Fri, Jan 10, 3:36 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 09 11:38 pm)
Subject: Having Issue with animation with some crash and error report!
alfhak712 ( ) posted Sun, 16 June 2013 at 12:38 AM · edited Sun, 24 November 2024 at 9:25 PM
I run Windows 7 64bit OS! DAS Studio Pro 4.5! Then rendering all images and doing animation it crash and want me to send an error report to DAZ. I have used 4 distance light with no raytrace shadows on! The movie is only 5 seconds long! I try to render only a second at each time! 25 frames about!
The help I need is to find another application for making all rendered images into a movie! I can render all images separately and then make the movie!
I have tried Corel Video Studio Pro but the problem with that is: It is not possible to set speed of each image to 1/30 of a second so you end up with 30 frames/second movie! You end up with a slide show instead! The other issue is you can only edit one frame at the time to lower the time!
I have no idea if I can import images to Blender and then use Blender to make the final movie!
If you know a application that solve my problem I will be very happy!
Alf
animajikgraphics ( ) posted Sun, 16 June 2013 at 12:57 AM
Quote - movie! If you know a application that solve my problem I will be very happy!
Alf
Try VirtualDub (Windows App) - http://www.virtualdub.org/download.html
This free app will do what you're looking for.
I personally, use AE to convert image sequences into .mov files, but VirtualDub is a cheaper solution (free).
-AniMajik
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
alfhak712 ( ) posted Sun, 16 June 2013 at 1:57 AM · edited Sun, 16 June 2013 at 2:00 AM
Thanks!
I checked the page and it also say you need lots of memory! 16GB
I only have 6Gb atm! Does that cause any issue?
Win 7 64 bit OS
Intel Core i7 CPU 920 2.67GHZ
Alf
Hiro.P ( ) posted Sun, 16 June 2013 at 6:37 AM
Yes you can use Blender to put together the final movie. You should be rendering to still images and put the images together in comp. That way, if it crashes, you don't loose everything, and also, if you change something you only need to rerender the changed portion. Almost always render to stills then composite.
erzebeth ( ) posted Sun, 16 June 2013 at 10:46 AM
your ram memory is the problem, I´m sure
ldgilman ( ) posted Sun, 16 June 2013 at 11:15 AM
Quote - your ram memory is the problem, I´m sure
I agree, If you can, add an additional 2 gig. Also if you are using 5400 RPM hard drive(s) try using a 7200 RPM drive. One other thing you can try is to increase the size of your swap drive (space on hard drive used as memory).
alfhak712 ( ) posted Sun, 16 June 2013 at 12:37 PM
Thanks for your reply!
I am using disks running at 10 000 RPM and I guess it is possible
to have 12GB of RAM too!
Alf
RHaseltine ( ) posted Sun, 16 June 2013 at 2:27 PM
If, as you said in your DAZ forum thread, you are using the 32 bit version of DS then extra RAM won't help - using the 64 bit version of DS will.
alfhak712 ( ) posted Sun, 16 June 2013 at 3:08 PM
I running both version of DAZ,  32 bit for animation and 64 bit for images!
The reason for this is I can't get the codec for animation to work with 64 bit version! Even if I have download extra codec that should work!
Alf
erzebeth ( ) posted Sun, 16 June 2013 at 7:07 PM
even with 64 bits the ram upgrade is essencial. you can download free software to turn turbo your computer, this can help. try "tune up utilities"
Hiro.P ( ) posted Sun, 16 June 2013 at 11:24 PM
You shouldn't be rendering animation that's the problem... render to images and composite it. Rendering directly to animation should only be done for very short (5 second) animations for more reasons then I care to go into.
alfhak712 ( ) posted Mon, 17 June 2013 at 12:44 PM · edited Mon, 17 June 2013 at 12:45 PM
Thanks for all good advice and tips!
Today I got reply from DAZ about my Error Report! I need to uninstall DAZ and get the newest version first and also try to get more RAM. Also a note of that I will run out of memory on 32 bit version when trying to render large/complex scenes. So a 64 bit version only and latest version of DAZ.
Render to images sounds like a better idea and now I think I got an idea how to put them together into a movie with Corel Studio Pro I use! I got some tip about how to do it and then some trying and error until I got it to work with not spending to much time!
I found a way to select all images and then copy them to clip board. After install all images in a sequence from my folder I could hightlight all of them in Corel by holding down CTRL+ALT key and then mouse click there the images was placed! Then all selected drag them down to clip board!
Also on clip board I select the first high-lighted the first image then press shift key down and then select the last images for the movie! That they all get selected and then I could edit the time for each frame to be shown! So all 150 images was edited at the same time! This way I did not know was possible to do but it save lots of time instead of working with one frame at the time! The movie is just 5 seconds long and it end up almost the same in Corel and also looks ok!
Here is the movie!
http://www.youtube.com/watch?v=kmraCHElEoQ
Alf
Hiro.P ( ) posted Mon, 17 June 2013 at 5:43 PM
Very nice for a first animation :)
alfhak712 ( ) posted Tue, 18 June 2013 at 3:55 AM
Thank you Hiro!
I did a small mistake doing the animation! Both cars coming from the left driving to the right, stop at the same time but have different start position! If you look careful you will see the second car closing in to the car in front! I should have make the stop position furhter away for the first car! This is the first animation that I manage to get the lightning ok and also have a distance light acting as sun! So some nice shadows on the street and even from the passing cars!
Alf
