Sat, Feb 8, 10:40 AM CST
Subject: Poser heaven has arrived?
nobodyinparticular ( ) posted Fri, 12 October 2012 at 9:31 AM
I would suggest you download it while it is free. No telling when that will end. You can install it at your liesure.
DavidGB ( ) posted Fri, 12 October 2012 at 9:39 AM
Quote - Individual body parts or areas do not scale well for Genesis. Seeing that figures made according to Poser specifications can scale better. The converted Genesis figure is still not
I notice that if I use Shoulders Wide, which just dials up the xscale on the collar bodyparts, the arms dislocate at the collar/shldr join on bending the arms down.
But this happens as well (in fact even worse given where the boundaries of the collars in the torso are) with V4 in Poser, just as it's always done when differentially scaling one axis of a bodypart since I started using Poser with Poser 4 (which was a main reason why I started using DS for rendering some of my characters that needed differentially one-axis scaled body parts back in 2006 when such scaling was fixed to work right in DS).
I had understood this had been finally fixed in one Poser 9/Pro 2012 SR, so I am a bit puzzled. I'm guessing that because the function has been broken for so many years in Poser, DAZ have not done something needful for their figures to function this way in the now-finally-fixed Poser as they did work in DS, and one couldn't easily see what was wrong for Poser when the function didn't work in Poser anyway. Does anyone know specifically what the issue is? Some particular joint parameter? With the function now working in Poser, perhaps DAZ will fix whatever it is that needs fixing in the Gen4 figures and Genesis for this to work in Poser as it does in DS.
DCArt ( ) posted Fri, 12 October 2012 at 9:39 AM
Quote - Thanks for the reviews, all.  Reading them with interest.
Still have not downloaded or installed this plugin myself, partly because I don't have time to figure it out this week, partly because I'm a little nervous at the reports some are having trying to uninstall it.
Do I have to buy something to try it out?  Or is there a figure to test it on in that Genesis starter essentials thing?
Comes with a base figure (or Poser companion)
For me, the installation was pretty easy ... I installed ONLY the plug-in to the Poser installation directory; then I creatd an external runtime (D:/Content/Genesis) and placed all my Genesis content, including the content files furnished with the DSON importer, into it.
I haven't been using DAZ Studio, so I haven't had to worry about double installations ... but I suppose if I did, I could just point the DAZ content manager to the Genesis runtime and have them both work.
DCArt ( ) posted Fri, 12 October 2012 at 9:43 AM
Quote - > Quote - Individual body parts or areas do not scale well for Genesis. Seeing that figures made according to Poser specifications can scale better. The converted Genesis figure is still not
There is a "Fix Mismatched Scale" button in the Joint Editor that will resolve the problem (for Poser 9 users, you'll find it added in Poser 9 SR 3.1).  Read the manual, as the steps have to be performed in a specific order.
DAZ_kevin ( ) posted Fri, 12 October 2012 at 9:57 AM
Hopefully an easier fix for this is to instead log in, add something else to your cart, then go to your cart, BOTH items should be there.  Remove the one you didn't want and check out with the DSON importer and enjoy!
Quote - The title of the thread is a reference to a DAZ promise from awhile back - that if Poser users stuck with DAZ, they'd be in heaven soon.  I think we can assume this plugin is what they were hinting about.
For those having problems "purchasing" the plugin...that's a problem many have been having for awhile now.  If logging in doesn't fix it, delete your DAZ cookies, clear your cache, and start again.  Their new web site really is a pain.
wimvdb ( ) posted Fri, 12 October 2012 at 10:03 AM
Quote - > Quote - > Quote - Individual body parts or areas do not scale well for Genesis. Seeing that figures made according to Poser specifications can scale better. The converted Genesis figure is still not
The Fix Mismatched Scale button does repair F4. I don't think it repairs the shoulder (or actually collar) problem in V4 - at least I have not found the order in which to do do this. Genesis does not seem to have the smoothing zones, but maybe they are just hidden, I haven't been able to try that out yet
LaurieA ( ) posted Fri, 12 October 2012 at 10:08 AM
Quote - I installed the DSOI importer to my Poser runtime and I created a new runtime for genesis and installed both essentials installers into that.
