Sat, Feb 1, 4:41 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 31 8:48 pm)
Subject: please look at image some problem
atpo ( ) posted Tue, 03 December 2013 at 5:12 AM · edited Tue, 21 January 2025 at 2:17 PM
here genesis5,hair is genesis4's.
but no bump or displacement with body.
i use bump image RGB:40,40,40,and the same with displacement
and change bump min and max  or displacement max and min,and no fruit.
what is the right bump or displacement image RGB?
and here specular's color is low red and the same as ambient.is it right?
and i change subsurface is also that color,is it right?
what is velvet?
Razor42 ( ) posted Tue, 03 December 2013 at 5:34 AM
Hmm firstly i'm nt sure how appropriate your image is for the forums i expect A moderator may pop in and remove it.
Are you using a grayscale image for your bump maps? Generally the color value should left at white. Height and depth is added by variation in the greyscale image map with white being high and black being low.
specular relates to the shiness of an object
ambient should be black unless the item is glowing...
i suggest it might be worth looking at the quickstart and user guide for daz studio there is a sticky at the top of the forum.
atpo ( ) posted Tue, 03 December 2013 at 5:47 AM
yes i use grayscale RGB with photoshop
But what is left at white,height and depth is added by variation...
if use image to demostration is good.
I also have read user guide ,because somewhere is no understand.
atpo ( ) posted Tue, 03 December 2013 at 5:49 AM
and that image just for explain
Razor42 ( ) posted Tue, 03 December 2013 at 5:55 AM
I see, maybe have a look at this link it will give you some background on bump maps
http://www.mat.ucsb.edu/594cm/2010/adams_rp1/index.html
Some more map specific info more directly about Daz Studio.
http://docs.daz3d.com/doku.php/artzone/pub/tutorials/textures/misc-text56
hopefully these will get you on the right track.
atpo ( ) posted Tue, 03 December 2013 at 6:15 AM
thanks MR razor have a nice day ,and i have a nice sleep.
