Tue, Nov 5, 5:14 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 05 11:30 am)
Subject: Reality Render thread. A new beginning.
Amethst25 ( ) posted Sun, 01 July 2012 at 11:17 AM
Quote - Over at the old Daz Forum we could include youtube clips. does that work here too?
If so: how? (could not make it work so posted just a link to the vid)
http://www.dailymotion.com/video/xrbqpu_luxrender-animation_creation
Btw.. on 'DailyMotion.com' they allow ~more~ than on Youtube :)
WoW Charley that was really good!
My Rendo Gallery
My DA Gallery
Reggie68 ( ) posted Sun, 01 July 2012 at 11:25 AM
Quote - Ho I just look at this so I can line them up thank. So you can set it up so it ges back and forth between 2 how?
If you tick Loop Queue and Write FLM it will loop round and continue with the first scene in the queue for another session.
The advantage of this method over running two renders simultaneously is you can run multiple renders which require more resources.
bobvan ( ) posted Sun, 01 July 2012 at 11:28 AM · edited Sun, 01 July 2012 at 11:29 AM
Quote - > Quote - Ho I just look at this so I can line them up thank. So you can set it up so it ges back and forth between 2 how?
Besides picking the film what else do I have to set?
Reggie68 ( ) posted Sun, 01 July 2012 at 11:50 AM
Set the time you want to render for in the Blue box (3600 secs is 1 hour) and tick both the red boxes.
Use the Add Files button to add scenes to the queue.
bobvan ( ) posted Sun, 01 July 2012 at 11:57 AM
Like this?
Reggie68 ( ) posted Sun, 01 July 2012 at 12:02 PM
Yeah, but you need to put something in the Overrride Halt Time box.
If you want the 1st scene to render for 1 hour and then swap to the second for 1 hour and then go back to the first and so on, put 3600 into the box.
Otherwise it will just run the 1st render until you stop it.
bobvan ( ) posted Sun, 01 July 2012 at 12:07 PM
> Quote - Yeah, but you need to put something in the Overrride Halt Time box. > > If you want the 1st scene to render for 1 hour and then swap to the second for 1 hour and then go back to the first and so on, put 3600 into the box. > > Otherwise it will just run the 1st render until you stop it.
I saw that and have it lie this now
Reggie68 ( ) posted Sun, 01 July 2012 at 12:11 PM
That's it.
Xandi ( ) posted Sun, 01 July 2012 at 1:30 PM
One of the creators of the Wonderous Wares product posted an answer to my problem with using it with Reality/Lux. This is his post.
"I’m sorry, we’ve both been talking about it and a Reality version would need completely reworked textures to handle transparency in a similar way to the DS versions.  It would also need it’s own set of shaders for both the glass and liquids, probably another 35% worth of the work that’s already gone into the set.  I’ll mess around with the idea of a small addon which adds support, possibly for Octane too, but it would have to be separate to justify the amount of extra work it’d take.
My apologies."
So, does am I just out of luck and can't use it?
BradHP ( ) posted Sun, 01 July 2012 at 2:02 PM · edited Sun, 01 July 2012 at 2:03 PM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=2344732
Haven't had much Daz time lately, but wanted to throw something together to help with the Reality crediting initiative.  Close ups are easy, and even better when using skin settings from ACSEL (V5Bree).  Click for full size in my gallery.
john3d ( ) posted Sun, 01 July 2012 at 4:21 PM
Great animation Charley :)
Reggie - Did you get those V4 earphones ?
Reggie68 ( ) posted Sun, 01 July 2012 at 5:30 PM
No, couldn't find any in-ear phones
Doctorjellybean ( ) posted Sun, 01 July 2012 at 5:41 PM
Cue for John to make some :)
My DA Gallery
bobvan ( ) posted Sun, 01 July 2012 at 8:48 PM · edited Sun, 01 July 2012 at 8:48 PM
Attached Link: Hand held
Nother alex appt ibl only no map
Pret-a-3D ( ) posted Sun, 01 July 2012 at 9:56 PM
Quote -  So, does am I just out of luck and can't use it?
