Sat, Feb 1, 7:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 7:14 pm)
Subject: Angora?
mamba-negra ( ) posted Tue, 23 July 2013 at 9:16 PM · edited Sat, 01 February 2025 at 7:53 PM
I have a render where I'm using a sweater and I was wondering if anyone has any ideas for creating an angora type textures.
angora
I did try adding dynamic hair, but it didn't work so well, nor did displacement. I'm guessing hair is the way, but it will have to be VERY dense. Any other alternatives out there?
RorrKonn ( ) posted Tue, 23 July 2013 at 11:47 PM · edited Tue, 23 July 2013 at 11:48 PM
with any app or using multiple app's
only 3 ways I know of getting it.
Paint it in a 2D app
Dynamic hair
Make it like they make conforming hair
ashley9803 ( ) posted Wed, 24 July 2013 at 1:57 AM
Here's an example of a commercial product - it can obviously be done.
Don't know how to make dynamic hair stuff like this - sorry.
But I'm sure someone here will help.
dphoadley ( ) posted Wed, 24 July 2013 at 5:01 AM
Try adding the Noise node modifyer to the bump slot in the materials, and then experimet with the strength
ashley9803 ( ) posted Wed, 24 July 2013 at 5:51 AM
I honestly don't think that bump/dispalcement will ever achieve a fine long fur/hair effect like the OP wants. But ther's no problem with trying it.
dphoadley ( ) posted Wed, 24 July 2013 at 6:31 AM
It's an easy way to create grass on the groundplane, and with a bit of postwork blur will be A LOT easier than struggling with dynamic hair!  Also a lot easier on resorce and render demand!
parkdalegardener ( ) posted Wed, 24 July 2013 at 6:32 AM
Hair room all the way. This might be a bit dense. More like fur but you get the idea. This what you want?
pdg
mamba-negra ( ) posted Wed, 24 July 2013 at 8:24 AM
pdg, that is very close. Can you show me the settings you used for it?
Also, is there a way to add hair to the entire sweater or does it always create a prop for each body part that bends with the thing it is "grown" on.
Does that take forever to render, compared with what it normally would?
RorrKonn ( ) posted Wed, 24 July 2013 at 10:35 AM
parkdalegardener : That looks good
mamba-negra : You can select what polygons get hair.
Just like your render settings ,Dynamics setting will determine your render times.
Can take a little longer or a lot longer.
mamba-negra ( ) posted Wed, 24 July 2013 at 10:50 AM
I've been playing, but so far, it's a pretty big mess. I need to spend more time with the manual and practicing on a sphere before I'll get anything useful.
One thing I've noticed is that, at least on the sphere, the follicles seem to favor a single direction. So, on one side of the sphere they will naturally wilt, but on the other, they seem to start upward before gravity takes effect. I realize that is related to the root stiffness, but I don't understand why it doesn't start off perpendicular to the tangent. Is it just a shortcut that Poser uses that happens to sometimes have a direction that is baked in on the lean of the root, or is there another setting I'm not using properly?
RedPhantom ( ) posted Wed, 24 July 2013 at 8:26 PM
Site Admin
You can't make hair groups span body parts. You will have to make at least one for each group or convert the shirt to dynamic, although I don't know how that would look with hair on it. I recomend using multiple groups then you can have the hair go in different directions using the the growth control. Or,if you are a glutton for punishment, you can have those set all the direction dials to zero and then use the styling tool to make them go in the dircetion you want. Also watch for faces on the inside of the sweater (sometimes added to give depth) don't select those.
RedPhantom ( ) posted Wed, 24 July 2013 at 9:51 PM
Site Admin
Is this something like what you are looking for? I've never actually seen angora (at least not that I know of) I can't tell is it that furry?
rokket ( ) posted Wed, 24 July 2013 at 9:56 PM
Figuring out how to make this work would go a long way towards making that Black Cat suit that was asked for in another thread.
