Sun, Nov 24, 10:05 AM CST
Subject: Butterfly scales
GeneralNutt ( ) posted Sun, 22 July 2012 at 4:31 PM · edited Sun, 24 November 2024 at 9:56 AM
The lighting effect on butterfly wings has been done on higher end apps, can it be done in poser?
http://www-graphics.stanford.edu/courses/cs348b-competition/cs348b-01/iridescent_butterflies/morpho.html
and
http://graphics.ucsd.edu/~iman/Morpho/
bopperthijs ( ) posted Sun, 22 July 2012 at 5:34 PM
I suppose this is another challenge for Baggingsbill.
I saw some math in the first link, so he will know how to make a shader of it. (Or at least say it's impossible in poser)
GeneralNutt ( ) posted Sun, 22 July 2012 at 5:52 PM
I tried looking at his scale shader and the nylon2 shader, but I get lost fast. I think it's a job for matmatic for sure. The changing colours might mean caustics, which would mean no.
GeneralNutt ( ) posted Sun, 22 July 2012 at 6:05 PM
SamTherapy ( ) posted Mon, 23 July 2012 at 12:45 PM
Butterfly scales?  Why on earth would you want to weigh a butterfly?  They're light.  Very light, in fact.  That's all you need to know.
HTH.
bagginsbill ( ) posted Tue, 24 July 2012 at 7:05 PM · edited Tue, 24 July 2012 at 7:09 PM
Attached Link: Free butterfly wings
Hm.
Those guys went about it a very hard way and got little results for it.
Here's my stab.
http://www.youtube.com/watch?v=Z7zDYKzhavk
That is a preview render - right out of Poser preview. I didn't even actually render it.
It's just a free pair of wings with a simple color map. I could do better but I'll leave that to you guys.
bagginsbill ( ) posted Tue, 24 July 2012 at 7:08 PM · edited Tue, 24 July 2012 at 7:12 PM
Here's the shader. The numerical and color values don't matter much - it depends on your map and what colors you want.
The map I had was green. Using HSV I shifted it to blue and magenta.
You run your variations into a ColorRamp, which is driven by Edge_Blend. The Edge_Blend changes value based on viewing angle.
Specular also changes value based on viewing angle and light source angle. I did one branch with Diffuse and one branch with Specular. Mix and match to whatever goal you want.
There is no math here - you see what you're going to get in real time.
GeneralNutt ( ) posted Tue, 24 July 2012 at 7:45 PM
Thank You very much! The animation looks pretty cool can't wait to try this out. Thanks again.