That worked for me
I think both if the essential installers have to be in the same runtime and the add-on needs to be in the program files poser runtime for the importer to work
Yep, I did exactly this and for me, everything went flawlessly.
DavidGB ( ) posted Fri, 12 October 2012 at 10:11 AM
Quote - There is a "Fix Mismatched Scale" button in the Joint Editor that will resolve the problem (for Poser 9 users, you'll find it added in Poser 9 SR 3.1).  Read the manual, as the steps have to be performed in a specific order.
I see the function in Pro 2012 SR3, but can't find it in the main manual or the SR3 ReadMe. Is it only explained in the SR3.1 docs (which I haven't got yet).
I am curious as to the basis of this, though, especially as it would be better to load figures working rather than the user having to process the figures to fix them after loading. Is the issue something technically wrong in the figures which DAZ could fix but they never noticed before as the function wasn't working in Poser to see? Or is the fix to the longstanding bug in Poser not actually a proper fix but a way of fudging round the problem that that function in the joint editor adds, but would break the figures in DS where they have functioned this way since a DS 1.something?
Must check the DS4.5 changelogs to see if there's a mention there. The 'mismatched scales' expression is ringing a faint bell, like maybe I read it before without knowing what it was about.
wolf359 ( ) posted Fri, 12 October 2012 at 10:13 AM
congrats to poser users
Cheers
My website
randym77 ( ) posted Fri, 12 October 2012 at 10:16 AM
Quote - I would suggest you download it while it is free. No telling when that will end. You can install it at your liesure.
I've already "purchased" it.  Just haven't downloaded it yet.  You can always reset your downloads at DAZ.
But I wonder if they will ever start charging for it.  Remember that "game-changing, industry-shaking announcement"?  DS Pro, Bryce, and Hexagon free for one month.
Going on a year now, and they're still free.
richardson ( ) posted Fri, 12 October 2012 at 10:17 AM
So,,, generally speaking;
the DSON exe goes to Main Poser runtime (default)
The 2 Genesis content files can go to a folder on any drive _OTHER THAN_C:Program Files and get linked via a new directory
I personally had problems as I use a virgin pc (never been online) and needed to upgrade C++ (thanks to Willber on Page4 of this thread) I also never needed a separate drive for content before. If I didn't have one, I guess I would just drop Genesis_essentials on Desktop.
I upgraded SR3.1 first
Genesis works
DCArt ( ) posted Fri, 12 October 2012 at 10:28 AM
Quote - > Quote - There is a "Fix Mismatched Scale" button in the Joint Editor that will resolve the problem (for Poser 9 users, you'll find it added in Poser 9 SR 3.1).  Read the manual, as the steps have to be performed in a specific order.
Not sure, TBH ... the need for the button and the exact "fix" it applies is beyond me.
Yes, the steps were added to the 3.1 manual.
anupaum ( ) posted Fri, 12 October 2012 at 10:35 AM
The Genesis figure appears to accept all of my V4 / M4 MATS. Nice!
LaurieA ( ) posted Fri, 12 October 2012 at 10:36 AM
Well, my fave release lately was Tyler, but this may run a close second ;). Installed flawlessly (I read all the installations instructions and the Daz forum thread first), and it seems to work that way as well. I haven't had any problems. As to the problems with scaling, I have had those if I choose individial body parts, but my purchase of the Genesis Evolution head and body morphs has put most of those functions in FBMs. After all my discounts and things, it was very cheap and I only paid but a few bucks. LOL. I'm happy so far - thanks Daz and SM. I just don't have the time right now to play with it properly and explore all options, but I do like what I see thus far.
LaurieA ( ) posted Fri, 12 October 2012 at 10:37 AM · edited Fri, 12 October 2012 at 10:39 AM
Quote - The Genesis figure appears to accept all of my V4 / M4 MATS. Nice!
