DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Hey Sharky, I have Elena also and her lips are fairly easy to correct. Set a low specular color in the grey range (35-41 I find useful) and enable the topcoat for pink/flesh, around .19 to .25. Glossy to 7500-8000 and she's off and away!
crimsonworx.com; free ebooks and previews
I've bowed down to facebook: https://www.facebook.com/crimsonworx
Quote - Cool beans looks like a vid game you have a french last name..
Thank you and that I do! Crazy cajun I am =D
Hey SBT, exciting trailer.
Thank you very much for the credits!
Good luck with the project.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+:
https://plus.google.com/106625816153304163119
The
Reality Gallery: https://reality-plug-in.deviantart.com
Much appreciated Paolo and John!
Next step, whoring and pleading for money. Not my strong suit, but here goes! =D
Add: I have one more little piece I wanted to add in but didn't quite make it in the previous vid. I'll wedge it into the youtube version in a day or so where full resolution can be enjoyed! That transcoding degeneration... Guh!
Sorry Bob, can't help you there. I'm not familiar with the setup.
Paolo
Tw: @preta3d
G+:
The
Hi, I have lux reality for Daz. It has always done a great job but in the last week it's crashing when I try to use it. Anyone else having these problems?
Kimberly
3D Artist Network by Imaginative 3D: Where the “i” in “imaginative” stands for the individual” 3D artists showing off their creative designs.
Try to remembe what you has changed in the last few days. Software doesn't change how it works for no reason.
Paolo
Tw: @preta3d
G+:
The
Attached Link: http://bobvan.deviantart.com/art/85-389019882
Good to see you got it fixed, or post-worked it away ;-)
Couldn't get back to you sooner, my router has been on the blink. Grrr....
One guess might be that a transmap either got overwritten or replaced. I've been saving my shaders for the big project for each prop/set/character in a separate folder and noticed that it only saves one copy of the settings if the prop or even a texture map is repeated when I saved the whole shader set in one folder. It's merely a guess though!
By the by Paolo, I'm not sure where it is happening, but I think it's the 'save scene' command in Reality that will save duplicate Reality Data nodes to the scene in Studio. I was having shader issues on one run and went to "show hidden nodes" in studio and found 9 copies of Reality Data. Could be a Studio fluke too, as its so crash-happy that I save constantly.
SBT, there is really no need to use the Save scene buttons anymore. They were added to overcome some limitations of Studio 3. The scene data is saved in the Studio scene automatically.
Cheers.
Paolo
Tw: @preta3d
G+:
The
Quote - > Quote - SBT, there is really no need to use the Save scene buttons anymore. They were added to overcome some limitations of Studio 3. The scene data is saved in the Studio scene automatically.
Cheers.
Thats good to know
Ditto! Studio crashed on me sooooo many times during 'production' that I got closer and closer to adopting Poser without a second thought. Just had to finish it and think about moving operations to PP2014 or even Blender. Anyway... sigh
Truth be told Bob, I looked at Luxus ever so briefly and can honestly say that I'm sticking with Reality as it still has the most faithful translations of Studio to Lux materials. From what I've seen with Luxus, it has Lux's lights and Studio's shaders in terms of looks and appearance. Not all that impressive IMO. I've really grown comfortable with Paolo's UI that working with Lux inside of Studio would be that much more annoying.
Edit reply to STB I agree this was in moments of frutration with all the merging issues. I dont think one should need to rebuild the scene from scratch everytime but it seems in this case for example its the only thing that would of fixed the issue, which is why I just put another pair of hose on the character..
Believe me Bob, I know your frustration! I would fully reccomend, if you use the same roster of characters fairly often, setting up shader folders for them. Highlight each clothing item separately (I group by clicking on the Owner tab in the materials window), click on the first desired to that piece, hold down left control and either drag down or click individually all related surfaces. In the shader box on the far right of Reality, there's a drop down box where it says Shader Operations or something similar. Click on that with your desired selections highlighted, click Save Shaders or whatever it says (the first option), which will open a directory window, probably to Roaming Data for Reality or Studio in Windows.