This is a classic case that shows how much easier is to do things right upfront instead of trying to retrofit products later. BTW, there is no need to do make any special shaders, just to have the right textures. Transparency maps are not needed because that property is built in the physical material. Get the right texture, plug it in the trasmission channel, you're done. Can be done in a couple of hours.
You have, as I have, now a good collection of vases that cab ne used with Reality, your best results, though, will be achieved with solid colors instead of textures.
BTW, this is a limit case, I used many textures with glass without doing much more than small adjustments. This is a classic case of faking results with shader tricks that are far detached from real world physics.
Anyway, good deal in communicating with the vendors, now they are aware of the limits of their approach and might do something else in the future.
Cheers.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
neimann ( ) posted Sun, 01 July 2012 at 11:55 PM
This looks like a great place to hang out and learn about Reality. I thought I might include one of my first atempts at using Reality. A rather sad little clown. Could be sitting in his ratty old hotel room or a cheap bar. I wanted to show some realistic looking smoke for the cigarette using a brush in PS but I was unable to achive the desired effect.  Anyway he was fun composing.
Cheers everyone...
bobvan ( ) posted Sun, 01 July 2012 at 11:56 PM
Welcome nice
Pret-a-3D ( ) posted Mon, 02 July 2012 at 12:00 AM
Hey Neimann.
Welcome to the group. Nice original composition. Clowns freak me out :) but this image is a cool "freeze frame", a moment in time, that has a nice feeling.
Paolo
Tw: @preta3d
john3d ( ) posted Mon, 02 July 2012 at 1:16 AM
> Quote - Cue for John to make some :)
Already done. Reggie, all I have to do is add a couple morphs and package them up for you. I will finish them off and post them to you tonight.
The above image was rendered using the softbox which comes with the RealitySpots set, gave me an excuse to render the Reality book again :)
Pret-a-3D ( ) posted Mon, 02 July 2012 at 1:35 AM
Great stuff John. I'm busy on a deadline but I will play with your new ligths after SIGGRAPH.
Cheers
Paolo
Tw: @preta3d
Reggie68 ( ) posted Mon, 02 July 2012 at 1:49 AM
Quote - > Quote - Cue for John to make some :)
Cool, thanks. Couldn't type much last post as was using phone.
bobvan ( ) posted Mon, 02 July 2012 at 7:29 AM · edited Mon, 02 July 2012 at 7:30 AM
I hate using the net on my phone
Sharkbytes-BamaScans ( ) posted Mon, 02 July 2012 at 8:28 AM · edited Mon, 02 July 2012 at 8:31 AM
Been a few days since I've posted a render.  Can't seem to get all the ingredients to come together at one time.
On a side note for Paolo.  Something is amiss with the Acsel shaders in my Reality 2.0.  It seems they're not loading.  I go to the acsel tab, download the appropriate shader, and then nothing happens.  I see the status where it's downloading and installing; but, I get nothing after that.  I browsed to where the .db is supposed to be and it's there.  Then I click on the shader operations button on my materials tab, go to Load Shaders, and there's no db there even though I JUST verified that it was, in fact, there.  Any help you or anyone else in the community can give would be nice.
Sharkie
[edit]
And yes, gave Reality proper credit on this shot in my gallery too.
[/edit]
Pret-a-3D ( ) posted Mon, 02 July 2012 at 8:50 AM
Quote - Then I click on the shader operations button on my materials tab, go to Load Shaders, and there's no db there even though I JUST verified that it was, in fact, there.  Any help you or anyone else in the community can give would be nice.
That's not how ACSEL works. The "A" stands for automatic, you don't have to use "Load Shader" at all. All you need to do is to place the figure designated for the shader in you r scene, with the texture package designed for the shader. Load Reality and the ACSEL shaders are used. That's it.
Please note that a shader made for V4 will only work with V4, not with Genesis.
Cheers.
