Sat, Feb 8, 11:28 PM CST
Subject: Poser Pro 2014 locks up computer when I render in main window
shadowhawk2zero ( ) posted Thu, 19 December 2013 at 9:25 AM · edited Sat, 08 February 2025 at 10:25 PM
Hi All,
OK I do not know if this is a Poser issue, a SR update issue or what but I have got a problem with Poser Pro 2014 locking up when I render in the main window, but I can render in the background without a problem. When I render in the main window it locks up my whole computer and everything on my computers begins to flash preventing me from shutting anything down which then forces me to to do a hard shutdown of my computer because I can't close anything down. This has been going on for about 6 months now and I can't think of any updates that I have done that would have created this issues.
I am running a ASUS G74 i7 with win7 and 16gb of memory. I have the Navidia GTX560 video card. This has gotten to be very frustrating and to be honest it has prevented me from doing a lot of art recently because of this.
If anyone has a suggestion or idea I would be forever greatful.
V/R
Roy
vilters ( ) posted Thu, 19 December 2013 at 9:32 AM
For starters it would be handy if you posted a screengrab of your render settings.
shadowhawk2zero ( ) posted Thu, 19 December 2013 at 9:37 AM · edited Thu, 19 December 2013 at 9:38 AM
Quote - For starters it would be handy if you posted a screengrab of your render settings.
It doesn't matter what the render setting are it does it. I can get two or three renders and then it starts. Every program I have open will begin to flash and then I am forced to do a hard shutdown.
ETA: I will post my render setting when I get to the room I am at work right now so I can't do a screenshot right now.
Teyon ( ) posted Thu, 19 December 2013 at 9:37 AM
Do you have render as a separate process checked in your preferences?
shadowhawk2zero ( ) posted Thu, 19 December 2013 at 9:41 AM
Quote - Do you have render as a separate process checked in your preferences?
Not sure if I do or not since I am not on my personal computer at the moment, do you know if this is the default setting? If so then I do as I haven't changed any of those settings.
basicwiz ( ) posted Thu, 19 December 2013 at 2:42 PM
Quote - > Quote - Do you have render as a separate process checked in your preferences?
No. It is not the default setting. You have to go in and check the "Separate Process" box located under Edit>General Preferences>Render.
shadowhawk2zero ( ) posted Thu, 19 December 2013 at 2:49 PM
Quote - > Quote - > Quote - Do you have render as a separate process checked in your preferences?
OK I have checked it now but I wil have to wait until tomorrow to try it out as it is close to midnight here and I need to get to bed. I will post my render settings and how my test goes tomorrow
ironsoul ( ) posted Thu, 19 December 2013 at 4:12 PM
If the computer is hanging and won't respond to the keyboard it suggests a low level problem like display driver or system board/disk area rather than a Poser issue. As the background renders are ok it doesn't sound like a heat/power problem so prehaps the graphics card ? - first thought is OpenGL, if you use it for preview and haven't tried SreeD mode it might be worth a quick go.
vilters ( ) posted Thu, 19 December 2013 at 4:15 PM
Yes, try to upgrade your display drivers first.
shadowhawk2zero ( ) posted Thu, 19 December 2013 at 4:19 PM
Quote - Yes, try to upgrade your display drivers first.
I have th enewest driver update for my Nvidia video card. I updated it just the other day.
FightingWolf ( ) posted Thu, 19 December 2013 at 6:17 PM
Do you have any other programs running at the same time?
Have you tried to use to option to render the program in the background?
Are you clicking on something else while Poser is trying to render?
shadowhawk2zero ( ) posted Thu, 19 December 2013 at 9:09 PM
Quote - Do you have any other programs running at the same time?
It happens both ways. When programs are running in the back ground and when I run just poser and nothng else. Am I clicking on something in Poser or somewhere else, not sure what you mean by the last question. Prior to this starting I could start Poser and do something else in Photoshop or surf the web but I haven't tried to start Poser rendering and then not touch anything at all that is just crazy to not be able to do something else while Poser is rendering.
FightingWolf ( ) posted Fri, 20 December 2013 at 1:31 AM
Quote - Prior to this starting I could start Poser and do something else in Photoshop or surf the web but I haven't tried to start Poser rendering and then not touch anything at all that is just crazy to not be able to do something else while Poser is rendering.
See if you get the same issues when you don't do anything else while Poser is rendering.