I set mine up in my Documents folder for wherever the main project is and make a character folder, for instance, Sandman Lux Shaders, then create folders for his skin textures, any clothing items in one folder, shoes/boots, props, weapons, etc etc. Each folder gets the highlighted shader settings for its individual aspects and nothing gets overwritten if you choose another character with the same prop which has a different diffuse color or glossy setting. It's a bit of set-up the first time, but man oh man does it come in handy. Just make sure you go through all the tabs to make sure the trans, bump/normal maps are correct, and I like to remove all displacement maps if possible.
Next time you load that character and the settings are mucked up, highlight the same, click the shaders operation box and select Load Shaders in the drop down box. Find your folder ('Recent Files' is a blessing!) and voila! Bing bang boom.
ACSEL does the same thing, but (and this may be incorrect) I've noticed that if someone else saves it to the directory, you get their settings. I spend hours setting up scenes sometimes, shader-wise, and sometimes use the same texture maps on different characters with differnt morphs, etc. The folder option is a nice back-up to keep everything the way I prefer that character's doo-dads.
Just an option Bob.
No prob. Glad it worked for ya!
There's still whacky stuff going on like I put a human character's shader in a file and the feline in another the feline shader takes over the human character even if I re apply the human's shader settings. I was able to fix it by applying re load Studio MAT on the human figure and once more re adjusted everything.... On the plus side it was a time saver since I could apply all the same seetings to all feline creature still one or 2 had to be manually adjusted. Even thoug it works it is also flawed...
Ladies and Gents, it's been approved!! Now live:
http://www.kickstarter.com/projects/621725049/mechanation-goes-to-the-movies
I would be eternally grateful if you could help spread the word! Lots of cool swag to be had :-)
That's all you'll hear from me, I promise!
Quote - Ladies and Gents, it's been approved!! Now live:
Is this your project?
Quote - > Quote - Ladies and Gents, it's been approved!! Now live:
The big daddy, it is!
For those living overseas, I'm working on rectifying the 'Shipping to US only' issue and may end up shipping everything myself rather than directly from the manufacturer as previously decided. I'll add a Project Update when everything gets ironed out.
Ok I am going to post this cause it may help someone else. Don't know if it makes sense. Seems that LIE tff files are at the root of some of my problems. 1st time I saved the shaders aka settings for my main character using LIE makeup without textures. Then I got all whacky textures loading on wrong characters that was fixed by reloading Studio MATS & re applying the "shaders" i then saved my main character's "shader" settings including textures and now everything loads properly. Confusing stuff keedz....
When I use LIE, once I've applied the preset, I browse in the Diffuse channel to the temp directory where the tif file is, select, right-click and copy it, then browse to e.g. the texture directory created by Reality for the render, right-click and paste. Next time DS and Reality starts, it's loaded from the new location.
Attached Link: http://bobvan.deviantart.com/art/92-389676618
Ho yeah and a torture render muhahahahah
Very nice John. I woul love to have those swords.
Paolo
Tw: @preta3d
G+:
The
Attached Link: http://bobvan.deviantart.com/art/108-390382304
Attached Link: http://bobvan.deviantart.com/art/111-390382274
All right, here is a radical proposal.
If you look at the summary of this thread it has almost 8200 posts. Think about it. If you were a new Reality user would you tackle a thread that has 8200 posts? I wouldn't. This is scary stuff. Nobody can read that many posts. It's a nightmare.
I would like to continue to have a place here at Renderosity where people can post renders and discuss Reality ideas.
What do you say if we stop this thread and we start a new one?
It will be the same but without the intimidation factor.
Shall we?
Paolo
Tw: @preta3d
G+:
The
Quote - All right, here is a radical proposal.
Shall we?
As long as we get a link im in
It will be just another thread in the Renderosity forums. I will post the thread here but I'm gonna ask the moderators to lock this thread at some point.
Cheers.
Paolo
Tw: @preta3d
G+:
The
Thanks. I'm still working on it. I'm adding another image for the Studio version.
Cheers.
Paolo
Tw: @preta3d
G+:
The
Ladies and Gents, I have a special announcement: the trailer is finished!!
Here's a sneak peek, right at the top:
http://www.kickstarter.com/projects/621725049/830135945?token=ad12d229
The project is not yet live, but here's to hoping they don't can in!