Paolo
Tw: @preta3d
Pret-a-3D ( ) posted Mon, 02 July 2012 at 8:57 AM
Just to illustrate my point about the "Woderous Wares" and the textrues, here it is a text done with one texture that I made lighter in PhotoShot using the Levels adjustment. It took a couple of minutes to do and another couple of minutes to set up the scene. One mesh light.
Click image for full size.
BTW, I setthe subdivision for the vase material to 1, the original geometry is a bit rough for a close-up like this.
Cheers.
Paolo
Tw: @preta3d
bobvan ( ) posted Mon, 02 July 2012 at 9:01 AM · edited Mon, 02 July 2012 at 9:02 AM
Nice Paolo and I wanted to thank the community and its tips, and offer one of my own. In this scene notice how the finger nails stick out oddly in the 1st render.
I went and removed the displacement map from the skin hand and woila!
Amethst25 ( ) posted Mon, 02 July 2012 at 9:48 AM
Quote - This looks like a great place to hang out and learn about Reality. I thought I might include one of my first atempts at using Reality. A rather sad little clown. Could be sitting in his ratty old hotel room or a cheap bar. I wanted to show some realistic looking smoke for the cigarette using a brush in PS but I was unable to achive the desired effect.  Anyway he was fun composing.
Cheers everyone...
I quite like this!  Very well done for your first render.   Looking foward to see more from you.
My Rendo Gallery
My DA Gallery
Tollaris ( ) posted Mon, 02 July 2012 at 11:16 AM
Newest one that I have done. Pure white skin is hard to get so it doesn't blow out.
bobvan ( ) posted Mon, 02 July 2012 at 11:38 AM
Good one
john3d ( ) posted Mon, 02 July 2012 at 12:13 PM
Reggie, I sent you a PM with the link to your head phones, I hope they are okay.
Doctorjellybean ( ) posted Mon, 02 July 2012 at 12:23 PM
Quote - Reggie, I sent you a PM with the link to your head phones, I hope they are okay.
Does it play Madonna's "Like A Virgin" when plugged in?
My DA Gallery
bobvan ( ) posted Mon, 02 July 2012 at 12:28 PM · edited Mon, 02 July 2012 at 12:31 PM
Attached Link: Doll Madonna
> Quote - > Quote - Reggie, I sent you a PM with the link to your head phones, I hope they are okay. > > Does it play Madonna's "Like A Virgin" when plugged in?
I already rendered her (Devil face)
Doctorjellybean ( ) posted Mon, 02 July 2012 at 12:32 PM
Well, considering Reggie's girls are virgins .......
My DA Gallery
bobvan ( ) posted Mon, 02 July 2012 at 12:33 PM
Quote - Well, considering Reggie's girls are virgins .......
Yeah bring on some fo youre hotties doc
Xandi ( ) posted Mon, 02 July 2012 at 12:33 PM
The lonely clown surprised me.  Usually I don't even look at them because they're so creepy, but I'm glad I viewed this one.  He looks so sad and lonely.  Very nicely done.
Tollaris, I really like your white skin portrait. What did you do so that it came out so well and didn't blow out?
Sharkey, put some  sunscreen on that girl!  Cute scene.
Now I'm going to rush off and look at those vases again after seeing Paolo's render.
Doctorjellybean ( ) posted Mon, 02 July 2012 at 12:45 PM
Quote - > Quote - Well, considering Reggie's girls are virgins .......
Be careful what you wish for :laugh: I'm actually working on one
My DA Gallery
Tollaris ( ) posted Mon, 02 July 2012 at 12:49 PM
Quote - The lonely clown surprised me.  Usually I don't even look at them because they're so creepy, but I'm glad I viewed this one.  He looks so sad and lonely.  Very nicely done.
A lot of tweeking of lights and exposure settings, plus using Color Space set to D55 and Agfacolor FuturaII 400CD film responce. Making sure the skin's diffuse was set to 220 220 220 helped too.
