DAZ|Studio F.A.Q (Last Updated: 2024 Sep 19 12:07 pm)
that polygon may have it's normal reversed. I don't know if Studio can sort that out or if it will need to be run through a modelling app
My Freebies
Buy stuff on RedBubble
that is a reversed normal - the polygon normal is pointing in the wrong direction
My Freebies
in Poser, you can do it in the material room. Don't know if Studio can something similar. If not it'll have to be done in a modelling app
My Freebies
Looks like the old "Black Poly" problem, DS has always had a problem with it's internal triangulating of some polygon shapes, it does it badly enough so that the normals no longer work and turn the poly black when they are applied, 3 vertices in or almost in a row in a quad or ngon will cause this.
Looking at the picture and location & shape of that poly, I'd say that was PT-Vicki's leg (or her little sister) as she has that exact same problem in the same place, but Laura doesn't.
Thanks for all of your help
Poppa C