Yep, it took the GND4 skin without a hitch ;). So far, the female at least has taken every hair prop and figure I've thrown at it. I assume tho, that after one starts to scale it is where we might run into some problems, such as a V4 hair on the basic child.
anupaum ( ) posted Fri, 12 October 2012 at 10:44 AM
Quote - Yep, it took the GND4 skin without a hitch ;). So far, the female at least has taken every hair prop and figure I've thrown at it. I assume tho, that after one starts to scale it is where we might run into some problems, such as a V4 hair on the basic child.
That's nice.  I haven't tried any clothes yet, but thus far, I've been pleased with how easily this figure installed into my Runtime and how well it works in Poser Pro 2012.
JoePublic ( ) posted Fri, 12 October 2012 at 10:56 AM
Has anyone an idea how to fix the messed up scaling ?
Hate to say it, but with broken single axis scaling and no (direct) access to the moveable joint centers, Genesis is pretty much pointless.
PoserPro 2012 SR3, DSON exporter installed.
V4 vs Genesis.
Shin and thigh = Y-Scale-120%,
Foot and toe = Scale -140%
I'd really like to start working with Genesis, but I need a way to change the default proportions.
As Genesis obviously can change from child to male to female via the animateable joint centers, is there a way to access that functionality manually ?
Jules53757 ( ) posted Fri, 12 October 2012 at 11:01 AM
Try the SR 3.1
http://poser.smithmicro.com/updates.html
Ulli
LaurieA ( ) posted Fri, 12 October 2012 at 11:03 AM · edited Fri, 12 October 2012 at 11:04 AM
I think for now, it doesn't have ALL the functionality of Genesis in DS, just some of it. Not sure of SR3.1 fixes it or not or if Daz will have to fix it.
It would be REALLY nice if we had all functionality, but frankly I'm surprised they got this far ;).
JoePublic ( ) posted Fri, 12 October 2012 at 11:24 AM · edited Fri, 12 October 2012 at 11:28 AM
Well, there is functionality and functionality.
As I create photorealistic custom sculpts that are supposed to look like real people, proper scaling is an absolute necessity.
I don't care about Genesis' mesh layout or default sculpting. It's quite lacking, anyway.(Although I do like M5 a lot better than M4)
I want it because of it's superior rigging and scaleability.
It bends very, very, VERY good in Poser. Best feet, knee and thigh rigging I've ever seen.
But I can't start working on it without a way to change the proportions.
 I don't mind hacking the cr2 or going through Studio 4.5 if necessary. But I do need the same full control over Genesis that I have over all my other meshes.
LaurieA ( ) posted Fri, 12 October 2012 at 11:30 AM
I think for now if you wanna make extreme changes you need to do them in DS
drifterlee ( ) posted Fri, 12 October 2012 at 11:45 AM
I was pleasantly susrprised with the free program. You even get a texture for Genesis. It imported very fast into Poser 2012. Just seconds, really. I purchased the V5 pro model suite also while it's on sale, and the jury is still out on that. I do not care for the included characters. They do not look very real. She does bend well, though, and does not seem to have the V4 joint issues that can look so distorted. I am certainly not giving up on V4, though. I have three runtimes filled with just V4 stuff. You are saying V5 will take V4 textures? Or just the Genesis female? If so, that is reallu cool. Let me know. Cheers, Sherrie
drifterlee ( ) posted Fri, 12 October 2012 at 11:46 AM
There sure were a lot of files to download from Daz. Legacy files, Daz studio and Poser companion files. I hope they simplify that.
Male_M3dia ( ) posted Fri, 12 October 2012 at 11:49 AM
Genesis will take the Gen4 textures, but you'll need to use one of the textures from the content to change it to the proper UV. I think the Lana one will change the UV to V4.
LaurieA ( ) posted Fri, 12 October 2012 at 11:53 AM
Quote - Genesis will take the Gen4 textures, but you'll need to use one of the textures from the content to change it to the proper UV. I think the Lana one will change the UV to V4.
