Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Thanks everyone. I got some good tips over at DZ forum. This model (bar lounge) uses bones throughout (god knows why for four walls, a ceiling, floor and some lights). This somehow ties the objects together and seems to confuse this light function. I am going to play around some more, but for the time being I just used a spot light with 90 degree angle placed at the bottom of the light fixture to get the effect I wanted.
Someone suggested I just need to uncheck casts shadow for the light fixture object, will try that just out of curiousity.
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
Quote - Strange, it is working well for me in 8.1, 8.5 (prerelease) and 8.5 v243.
Are you running Mac or PC?
Mark - I use a PC (didn't you see my sig?)
Quote - Mark - I use a PC (didn't you see my sig?)
Yes, after I posted. Apparently because I can't read and comprehend at the same time.
Remember, I'll buy you a boubon the next time you're in Denver.
Mark:
Could be a while - my entire Denver team defected to a competitor and I closed our office in the DTC. If I do get there (spending more time in FL and AZ these days) I'll give you an advance heads up. Would love to collect that Bourbon.
Klebnor
BTW, sig is weak sarcasm.
Frohe Weinachten!
Klebnor
I find today that using the “all objects except” selector with a bulb no longer works. I have tried in both C 8.0 and 8.5 and get the same effect. If I put a light inside an object and add the object to the exception list, the light is obscured by the object. Additionally, if the bulb is outside the object, and I select “all objects except” and add the object, it is still lit by the light.
Anyone else find this issue? Is there a fix or work around?
Thanks,
Klebnor
