Point at selected in hierarchy too convoluted? Although, I must admit that laurie's cryptic response had me looking around for a little undocumented button for a second (and jeez will I be embarrassed if there is one). No keyboard short cut for point at though... unless they added a "Pro" one ;)
Edit_ ahhh, nevermind he wants to put the object in front of the camera rather than have the camera point at the object. Hmmm, that's a good one. An objects origin is at zero xyz when it loads even if those coordinates aren't matching the zero coordinates of the poser work space. I think, stumped on this one.
"Edit_ ahhh, nevermind he wants to put the object in front of the camera rather than have the camera point at the object. Hmmm, that's a good one. An objects origin is at zero xyz when it loads even if those coordinates aren't matching the zero coordinates of the poser work space. I think, stumped on this one."
Yeah, it's not the traditional point at anyway... They must have added the little ball with brackets in Pro, Laurie. I'm not seeing it.
_ solved, Poser 9 feature.
Quote - [o] little button at the top of the scene window.
That moves camera to focus on the selected object. I want the opposite effect. Basically whereever my camera is pointed, I want the prop to end up somewhere in front of the camera.
Instead of moving the camera, it moves the object in front of the camera.
Quote - > Quote - [o] little button at the top of the scene window.
You're out of luck then. LOL
Anyone know of a script that puts the selected object in front of the active camera?
I hate adding a prop then having to look for it. Do you guys know a clever way to put the item you add directly in front of you?
I'm thinking a script. Before I write it, I was hoping someone else already did it.