Yes, it does. I used that first, then applied GND4's textures. It worked :).
DavidGB ( ) posted Fri, 12 October 2012 at 11:58 AM
I agree. I'd like to switch to using Genesis in Poser rather than DS, but I need to be able to single-scale various body parts to change the length of the legs, the width of the shoudlers etc.
But I seem to be onto something ....
Haven't quite got to the bottom of this yet, but ... with Genesis loaded, a bodypart selected and the joint editor panel open there's a button on the panewl marked  Scale Zones. Clicking this allows to select other parts whose scaling should be affected by the scaling of that body part, and smooX etc joint parameters appear where there weren't any. Just a few selection clicks in the collars to affect the shldrs fixed the dislocation of the arms at the collar/shldr interface on bending the arms down with Shoulders Wide (actually just xscale of the collars) applied.
It looks like the collar/chest abdomen discontinuity with Shoulders Wide applied will actually need the smooX and SmooY parameters adjuiting after clicking for them to be added ... but it's doable.
Bottom line would appear to be:
Yes, the user can fix the  Genesis in Poser so all the (many) proportion dials wil work.
But the root problem appears to be that the DSON importer is not importing/creating the smoothscaliung joint parameters. One would hope DAZ could do something about that in a timely fashion.
DCArt ( ) posted Fri, 12 October 2012 at 12:14 PM
Bingo. Have already contacted DAZ.
LaurieA ( ) posted Fri, 12 October 2012 at 12:16 PM · edited Fri, 12 October 2012 at 12:17 PM
Thanks Deecey. That will hopefully get things rolling on their end. Especially if they want ppl to spend, spend, spend...lol ;).
fonpaolo ( ) posted Fri, 12 October 2012 at 12:33 PM
So, is better wait a fix before download some hundred megs of files?
Just asking...
DCArt ( ) posted Fri, 12 October 2012 at 12:42 PM
Quote - So, is better wait a fix before download some hundred megs of files?
Just asking...
It appears to me the issue shows up only when you try to scale body parts. So far it appears to bend fine otherwise.
Note, though, that I haven't installed the morphs packs yet. But I suspect that the morphs will work fine as long as you don't start scaling body parts excessively.
anupaum ( ) posted Fri, 12 October 2012 at 12:42 PM
So, how do the morphs work?  Are there Poser-specific body morphs?
JoePublic ( ) posted Fri, 12 October 2012 at 1:06 PM
Many thanks for the reply, DavidGB.
As you can see, your solution works.
At least I have the head size, arm and leg lenght as well as foot size (more or less) working.
I don't think I want to do DAZ' job and add all the scaling zones as it requires not just creating the zones but also carefully weightmapping them.
But it's enough for now to fool around with Genesis a bit until an official fix is released.
Thanks again.
cspear ( ) posted Fri, 12 October 2012 at 1:09 PM
Just playing around with this...
Loaded Genesis, dialled in a child morph, applied an M4 texture, dialled in a pose / expression, then dragged-and-dropped (from the Poser library) some clothing items, hair and a prop onto the figure.
And hey presto! Everything snaps into place, more or less... just a tiny bit of poke-through on the left boot.
Then changed the body shape to a female, loaded a V4 texture, ran the DSON support > Transfer active morphs script. The only glitch was that the sword didn't behave itself: easily sorted by deleting it, selecting the figure and reloading.
So well done DAZ, this seems to work really well!
PoserPro 11 - Units: Metres
Adobe CC 2017
jartz ( ) posted Fri, 12 October 2012 at 1:11 PM
So, in truth, we would have Genesis in Poser with this (DSON and Installers)?
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
cspear ( ) posted Fri, 12 October 2012 at 1:12 PM
Quote - So, in truth, we would have Genesis in Poser with this (DSON and Installers)?
That's exactly what's in the images above.
Adobe CC 2017
jartz ( ) posted Fri, 12 October 2012 at 1:14 PM
Ah, sweetness!  Nice layout you've done, cspear
P.S.: I got the whole kit and kabootle and will play with it later, like to see how others come out.
