Sun, Sep 22, 10:25 PM CDT
DAZ|Studio F.A.Q (Last Updated: 2024 Sep 22 4:53 pm)
Subject: Daz Studio 4.6.18 will not run
dogor ( ) posted Sat, 08 June 2013 at 11:34 AM · edited Sun, 22 September 2024 at 10:22 PM
Installed Daz Studio 4.6.18 but when I try to run the program I get error 0xc000007b.
This was also the case with DS4.0.
Earlier versions 3 and lower have loaded and run, maybe not solid in every event, but they ran.
Anyone know why the 4.0 versions give me that error message?
Thanks,
DazShawnDonaldson79 ( ) posted Sat, 08 June 2013 at 12:51 PM
I'm not sure, but I think that was the same error I got when I bought the Look at My Hair plug-in.  In my case it turned out to be my video drivers:  my update software said they were current, but they weren't.  I had to manually download and install updates from Dell.
dogor ( ) posted Sat, 08 June 2013 at 8:13 PM · edited Sat, 08 June 2013 at 8:14 PM
I have a NVidia Geforce GT 240 graphics card.
The driver did need updating even though Windows said it was up to date, but after updating to the latest driver, complete with a restart I still got the same error 0xc000007b.
It was a good idea anyways that I hadn't done yet.
SickenlySweete ( ) posted Sun, 09 June 2013 at 12:04 AM · edited Sun, 09 June 2013 at 12:06 AM
clean the registrary
update:
graphics card driver
are you using 32bit or 64?
if you install the wrong one you will get this error
also check for an update on the visual c+
and the open gl
this problem is discussed at daz
http://www.daz3d.com/forums/viewthread/14562/P270/#277542
www.bloodyrosesdesigns.com
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
SickenlySweete ( ) posted Sun, 09 June 2013 at 12:12 AM
found one solution that may work
Run the proper for your version of Windows, Vcrun2010 package…
http://www.microsoft.com/en-us/download/details.aspx?id=5555 (32 bit)
http://www.microsoft.com/en-us/download/details.aspx?id=14632 (64 bit) < the one you want…
dogor ( ) posted Sun, 09 June 2013 at 2:00 AM · edited Sun, 09 June 2013 at 2:01 AM
This is another thread at Daz forums to keep you up to date on what I've already done.
This thing is being a bugger to fix. I've been working on it for hours and hours to get it to work already. Right now it's still broken.
www.daz3d.com/forums/viewthread/23389/
dogor ( ) posted Sun, 09 June 2013 at 12:22 PM
I'm throwing in the towel on Daz Studio.
I tried to get it working. I cannot.
dogor ( ) posted Tue, 11 June 2013 at 2:25 AM
Got Daz Studio to work.
Gave Administrator full permission
Gave Trusted Installer full permission
in program files (x86) where I installed DS4.6,,,, after I took ownership first.
For some reason I can't paste links through firefox on this forum or I'd post a link showing you how to own the files in Windows 7.
If you want the link go to the Daz forum link I manually typed in on an earlier post and look at my last post there. Easy instruction on how to do it there.
The problem Windows file permissions.
Anglofdrknss ( ) posted Tue, 25 June 2013 at 12:27 PM
I hope I am in the right place. I need to know specs on a graphics card that will open the latest DAZ Studio. My Tech is having difficulties and I can't find anything anywhere that might help. I am reading also, that I need to have my system set on high performance, make sure I have permission to open the program,(he set it so anyone can use the computer), and the latest visual C++ which I had done before I took it back after getting an error message that that I need at least an Open GL of 1.3 which he upgraded to a 2.0. He also  took out the ATI card and put in a new NVidea and I just talked with him and he said it still would not open. Never have had such a time with this program opening before.
ANY help is so appreciated! Thank you!!
RHaseltine ( ) posted Tue, 25 June 2013 at 2:51 PM
If your system has a video chipset in the processor then you made need to make sure that DS is getting the nVidia card and not the processor video.