BradHP ( ) posted Mon, 02 July 2012 at 3:22 PM
Attached Link: http://www.renderosity.com/mod/gallery/media/folder_235/file_2345076.jpg
Here's a car, because I still don't have as much free time as I want and shiny things look pretty with Reality.
erik-nl ( ) posted Mon, 02 July 2012 at 3:33 PM
Hi all,
My first post here, I hope everything works as intended : )
Been away for a month, but also been working hard to improve my DAZ/Reality skills.
Quite a few fresh images in my spanking new DA collection, but to be honest many of them still need hours and hours of cooking to get rid of all residual noise.  Nevertheless I would be pleased if some of you would care to take a look, and perhaps even leave a comment or two. Thanks in advance!
http://erik-nl.deviantart.com/gallery/
Here's one of them (if I manage to do this correctly), Cheers!
Reggie68 ( ) posted Mon, 02 July 2012 at 3:41 PM
Who told you that? Gemma's taken her M5 Pro back to the shop 4 times already.
Xandi ( ) posted Mon, 02 July 2012 at 3:58 PM
Quote - Just to illustrate my point about the "Woderous Wares" and the textrues, here it is a text done with one texture that I made lighter in PhotoShot using the Levels adjustment. It took a couple of minutes to do and another couple of minutes to set up the scene. One mesh light.
Cheers
So......here's my try at the vase.  I lightened the texture in Photoshop but something is amiss. Mine doesn't look like Paolo's.  I used subdivision 1 as well.  It looks like he got the expensive vase and I got the cheap knock off.   Help please? my lightened vase
Sharkbytes-BamaScans ( ) posted Mon, 02 July 2012 at 3:58 PM
Quote - Here's a car, because I still don't have as much free time as I want and shiny things look pretty with Reality.
Good lookin render.. it'll have my wife drooling when she sees it.
Xandi ( ) posted Mon, 02 July 2012 at 3:59 PM
My vase got all weird and skinny when I posted it.  It actually is the same shape as Paolo's.
Honest!
Sharkbytes-BamaScans ( ) posted Mon, 02 July 2012 at 4:01 PM
[Quote]
Xandi.. too me.. it looks to be a case of lighting and exposure.  Paolo's lights are very subtle and seem positioned to get the most out of the texture and its reflectivity.  I'd try your render again; but, halve the exposure and see what you get.
Sharkie
P.S. the above advice was given with the caveat that I suck at lighting and am constantly fiddling with the exposure in my renders until they look nice to me.
Pret-a-3D ( ) posted Mon, 02 July 2012 at 4:36 PM
Xandi, your vase seems to have no highlights. How did you set up your material? Post a screenshot of the material and I will take a look. About the stretching, that is caused by posting the wrong size/ratio. I usually specify only the width and let the browser figure out the hoeight automatically.
Paolo
Tw: @preta3d
Sharkbytes-BamaScans ( ) posted Mon, 02 July 2012 at 4:42 PM
Quote - Xandi, your vase seems to have no highlights. How did you set up your material? Post a screenshot of the material and I will take a look. About the stretching, that is caused by posting the wrong size/ratio. I usually specify only the width and let the browser figure out the hoeight automatically.
Ditto the above3 comment about size/ratio.. i checked the shot on photobucket and it looks fine size/ratio-wise
bobvan ( ) posted Mon, 02 July 2012 at 5:34 PM · edited Mon, 02 July 2012 at 5:35 PM
OT it happened Reality melted down m machine! LOL! After rendering none stop since late feb it is over heating and has to go back for service...
Xandi ( ) posted Mon, 02 July 2012 at 5:36 PM
I'll see if I can figure out how to choose the width.  I didn't chose anything.  Here's the materials I used for the vase.  There's nothing in the other tabs except the subdivision is set to 1. I couldn't figure out how to set any dimensions for the picture.
Vase Mats
Doctorjellybean ( ) posted Mon, 02 July 2012 at 5:43 PM
Reality gets the dimensions from the Render Settings in DS. However, on the Output tab in Reality, there is a Frame Size option, which you can adjust to set the final output dimensions.
My DA Gallery
