DAZ|Studio F.A.Q (Last Updated: 2025 Jan 21 5:37 am)
Hmm firstly i'm nt sure how appropriate your image is for the forums i expect A moderator may pop in and remove it.
Are you using a grayscale image for your bump maps? Generally the color value should left at white. Height and depth is added by variation in the greyscale image map with white being high and black being low.
specular relates to the shiness of an object
ambient should be black unless the item is glowing...
i suggest it might be worth looking at the quickstart and user guide for daz studio there is a sticky at the top of the forum.
I see, maybe have a look at this link it will give you some background on bump maps
http://www.mat.ucsb.edu/594cm/2010/adams_rp1/index.html
Some more map specific info more directly about Daz Studio.
http://docs.daz3d.com/doku.php/artzone/pub/tutorials/textures/misc-text56
hopefully these will get you on the right track.
but no bump or displacement with body.
i use bump image RGB:40,40,40,and the same with displacement
and change bump min and max or displacement max and min,and no fruit.
what is the right bump or displacement image RGB?
and here specular's color is low red and the same as ambient.is it right?
and i change subsurface is also that color,is it right?
what is velvet?