Anglofdrknss ( ) posted Tue, 25 June 2013 at 3:17 PM
Thank you , I am going to call my tech and suggest that to him to see if he can open the program.
Anglofdrknss ( ) posted Tue, 25 June 2013 at 3:32 PM
Back again. I called my Tech and he wants to know if you might talk with him so he can get this right for me. I said I would give you his  number here in Iowa or perhaps you can give me a number so he can call you back?  He told me that the new card would override the one in the processor so he doesn't quite understand. I let him know you are one of the staff.
His name is Zach Knorr from Computer Heaven in Cedar Rapids, IA.
319-294-3177 work hours  9 a.m. to 4 p.m.
my email is magenta@southslope.net if you don't wish to give out info here, or send me a message here.
He is really trying to fix my pc so I can continue to use DazStudio. Thank you!
RHaseltine ( ) posted Wed, 26 June 2013 at 2:19 PM
Since I am in the UK that would be a pricey call, and I don't in any event have the experience of working with dual-chip systems so my knowledge is purely theoretical. If he's confident that the right card is being used. There was, recently, a problem with the tool that was meant to switch the chipset in use which was causing the DAZ Bitrock installers to crash, even on systems that didn't really have two active adaptors. There is some discussion of the issue here and on the immediately preceding pages http://www.daz3d.com/forums/viewreply/322772/
Anglofdrknss ( ) posted Wed, 26 June 2013 at 3:11 PM
Thank you for the reply. I am reading it has something to do with the Bitrock installer that may be causing the problem with my machine. Can't find a workaround or I just don't understand how to help my Tech fix it. Will make notes and give him a call.
Yes calling from the states to England would take up some major pocket money.
jestmart ( ) posted Wed, 26 June 2013 at 5:50 PM
What was the exact specs of your computer before the tech started to mess with it?
Anglofdrknss ( ) posted Wed, 26 June 2013 at 7:01 PM
jestmart, I have had a whole new rebuild and it's still in the shop. He put in a new processor, two hard drives with 2T each since I clone/ghost and Windows 7, 64 bit. I talked with him and he is putting back in the new nVidia card which I don't know the exact specs. The old one was ATI, 1.1 and when I tried to open DAZ Studio the popup read I needed at least 1.3.  Something is not clicking right as that was the second card he put in.
Since programs that I use are upgrading I needed a faster processor , more RAM which he gave me, and then of course a brand new card.
jestmart ( ) posted Wed, 26 June 2013 at 8:09 PM
Tell him to put in any current budget AMD card with atleast 1GB of memory.  Everyone is saying how nVidia has better OpenGL and yet most of the people reporting problems with Studio have nVidia.
Anglofdrknss ( ) posted Thu, 27 June 2013 at 6:27 AM
Thank you, I will let him know this.
jestmart ( ) posted Thu, 27 June 2013 at 10:59 AM
I probably should have said, 'Have him TEST an AMD budget card", as any good computer tech is likely have few spare parts kicking around.  Don't let him charge you for one first in case it doesn't work.
Anglofdrknss ( ) posted Thu, 27 June 2013 at 3:50 PM
Here is what is in my machine. Radeon X800 XT with 3064 MB memory
Display is in 32 bit mode, don't understand that as I am running 64 bit Windows.
Just loaded my new poser pro and had no problems. Tried to open DAZ Studio again and I get the same error message that the graphics card isn't good enough.
Somewhere I have something off. Right now I am burned out.
jestmart ( ) posted Thu, 27 June 2013 at 6:07 PM
it is not 32 bit mode it is 32 bit color depth.
http://www.howstuffworks.com/monitor4.htm
The first thing to try is open device manager, locate the display device and do a check for updated drivers.
Anglofdrknss ( ) posted Fri, 28 June 2013 at 8:14 AM
Found the device manager, thank goodness for Google, and both vid card and monitor are up to date. I am using an LG  standard monitor, system32.
