DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
Attached Link: http://bobvan.deviantart.com/art/368-355706160
A render from my current chapter on D/AContent Advisory! This message contains nudity
Attached Link: http://bobvan.deviantart.com/art/Sex-cyclops-7-5-355798069
Rendering like this can be a huge time saver since the water is part of the BG wallpaper
I find a lot of IBL renders look like a forground pasted with a BG look
"Excuse me, are those cargo pants new?
"I refer to the Runtime Appearance Contract of Penny which clearly stipulates that all newly bought products will be tested by the formentioned Penny in the first instance. They will be tested to see if my bum looks big in them. If that does happen they will be removed from the list of available outfits. Only after this test will they be available for other non-stipulated persons to wear.
"So missy, remove those pants"
@ Bobvan
That is one naughty Cyclops! A Cyclops has one eye, right? Now does he also has one ..uhm.. 'you-know-what-I-mean' ? :)
@ Reggie68
You do know there is NO right answer found yet in this world when a woman asks: "Does my bum look big in this?"... :P
@ Rayman20
Very dramatic lighting, I like it! If you had not said anything about displacement I would not have known. :)
@ Amethst25
Very nice Kimmers! Maybe a side-light to her back would make her 'pop out' a lil' more?
@ Jennyver
Beautiful! Lovely scene and pose! The little red dots aren't fireflies I think. It seems to be a noise created maybe due to some materials having a high specular setting. Those dots can be very persitent, I usually clone them out in photoshop.
Attached Link: ENLARGE first image
Have been working on my 'GEL Cam' set the past few days.Here are some features:
3 small size GEL projection Cameras
Preview in viewport to exactly position the projection
Use of camera controls to Easy Pose the GELs
98 colored GEL mat-files included
150 SHAPE mat-files included
GEL & SHAPE can be mixed
GEL mask and SHAPE mask can be mirrored and scaled individually
Sharpness of the projection can be adjusted from razor-sharp to fuzzy
10 presets to load your own image for photo-projection purposes
The possebilities seem to be endless, just do the math: 98 X 150 different projections for each camera. When the three GEL Cams are combined, well... as said, just do the math. :)
Now I have to write the guide, that is going to take some time, then a testing period and then the set is yours.
Here are two examples on what they can do. In the first image Justine is holding an actual GEL Cam so you can see how 'big' it is. The second image shows a random example of two GEL Cams combined. No post work on both images other than adding text in the first one.
Quote - You've been busy Charley, very impressive list of contents and your renders are excellent (as per usual).
Personally I got bored and started one of those WIP projects where I fill a room with odds and sods, I need to add a curtain pole and some scatter cushions, then look at it again (and again) :)
It's a great WIP, would like to see the final result :)
Quote - > Quote - You've been busy Charley, very impressive list of contents and your renders are excellent (as per usual).
Agreed, nice work.
Regards, Michael
Attached Link: http://i1056.photobucket.com/albums/t366/xandi11/Summerwatering4_zpsc10e80d1.jpg
I'm hesitant to post this after seeing everyone's work, but ....here it is. I'm finally posting something again, that counts, right?LuxRender 1.2 has been officially released. Download it NOW!
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
Quote - I'm hesitant to post this after seeing everyone's work, but ....here it is. I'm finally posting something again, that counts, right?
Actually I find this quite excellent. I assume IBL for the lighting.
How did you do the ground? Are the plants Lisa's Botanicals? (The clothes are Hypwear and Extreme Cut Offs?)
I'm not sure if anyone else is having PC issues. Mine was making a racket when I was rendering.
My PC is an ROG mother board, fast fast fast 16GB RAM, and a 3.8Ghz processor with a stock CPU FAN, and Geforce 560Ti (2GB) video card.
The stock fan would go into overdrive when I was rendering. Given that my last bunch of renders are chewing in excess of 10GB of RAM, with FLM saves > 1.2GB, its no wonder my PC was chugging... for 3 days through some of these renders.
I just upgraded to water cooling. I put in a Corsair H6O. ('cause thats more than H2O?)
Overall my PC is louder, but it hardly breaks a sweat when I'm rendering. CPU temperature is topping at 70C and holding there. The loud turbo fan sound is long gone.
Quote - LuxRender 1.2 has been officially released. Download it NOW!
I was waiting for an update cool. I feel these great plug in & program allow me to be a decent render artist & lets me express my vision!
Xandi very nice!!!!
Attached Link: http://www.deviantart.com/download/356330363/mermaid_boat_by_lasserine-d5w5e9n.png
This one came out ok.Quote - I'm hesitant to post this after seeing everyone's work, but ....here it is. I'm finally posting something again, that counts, right?
This is a very nice render, Xandi!
Quote - > Quote - I call this one Henpecked. Please click for larger version.
I really like this render... Mind if I ask how you did the lighting? Sun? IBL? for the outside, and regular meshes on the inside?
Thank you UHF. Just a sun, and the wall lamps converted to light (which wasn't really neccessary). I removed the roof of the bar to allow more light in.
Well, it's not working for me. Should it be named ".app" at the end? It isn't. Should I add that on? There's no icon, for the Mac version at least. Can't add it to the dock. When I double-click to open it, it opens in Terminal.
Quote - > Quote - LuxRender 1.2 has been officially released. Download it NOW!
http://www.luxrender.net/en_GB/standalone
Are you sure you got the Mac version? It's about halfway down the page under all the different Windows ones. It downloads a .dmg for me (but I'm on a PC so I can't actually try to run it).
Quote - > Quote - > Quote - LuxRender 1.2 has been officially released. Download it NOW!
OOps! OK That's probably it. Yep, that was it. Got the Mac version now. Sorry.
It depends it was a year ago I would say 2 to 3 hours on average the one with the girl overhead POV closer to 5 or 6 don't forget I am taking FULL advantage of queue render
I have had renders take as little as 10 & 15 mins. I posted something on my evolution of render times & material tweaking while you were absent..
It certainly rolled out better than the Daz crashomatic technique...
