Wed, 23 May 2012 at 4:07 AM
Quote - The texture/material is in my freestuff, feel free to take advantage, I have a few more on the way as well...
Cool - thanks :-)
Good thread too... I'm trying to get displacement to work on something, sort of vein related, currently and this surfaced just in time to save me some digging ;-)
MatCreator ( ) posted Wed, 23 May 2012 at 9:02 AM
For displacement, you'll need to adjust the setting in the render settings menu. I have not learned how to do this as yet. I didn't grasp why none of my displacement maps/renders would work, and that was why. So there's more to be had in this thread, I'm not totally done yet =P
monkeycloud ( ) posted Thu, 24 May 2012 at 11:04 AM
Quote - For displacement, you'll need to adjust the setting in the render settings menu. I have not learned how to do this as yet. I didn't grasp why none of my displacement maps/renders would work, and that was why. So there's more to be had in this thread, I'm not totally done yet =P
Hi MattCreator.
Do you mean the "Min Displacement Bounds" setting, which is bottom middle, just above the "Delete Preset" button on that "Render Settings" screen?
As far as I know, this just needs to be set to a number that is a little bit higher than the highest displacement value you have set in any of the materials in your scene?
I've been making a displaced texture on a ground plane for a scene I'm doing...
...but after that I have need of some veins for M4... so I thought I'd have a go at painting these in the 3d paint feature of Photoshop CS5 Extended... and outputting a displacement or normal map from that... should be a good learning exercise for Photoshop anyway...
cheers ;-)
hborre ( ) posted Thu, 24 May 2012 at 11:52 AM
@MC: Glad everything worked out for you.  I'll create an opportunity to dl your latest creation and play with it.
monkeycloud ( ) posted Thu, 24 May 2012 at 11:54 AM
Quote - Vein displacement for M4 python script
http://forum.runtimedna.com/showthread.php?40908-M4-Displacement-Not-only-for-DAZ-Studio&highlight=displacement+m4
Cool, thanks...good to know about that. I will see how I get on painting some myself perhaps... and if that fails... which it may well, LOL, I now have my backup plan ;-)
hborre ( ) posted Thu, 24 May 2012 at 11:59 AM · edited Thu, 24 May 2012 at 11:59 AM
This was in answer to the DAZ only M4 Displacement for veins.  The displacement maps are TIF files and the displacements cover 3 intensities.  Very nicely done.
monkeycloud ( ) posted Thu, 24 May 2012 at 12:10 PM · edited Thu, 24 May 2012 at 12:10 PM
Thanks HBorre... yes I almost bought these last week (only didn't because of their payment system breaking) during which time I realised it was specified as a Daz Studio only product.
Hence I thought I'd just try and make some...
TBH, I suspected, since the maps themselves are just tif files, that I could probably just manually add them to my Poser mats?
But if there's already a script to do this... much better.
Cheers ;-)
hborre ( ) posted Thu, 24 May 2012 at 12:12 PM · edited Thu, 24 May 2012 at 12:15 PM
The script works beautifully.  If you use VSS, it can be incorporated into a template.  I haven't tried using it with Snarley's EZSkin yet, but it may be worth a try.
monkeycloud ( ) posted Thu, 24 May 2012 at 12:21 PM
Quote - The script works beautifully.  If you use VSS, it can be incorporated into a template.  I haven't tried using it with Snarley's EZSkin yet, but it may be worth a try.
Many thanks, if I do go down this route... and there's a fair chance of it, I'll definitely investigate the EZSkin compatability...
MatCreator ( ) posted Thu, 24 May 2012 at 1:02 PM
Photoshop handles/paints in 3D now?!?!?!?
MatCreator ( ) posted Thu, 24 May 2012 at 1:11 PM
You know me, I', real slwo when it comes to marinating on scripts and such... Is the script something that manipulates nodes to mimic veins or is the script actually referencing a displacement image file to apply the effect?
I ask, because I thought it was a matter of setting up displacement thru the render settings, I'm just not following what the script is actually doing...
(I need to read more, brb =P)
hborre ( ) posted Thu, 24 May 2012 at 2:13 PM
The script will insert the displacement maps and appropriate settings for each level of intensity.  It will not disturb any present image map already available for the model.  However, do keep in mind, any displacement/bump you use is dependent on your Poser unit of measurement.  If you are using a measure of feet in Poser, setting a displacement value of 0.1 translates to 0.1 feet.  You will not see any significant displacement.  Now change your unit of measure to inches in Poser, 0.1 inches will show some displacement in the render.
