DAZ|Studio F.A.Q (Last Updated: 2025 Feb 06 11:16 pm)
first u need an unzipper (extractor) like winrar..u can download a free version from the web...then once its installede, go to the folder where the zipped file is, rightclick on it, then select 'extract here' , or direct it to the desired folder path (ur 'DAZ4/Studio/content')...if u use 'extract here', then u'll need to copy/paste the files into their designated destinations...lmk if u need more info
hi every one
since the release of studio 4pro for free my library files became a mess and installing new content from zip files makes it even messier many of the new files are showing but does not have any iconic figures
buying stuff from daz alway,s come with installer but all other provider have zipped file . installing stuff in poser 2010 is easyer using content button and press unzip and it will install the file in the proper location or in the downloaded files to be moved later .i wish i can find a proper solution i have found that renderosity have a better pro centent
documents and settings/jacques/daz3d/studio4/my library/content is almost certainly wrong, it's the DS3 default name nested inside the DS4 default name. Most likely you don't need the Content folder there, and should copy the contents out and paste them into the My Library folder - but check the settings for content paths in Edit>Preferences>Content Library>Content Directory Manager. I don't recommend using the search function, it's too likely to grab folders it shouldn't - especially if there are installation issues already.
i must said thank,s to every one for the implication into my problem i was able to reedit my preferences and now the installation path was reset to my documents /jacques/daz 3d studio/my library 99% of the files are there now i have to try to clean all the mess it did created and resolved the 1% missing files
hi every one
i am a hobbyist and i am not familliar on how to install zipped file into daz studio
every attempt i have made so far resulted in half of the file are not working
can someone help
i am a dummy when it comes installating zip, most of the file i have use have installer