The reason I say this is not to be a solution but to have an idea if this is caused by using other programs while rendering or if this is something else.
I have had similar experiences where Poser appears to freeze for a bit an at the top of it a message saying "not responding" pops  up.  When I see that message come up then I stop doing what I was doing for bit so that the computer can sort itself out.  It's usually like a 5 or 10 second pause and I can only assume that what I was doing at the time of rendering cause a conflict somewhere.   It doesn't happen often but when it does I just take a small break.  However I don't get this issue when I tell Poser to render in the background.
I was thinking that this may be the case with what is happening with you, but you really won't know unless you let Poser render without doing anything else on the computer.  If it still hangs when you don't do anything then you can be 90% sure that it's not because you were using another software.
shadowhawk2zero ( ) posted Fri, 20 December 2013 at 2:21 AM
Quote - > Quote - Prior to this starting I could start Poser and do something else in Photoshop or surf the web but I haven't tried to start Poser rendering and then not touch anything at all that is just crazy to not be able to do something else while Poser is rendering.
OK I know what you are refering to and I get that from time to time as well. It is not that, this actually causes poser and every other program running at the time to lock up and starts to flash on the screen every 10 to 15 seconds and causes my CPU to max out locking up my whole system.
ironsoul ( ) posted Fri, 20 December 2013 at 3:00 AM
Bit of a fishing trip, have you..
Checked the event logs to see what (if any) error messages are displayed
Run dxdiag and clicked on each to screen (No problem found should be displayed in Notes)
Configured Poser to use only one thread for Rendering (incase this is a problem with your CPU)
If your PC comes with any stress software have you ran this since the problem started. This should go through all your components and memory.
Revert you video driver to the version running before the problem started.
One thought is trying to reproduce the problem in safe mode but I don't know if there are any risks in doing so. The reason to do this is it removes all third party drivers from your OS in one easy step - done at your own risk, I not saying you can/should do this but its an idea to consider.
shadowhawk2zero ( ) posted Fri, 20 December 2013 at 6:55 AM
Quote - Bit of a fishing trip, have you..
OK this may sound wierd but where do I find the events log and the dxdiag. I have PC mechanic and have run checks on all the systems so not sure if that is the same. I will change from 8 to a single thread to see what happens.
I have had 3 or 4 updates since this started so to be sure the only option I have is to take it back to the factory new settings that came whenthe laptop was new. I haven't tried to run it in safe mode yet I guess I could always give that a try.
ironsoul ( ) posted Fri, 20 December 2013 at 11:52 AM
If you had a PC mechanic look at the PC I would expect them to do these kind of checks so maybe this is a repeat of what they did.
To run dxdiag, click on the start button. In the field right at the bottom of the menu enter dxdiag and hit return. You should get the DirectX Diagnostic tooks, just click through the tabs at the top and check the Notes field, should say no problems found
To see system event logs click on the start button, In the field right at the bottom of the menu enter eventvwr.msc and hit return. It should have in left pane "Windows Logs". Open that and two logs to be interested in are Application and System. Double click on these and scan back to the time of the last freeze. Any Errors list at the time of the freeze might contain a useful hint to the problem, see more info by double-clicking on the error. Your favourite Internet search will be useful to  translate the errors into something more meaningful.
martial ( ) posted Fri, 20 December 2013 at 7:05 PM
In the render preferences , try to put the number of thread to 8
I have meet the same problem during the past with a system look like your
and someone in this forum suggest this and my problem was solved
And now with my new system i set the same parameter to 8 also
shadowhawk2zero ( ) posted Sun, 05 January 2014 at 12:39 AM
My threads are set at 8 by default, and I have updated all of drivers and have the newest SR3 update. I haven't had this many issues with Poser since Poser 8. I kind of wish I hadn't deleted my copy of Poser Pro 2012 when I was cleaning out my hard drive.
vilters ( ) posted Sun, 05 January 2014 at 3:58 AM
OK, here another "wild" shot.
Do you have a light set to raytrace shadows? AND is there a dynamic hair in the scene?
Unfortunately this combination leads to Poser "hangs" at the end of the render.
shadowhawk2zero ( ) posted Sun, 05 January 2014 at 4:55 AM
Quote - OK, here another "wild" shot.
I do use raytrace shadows quite a bit but I have never used a dynamic hair before. Almost all of the times Poser will lock my system up before it gets to the render pass, about 2/3 of the time it will happen before it gets to the render pass.
