DAZ|Studio F.A.Q (Last Updated: 2025 Feb 06 11:16 pm)
BUT
I then go to "pose" and inj base and morphs..But it's just the base options in the parameter.. The morphs +++ don't apply to her??
I think it's frustrating to work with this program:-( To inj the morphs is the easiest thing I do in Poser.. After struggling sooo much with DS 4.6 I don't ever think I will use sooo many hours to get my new V4 work inside DS..
This is one of the reason that make a vendor don't make a character to work inside DS but just Poser i think:-(
If you have V4 set up ad working for Poser then it would be simplest just to point DAZ Studio to the same external library and share the files - right-click on Poser Formats in the last screenshot, then select Add runtime Directory, and select the folder that contains the actual "Runtiem" folder as you do when adding a location to Poser.
![file_500759.jpg](https://live.cdn.renderosity.com/forum/threads/2876898/file_500759.jpg)
I still struggle with DazStudio 4.6:-)I have installed V 4.2 and the morph pack.. I see the paths are ok, but can't see V4.2 base in there??
I have used install manager to install V4 so it should be right??
See picture.. All the paths are ok, but don't find V 4.2 base??
Marina