I could do the whole suit, minus that part of it.
mamba-negra ( ) posted Wed, 24 July 2013 at 10:20 PM
Red Phantom, that looks about right. Your hairs are probably a good bit coarse, but for poser, I would say it's would do splindedly.
Angora is actually made from fur from a special kind of rabbit. So, it is fur, it's just not like the fur coats or other types of fur that we think of. I believe it's woven into a fabric.
RedPhantom ( ) posted Thu, 25 July 2013 at 7:07 AM · edited Thu, 25 July 2013 at 7:08 AM
Site Admin
The hair or rather fur in this case can be made alot finer. I've got another render queued up and will post it when I can. Here are the settings I used but with the finer strands. In my sample I used .2 and .4 respectivly for the tip and root width. There was no use of the styling tool or any draping. Also keep in mind dynamic hair likes higher render settings, something I didn't do in my sample. Usually I use 10 pixel samples or more and .10 min shade rate.
RedPhantom ( ) posted Thu, 25 July 2013 at 12:36 PM
Site Admin
Ok here is a sample with the settings above
parkdalegardener ( ) posted Fri, 26 July 2013 at 7:10 AM
Sorry, I haven't been getting notifications for this thread.
RedPhantom seems to have you well in hand. A few thoughts....
The render time can soar to almost unrealistic lenghts if you leave "emitter" on for the hair.
The mesh density has a direct effect on growing the hair so you may need to change settings across body parts if the mesh density changes so that you can keep an even look across the entire prop. The lower the mesh density, the better the hair looks. IMHO
For patterned hair like a leopard or zebra print you can plug the texture into the hair node both root and tip instead of the blonde shader that is there by default.
Hair does grow perpendicular to the polygon.  Image included.
Don't try growing hair on a dynamic object. You will be long dead by the time the calculations finish.
RorrKonn ( ) posted Fri, 26 July 2013 at 9:31 AM · edited Fri, 26 July 2013 at 9:38 AM
Quote - For patterned hair like a leopard or zebra print you can plug the texture into the hair node both root and tip instead of the blonde shader that is there by default.
Could we burn a leopard or zebra texture on to a dynamic hair that's converted into .obj conforming hair ?
for faster render times .
RedPhantom ( ) posted Fri, 26 July 2013 at 10:18 AM
Site Admin
RorrKonn, do you know of a way to conver the hair? Most attempts that I have heard of, if they work at all, cause such a high poly count the computers can't handle it. But if there is a usable way, I'd love to be able to do it.
parkdalegardener ( ) posted Fri, 26 July 2013 at 5:20 PM
Conversion to a reasonable object is something I have yet to see done. The hair node can be uv mapped along the P node but Fibre Mesh hair out of zBrush but be a better option. I don't have zBrush so I cannot say for sure.
Regarding hair on a dynamic cloth. I did a tiger skin throw for a chair to demo the process on another board using Poser's hi res square. The results were fantastic. The render took 27 hours.
pdg
RorrKonn ( ) posted Fri, 26 July 2013 at 10:54 PM
Ya could export n import hair in sections/parts.
Might help to leave in box,wireframe in Poser.
C4D can hide meshes till render time.
more or less ,LW raises n lowers the polycount depending on how close it is to the camera.
When Poser 5 got dynamic hair was the last time I messed with Poser dynamic hair.
since mamba-negra angora swetter is soild pink & Pro 14 has a brush.
thought converting the dynamic hair to conforming might be feasible
I know I know I shouldn't be thinking ;)
I messed a very little with zBrush fiber/hair.
It's cool for zBrush but don't know about exporting it for another 3D app or Poser.
Don't know if ya could re topology fiber for game meshes.
I need to try that.
If ya could just have a shader on dynamic hair where the shader would have the hairs with random colors.
so every hair is no the exsact same color would be a lot closer to conforming hair.
Can Pro 14 dynamic hair have shaders ?
