Tue, Jan 21, 2:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Anyone know of a script that puts the selected object in front of the active cam
Zanzo ( ) posted Sun, 14 April 2013 at 7:19 PM · edited Mon, 06 January 2025 at 10:56 PM
Anyone know of a script that puts the selected object in front of the active camera?
I hate adding a prop then having to look for it. Do you guys know a clever way to put the item you add directly in front of you?
I'm thinking a script. Before I write it, I was hoping someone else already did it.
LaurieA ( ) posted Sun, 14 April 2013 at 7:22 PM
[o] little button at the top of the scene window.
DeathMetalDesk ( ) posted Sun, 14 April 2013 at 7:51 PM · edited Sun, 14 April 2013 at 7:59 PM
Point at selected in hierarchy too convoluted? Although, I must admit that laurie's cryptic response had me looking around for a little undocumented button for a second (and jeez will I be embarrassed if there is one). No keyboard short cut for point at though... unless they added a "Pro" one ;)
Edit_ ahhh, nevermind he wants to put the object in front of the camera rather than have the camera point at the object. Hmmm, that's a good one. An objects origin is at zero xyz when it loads even if those coordinates aren't matching the zero coordinates of the poser work space. I think, stumped on this one.
LaurieA ( ) posted Sun, 14 April 2013 at 7:53 PM
It's looks like brackets with a ball in it. LOL
Maybe it is just in pro. I have no idea but I do have pro.
AlanaDale ( ) posted Sun, 14 April 2013 at 8:04 PM
the shortcut for "frame selected" is ctrl shift =
it's also on display menu
DeathMetalDesk ( ) posted Sun, 14 April 2013 at 8:04 PM · edited Sun, 14 April 2013 at 8:09 PM
"Edit_ ahhh, nevermind he wants to put the object in front of the camera rather than have the camera point at the object. Hmmm, that's a good one. An objects origin is at zero xyz when it loads even if those coordinates aren't matching the zero coordinates of the poser work space. I think, stumped on this one."
Yeah, it's not the traditional point at anyway... They must have added the little ball with brackets in Pro, Laurie. I'm not seeing it.
_ solved, Poser 9 feature.
Zanzo ( ) posted Sun, 14 April 2013 at 8:08 PM · edited Sun, 14 April 2013 at 8:08 PM
Quote - [o] little button at the top of the scene window.
That moves camera to focus on the selected object. I want the opposite effect.  Basically whereever my camera is pointed, I want the prop to end up somewhere in front of the camera.
Instead of moving the camera, it moves the object in front of the camera.
LaurieA ( ) posted Sun, 14 April 2013 at 8:11 PM
Quote - > Quote - [o] little button at the top of the scene window.
You're out of luck then. LOL
DeathMetalDesk ( ) posted Sun, 14 April 2013 at 8:12 PM · edited Sun, 14 April 2013 at 8:18 PM
Python script "snap to" by Ockham, moves selected object to clicked location. Not sure if it's Poser 9/pro usable though...
http://ockhamsbungalow.com/Python/
Results are variable.