DCArt ( ) posted Fri, 12 October 2012 at 1:18 PM
Quote - Just playing around with this...
OK, is it me or does that character on the left look like Mac from "It's Always Sunny in Philadelphia" ...
http://www.imdb.com/name/nm0568390/
Demon2330 ( ) posted Fri, 12 October 2012 at 1:33 PM
Got it working Finally ! did the same as alot of others bunged the DSON script in install directory Runtime and then put the content into a folder called Genesis Essentials poser automatically detected the runtime and it worked a piece of cake seems to my oppion if its all in the runtime it wont work.
Not installed V5 yet thats the next challenge.
Desktop : AMD FX4100 , GT-630 1GB, 4x BD-RE , AOC e2343 23in LED Monitor , 1TB External (120mb/s write speed)(stores my all poser stuff and photo's from camera) and 1TB internal HDD
P2010 , P2012 , P2014 , Reality 3 , Max 2014 , Lightwave 11 , Showcase 2014
Website @ www.steadyrabbitdesign.freezoy.com (New site still under construction) & Dev art : Tim2700
FrankT ( ) posted Fri, 12 October 2012 at 2:01 PM
Hmm..
Downloaded and installed (not sure why I have to have the 32bit version even though I'm using Windows 7 64 bit but hey)
Bit of a snag though.  As soon as I load genesis, my library stops functioning.  Can't switch to pose, material, camera etc. - can't open other items in the figures bit either so looks like it's an uninstall again.  Meh - oh well, it's a good idea I guess.
fwiw, I'm running Poser 9 with the latest SR on Windows 7 Pro 64 bit
My Freebies
Buy stuff on RedBubble
LaurieA ( ) posted Fri, 12 October 2012 at 2:02 PM
Quote - Got it working Finally ! did the same as alot of others bunged the DSON script in install directory Runtime and then put the content into a folder called Genesis Essentials poser automatically detected the runtime and it worked a piece of cake seems to my oppion if its all in the runtime it wont work.
Just install V5 like you installed the Genesis Essentials content. I had no problems with the morphs I added.
anupaum ( ) posted Fri, 12 October 2012 at 2:12 PM
So, you have to have V5 in order for morphs to work?  Is there a separate set of head and body morphs for Poser?
Demon2330 ( ) posted Fri, 12 October 2012 at 2:12 PM
Quote - > Quote - Got it working Finally ! did the same as alot of others bunged the DSON script in install directory Runtime and then put the content into a folder called Genesis Essentials poser automatically detected the runtime and it worked a piece of cake seems to my oppion if its all in the runtime it wont work.
Just finished sorting it out now and its working havent got any morphs installed yet though.
LaurieA ( ) posted Fri, 12 October 2012 at 2:19 PM
BTW, the shaders Daz have supplied are very nice, but also very blue. All the SSS groups are in group 1. If you change the groups on the teeth, inner mouth, gums and toungue you'll lose all that blue around her lips :).
RedPhantom ( ) posted Fri, 12 October 2012 at 2:32 PM · edited Fri, 12 October 2012 at 2:35 PM
Site Admin Online Now!
Just thought I'd share the image I made while testing genesis. I don't have v5 so it's just the basic female but she doesn't look too bad.
anupaum ( ) posted Fri, 12 October 2012 at 2:32 PM
Here's a side-by-side comparison of V4 and Genesis.  The MAT files apply nicely, but the injection morphs obviously DON'T work . . .
V4 is on the left, Genesis on the right.  I forgot to apply the right MAT file to the Koz short bob hair, and the EZ Skin texture isn't quite the same, but you get the idea . . .
DavidGB ( ) posted Fri, 12 October 2012 at 2:37 PM
Quote - So, you have to have V5 in order for morphs to work?  Is there a separate set of head and body morphs for Poser?
No. There are no 'morphs for Poser', just Genesis morphs as for DS4 - they are in .dsf format and go into the Genesis 'data' folder, which will happen if you install the same way and place as the Genesis essentials.
