Mon, Jan 20, 12:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Nightmares in Dynamics & Rigging
3DFineries ( ) posted Mon, 20 May 2013 at 11:23 AM · edited Mon, 20 January 2025 at 11:44 AM
It's a complete & total nightmare...............
I'm just having too many problems getting this stuff to play nice.  I built a dynamic dress, but when I do I drape, this is the result.  The mesh crinkles where it should smooth out & lay flat.
Then I try to rig it instead with the V4 Dev Suit & that causes even more nightmares.  I fixed the broken mesh issue, but now when she's posed I get major poke thru.  Dare I mention that when I rig it as a hybrid outfit, the abdomen doesn't drape & it needs to drape.  :(
Any suggestions to fix the dynamics & rigging of this outfit?
Have a creative day!
My Lil' Store
cedarwolf ( ) posted Mon, 20 May 2013 at 11:58 AM
Good questions.  I seem to have those same problems.
ghostman ( ) posted Mon, 20 May 2013 at 12:01 PM
On the rigged clothing! Have you tried to magnetize the clothing to V4?
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
3DFineries ( ) posted Mon, 20 May 2013 at 12:17 PM · edited Mon, 20 May 2013 at 12:18 PM
Ghostman,
That is magnitized. :ohmy:  It's the Default V4 too.
My Lil' Store
ghostman ( ) posted Mon, 20 May 2013 at 12:34 PM
Quote - Ghostman,
Have you added the jcm's from V4 as well? D3D's Morphing Clothes is great for that
3DFineries ( ) posted Mon, 20 May 2013 at 12:35 PM · edited Mon, 20 May 2013 at 12:49 PM
Uh, no.  I just bought MC a couple of days ago.
Edited:  I didn't work.
My Lil' Store
ghostman ( ) posted Mon, 20 May 2013 at 1:32 PM
Guess you'll just have to tweak the rigging then. I'm not that good at this yet. Sorry. :(
3DFineries ( ) posted Mon, 20 May 2013 at 1:49 PM
I think so.  Not sure where the problem is though....  I'm not that good at it yet either-lol.
My Lil' Store
rokket ( ) posted Mon, 20 May 2013 at 2:31 PM · edited Mon, 20 May 2013 at 2:32 PM
What program did you use to model this dress?
In the dynamic pic it looks like there are some vertices that is not assigned to a material group. It is causing the mesh to bunch up because it's not moving with the rest of it. I'd go back into my modeling program and look for isolated verts and either connect them to the mesh or delete them if they are not needed.
In the rigged dress, you have to adjust the joint centers on the chest, collars and shoulders.
rokket ( ) posted Mon, 20 May 2013 at 2:46 PM
Sorry, I just noticed you said you fixed the issue with the mesh..
I don't have V4, so I can't really give you a specific fix on the rig, but I would look at the joint centers on the above mentioned parts.
Also the hybrid might be causing a problem. Perhaps give it a standard rig and use the morph brush to make the abdomen do what you want it to do?
3DFineries ( ) posted Mon, 20 May 2013 at 2:46 PM
Quote - What program did you use to model this dress?
I used Hexagon.  I started playing with some settings & it seems to be the dynamic settings that are sticking on 'squaring' it off.  scratches head  I've already looked for isolated verts & made sure groups were right, but will double check.
Ah!  The joint centers... that might explain it.  Was adjusting spherical zones thinking that might be the problem, but that just mushed it up more.  Will fiddle with the centers.
My Lil' Store
rokket ( ) posted Mon, 20 May 2013 at 3:47 PM
Quote - > Quote - What program did you use to model this dress?
Spherical zones set limits on which part of the mesh is affected by the bone. Adjusting the joint center will affect where it comes to rest when you conform it. If that makes sense. I am fairly new at rigging myself, but I catch on pretty quick.
Be glad it's not weight mapped. Whole other ball game there. I am working on rigging a Halo style armor for Miki 4 right now. I have a fairly good grasp of standard Poser rigging, but weight mapping is giving me fits.
I also learned how to edit a cr2 today. I have effectively burned several brain cells, and in order to keep this information in my fried out brain, I had to let go of several childhood memories! :lol:
rokket ( ) posted Mon, 20 May 2013 at 3:55 PM
Check out this tutorial. It's rigging from scratch, and since you just transferred V4's rig, you can skip parts of it, but it explains about everything.
Good luck!
http://poser.smithmicro.com/tutorials/Characters_rigging.html
rokket ( ) posted Mon, 20 May 2013 at 4:00 PM
One thing about editing the joint parameters: Don't use the main or aux camera. You want to use front, right, left and top. The main and aux camera are perspective view and you will not be able to align the bones or change the centers properly in those camera views.
icprncss2 ( ) posted Tue, 21 May 2013 at 8:05 AM
Is the dress meant to be fully dynamic or a hybrid?
Full dynamics are basically props.  Make sure you don't have duplicate verts and all are welded.
Hybrid clothing is more difficult.  You still need to make sure there are no duplicates and proper welds.  Also look at the skeleton to make sure there aren't and bones below the hip.  What does the bunched mesh look like in wire frame?
3DFineries ( ) posted Tue, 21 May 2013 at 10:33 AM
The dress was modeled as a dynamic outfit.  Everything is done except the dynamic settings aren't playing nice.  I've checked & double checked it.  When I change the dynamic control settings, it looks fine.  There are no breaks in the mesh that I can find.  There are also no bones below the hip in the rigged version.
I'm to the point where I'm ready to remodel the dress so that the breasts don't become exposed when it drapes & it adds some modern versatility to it.  The only reason I was thinking of rigging it was to cover the breasts more, but I just can't get the rig to work & I dislike the way it drapes when rigged as a hybrid so that only leaves me to remodel it, retexture the one piece, & use transmaps for the Egyptian designs to give it the illusion of a completely open front.
My Lil' Store
rokket ( ) posted Tue, 21 May 2013 at 11:37 AM
Can you post a lit wireframe of your mesh without V4 in the scene? Especially a closeup of the area that is pinching....
or,
if you want, you could email me the .obj file and I could take a look at it. I'll PM you my email if you want to go that route.
3DFineries ( ) posted Tue, 21 May 2013 at 1:34 PM
I fiddled with the dynamic settings & all drapes nicely with the modified model.  Rigging it was something I really didn't want to do in the first place.
It was pinching at the hip with the sharp bend.  Here's a wireframe snapshot of it with the new dynamic settings.
My Lil' Store
rokket ( ) posted Tue, 21 May 2013 at 2:14 PM · edited Tue, 21 May 2013 at 2:15 PM
Looks a lot better.
How many drape frames did you use? Sometimes that can help it lay more natural against the body when you run the sim.
