Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 8:40 pm)
It's still going to require a TON of clean up if you intend to 3D print it.
mo·nop·o·ly [muh-nop-uh-lee]
noun, plural mo·nop·o·lies.
1. exclusive control of a commodity or service in a particular market,
or a control that makes possible the manipulation of prices
Clarification for casual forum readers: no mesh work needed if he can use the DXF; while the bas-relief type of work would not inherently require topological closure nor triangulation, the .stl (STereoLithography) format will insist. This the format commonly used by rapid prototypers and 3D printers.
OSes: Win7Prox64, Win7Ultx64
Don, it is trivial for Poser to output a DXF (although it takes a while for Poser to do the format conversion). I know how to prepare a mesh for STL, and my favorite modeler program Silo can export it, but Poser models are not even close to being suitable for STL as-is. It would take a lot of time & work to re-work all the geometry in a complex Poser scene to meet STL standards.
I'd also have to build new models if you need an STL or DXF, because I can't send you geometry which was built by someone else (copyright issue).
Quote - Can you do the same scene we are working on and use 8 shades of gray with no black.
Hmmm... I think so. I'll give it a shot.
Can Poser save a scene as a STL or DXF file. No animation just a static scene.
If no can a Poser scene be saved and imported to another program like Blender or Meshlab and saved as an STL or DXF.
Thank You
Don