The Genesis Essentials come with a bunch of morphs - basic male, female and kid, expression morphs, and a bunch of FBMs like heavy, Bodybuilder etc. If you've got Genesis into Poser with this importer you already have those. Then there are extra morph sets like the Genesis Evolution Body and Head and Expression morphs, creature Body and Head morphs, V4, M4, S4, H4, F4, A4, G4, M3, V3, S3, H3, F3, A3, D3, And the M5 morphs and the V5 morphs and S5 morphs. Because you can mix all morphs, there's no 'Body morphs for V4' and Body morphs for M4 like with the Gen4 figures. So the Bodybuilder base morph, for example, works with M4, or V4, or M5 or V5. You cna mix all the morphs together, so have a part M4, part D3, part M5, part F3 and some Bodybuilder with some Ogre morph or whatever. The provided transfer utility should put any of the morphs you are using into the clothes that the clothes don't have.
Also note that if you e.g. loved David3 but wanted a weight-mapped version, you can dial up just his morph (if you have bought it) and have a figure the shape and size of D3, but with Genesis weight-mapped bending instead of the grotty old gen3 bending.
Also there's the GenX utility for DS by Dimension3D. With it and the appropriate figure packs for it, you can convert any generation 3 or 4 morph, set of morphs or custom character morph to Genesis, then useable with Genesis in Poser - so you can migrate favorite  gen3 or gen4 characters to the Genesis figure to have the character but with the better Genesis bending. (Note you do now need to use the (free) DS4 to use the GenX plugin to convert the v3, M3, V4, M4 etc morphs to Genesis, but the morphs can then be turned into versions that will load into Genesis in Poser).
DCArt ( ) posted Fri, 12 October 2012 at 2:40 PM
Quote - Here's a side-by-side comparison of V4 and Genesis.  The MAT files apply nicely, but the injection morphs obviously DON'T work . . .
Are you trying to use V4 injections on V5?  I might be wrong on this, but I think the main reason it doesn't work is because Genesis is much lower poly (about 1/4 the number of polys that V4 has), so it makes sense that the morphs wouldn't work. I am still installing things so don't know yet if V5 has injections of her own.
Anyone?
anupaum ( ) posted Fri, 12 October 2012 at 2:46 PM
I suspected that you had to either have V5, or had to use the Ralf Sessler utility and DAZ Studio to convert the Gen X morphs.  David GB has tried to enlighten me, but I have a migraine right now, and the medicine for it makes language more difficult to process.  I'll have to wait until I'm "normal" to understand what he's written.
DavidGB ( ) posted Fri, 12 October 2012 at 2:48 PM
Not sure what you mean by 'the injection morphs obviously DON'T work'. Obviously V4 injection morphs don't work on Genesis - she's a different figure with a different mesh, just like V3 morphs don't work on V4. Plus she's not set up to use any kind of INJECTION morph, DAZ started with injection morphs with V3, developed them with the ExP system with V4, but they were always a nightmare for support and with the new Genesis system and the DSON files they have dropped the whole notion of injecting morphs. When you install Genesis morphs, they are then just there next time you load a Genesis - there is no injecting anything at all.
Genesis morphs work on Genesis. And as I explained above, with DS4.5 and the GenX plugin you can also convert all generation 3 and generation 4 morphs to Genesis versions as well. (With the GenX plugin, you can convert all V4 and M4 morphs. To convert M3, V3, S3, D3, F3, A3, H3 and G3 morphs rerquires GenX expansion packs). So you can use V4 and M4 morphs on Genesis (and the pose files that set them to create characters), but ONLY by converting the morphs (and pose files) with GenX.
Morana ( ) posted Fri, 12 October 2012 at 2:49 PM
Has anyone tried importing the Poser Genesis to Vue?  I haven't had a chance to play with any of this yet, but I'm curious if I can now use M5 in Poser and then import him into Vue as easily as I do the Gen4 figures.
lady-morana.deviantart.com
