Thu, Jan 23, 7:25 AM CST
Subject: Removing body parts from a Pose file
Darkworld ( ) posted Thu, 20 March 2014 at 7:04 PM · edited Thu, 23 January 2025 at 7:20 AM
I don't have a lot of time to dig for this so thought i'd ask my peers!  I need to open already existing pose files and DELETE body parts from them, in other words if I want only the abdomen to pose and/or morph, is there some quick utility i can crack open to delete chest/arms/body channel etc?  I know i can do this text editing but that takes a long time.
Thanks!
ThunderStone ( ) posted Thu, 20 March 2014 at 9:12 PM
How about using the hierarchy editor to turn off the part that you don't want?
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
ElZagna ( ) posted Thu, 20 March 2014 at 11:47 PM
How about using Les Bentley's Lock Actor script? With that you can lock everything then unlock the abdomen.
ThunderStone, how can you "turn off" parts in the Hierarchy Editor?
OS: Windows 10 64-bit, Poser: 10
Darkworld ( ) posted Fri, 21 March 2014 at 12:28 AM · edited Fri, 21 March 2014 at 12:32 AM
uh no, you can't disable hierarchies to change a pose file.  not in Pro 2012 anyway
Quote - How about using Les Bentley's Lock Actor script? With that you can lock everything then unlock the abdomen.
Locking the parts doesn't help me, they still write to the pose file.
Darkworld ( ) posted Fri, 21 March 2014 at 1:23 AM
Saved!  by "Save Subset" the little button i've never even noticed.  When you save a pose file that button is on the dialogue box
grichter ( ) posted Fri, 21 March 2014 at 6:41 AM
Look under your scripts menu under partners and see if you have the netherworks PoseWriter Panel that has come with the last couple of versions of Poser. It allows you to save off just selected body parts, and has check boxes to select just Tranlsations, Rotations, Morphs or Scales or any comb of those 4 you want. I use it all the time to do what I think you are wanting to do.
Gary
hborre ( ) posted Fri, 21 March 2014 at 8:46 AM
The question is actually 2-fold, yes, you can save subsets of body parts for posing, both default and morphed.  You will need to pose the part first before saving.  Now, if you intend to create target morphs for body parts, you will need to zero the figure first, select the body part and export it as an obj file to be modified in a modeling program.
arrow1 ( ) posted Fri, 21 March 2014 at 5:21 PM
Does the "Lock Actor" work for M4 as well? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
grichter ( ) posted Fri, 21 March 2014 at 9:18 PM
Quote - Does the "Lock Actor" work for M4 as well? Cheers
The lock actor works on all actor parts of any figure, so yes it works on M4
Gary
arrow1 ( ) posted Fri, 21 March 2014 at 9:30 PM
Many thanks.Cheers
ElZagna ( ) posted Fri, 21 March 2014 at 10:33 PM
As long as the actor names are the same, then yes. For example the code for the All_Locked pose goes like this:
actor BODY
    locked 1
actor hip
    locked 1
actor abdomen
    locked 1
AnAardvark ( ) posted Mon, 24 March 2014 at 1:08 PM
You can also just edit the pose file.
