Sat, Nov 23, 2:06 PM CST
Subject: STL format or DXF
Dmurphy ( ) posted Fri, 18 October 2013 at 7:13 PM · edited Sat, 23 November 2024 at 1:41 PM
Can Poser save a scene as a STL or DXF file. No animation just a static scene.
If no can a Poser scene be saved and imported to another program like Blender or Meshlab and saved as an STL or DXF.
Thank You
Don
seachnasaigh ( ) posted Fri, 18 October 2013 at 7:42 PM · edited Fri, 18 October 2013 at 7:50 PM
Poser can export geometry as DXF.
Joe@HFG ( ) posted Fri, 18 October 2013 at 7:44 PM
It's still going to require a TON of clean up if you intend to 3D print it.
mo·nop·o·ly  [muh-nop-uh-lee]
noun, plural mo·nop·o·lies.
1. exclusive control of a commodity or service in a particular market,
or a control that makes possible the manipulation of prices
seachnasaigh ( ) posted Fri, 18 October 2013 at 7:51 PM
No, Joe, he's using a CNC to carve bas-relief in wood.
seachnasaigh ( ) posted Fri, 18 October 2013 at 7:53 PM · edited Fri, 18 October 2013 at 8:01 PM
Silo geometry export formats:
STL included!
seachnasaigh ( ) posted Fri, 18 October 2013 at 7:55 PM
modo geometry export formats:
seachnasaigh ( ) posted Fri, 18 October 2013 at 8:18 PM · edited Fri, 18 October 2013 at 8:18 PM
Clarification for casual forum readers:  no mesh work needed if he can use the DXF;  while the bas-relief type of work would not inherently require topological closure nor triangulation, the .stl (STereoLithography) format will insist.  This the format commonly used by rapid prototypers and 3D printers.
seachnasaigh ( ) posted Fri, 18 October 2013 at 8:26 PM
Don, it is trivial for Poser to output a DXF (although it takes a while for Poser to do the format conversion).  I know how to prepare a mesh for STL, and my favorite modeler program Silo can export it, but Poser models are not even close to being suitable for STL as-is.  It would take a lot of time & work to re-work all the geometry in a complex Poser scene to meet STL standards.
Dmurphy ( ) posted Fri, 18 October 2013 at 10:02 PM
Ok I am sill looking for an easy and quick way to o this.
Don
seachnasaigh ( ) posted Fri, 18 October 2013 at 10:31 PM
I'd also have to build new models if you need an STL or DXF, because I can't send you geometry which was built by someone else (copyright issue).
Dmurphy ( ) posted Fri, 18 October 2013 at 11:01 PM
I did not think of that. What if the model is part of the complete scene. The STL format is not a real 3-D format. Can you do the same scene we are working on and use 8 shades of gray with no black.
seachnasaigh ( ) posted Sat, 19 October 2013 at 12:02 AM
Quote - Can you do the same scene we are working on and use 8 shades of gray with no black.
Hmmm...  I think so.  I'll give it a shot.
