Tue, Jan 14, 9:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Subject: What render dimensions do you all use?
crystalmethodcaf ( ) posted Fri, 27 June 2014 at 8:52 AM · edited Tue, 14 January 2025 at 9:16 PM
Hi all!  I've been playing with Poser for a while and I love the software.  I'm just curious what render dimensions you all typically use?  I know obviously the higher the better, but for the kinds of renders I do, I'm wondering if using render dimenstions of 1920x1080 (for example) is really worthwhile.  I typically just view them on my computer monitor, sometimes (rarely) on my 50" TV.
I know that if it's only, say, a 1024x768 resolution for example and I zoom in, it'll become grainy.  But if my monitor is at a 1600x1200 resolution, and I'm viewing a pic rendered with a 1920x1440 resolution, then all those extra pixels aren't needed from what I understand.
For an example, if I'm rendering a picture of a person with a tree in the background, would there be that drastic of a difference if I rendered it at 1200x900 instead of 1920x1440?  On the other hand, if I was rendering a scene with several people walking in the background in front of a store, then would I be correct in assuming that if the same picture is viewed at the same resolution (let's just say 1024x768 [I don't really use this res, just saying]), but one is rendered at 1920x1440 and the other at 1280x960, there will be a noticeable difference in the detail of the two pics?
I know how the resolutions affect TV and blu-ray viewing, I'm just not sure how much of that translates into the world of graphic design.  Thanks for reading!
MistyLaraCarrara ( ) posted Fri, 27 June 2014 at 9:01 AM · edited Fri, 27 June 2014 at 9:05 AM
for wallpaper i render at 1920x1080
i size my preview window at 960x540 when i'm at camera framng stage (rule of thirds), then render to exact size 1920x1080
Poser lets you set dpi, great feature, if you're selling prints on DA or Zazzle or similar, you'll need their pixel specs. Rendering book covers for create space needs 300dpi. book covers you usually need to add .25 inch to edges for full bleed space
RedPhantom ( ) posted Fri, 27 June 2014 at 9:52 AM
Site Admin Online Now!
My default resolution is 771x652. I know that is very strange. It fits my workspace and allows me to see the whole scene when rendered. I don't normally print my renders or use them for wall  paper or really anything but dust collectors on my hard drive so the odd dimentions don't really matter. When I am printing, I do use a much bigger size.
infinity10 ( ) posted Fri, 27 June 2014 at 10:03 AM
480 (W) x 640 (H) - because it fits into my visual novel otome game format
Eternal Hobbyist
false1 ( ) posted Fri, 27 June 2014 at 10:47 AM
I render my final images rather large in the 1800 X 2700 range for potential inkjet printing. I may never print it but you can always downsize an image whereas you can't upsize it later. Images I put on the web are generally 900px on the largest side. Big enough to see but not so large it can be printed out without my permission.
________________________________
My DeviantArt Gallery
My Website
Netherworks ( ) posted Fri, 27 June 2014 at 10:56 AM
600x600 for faster renders.  1200x1200 for other output.  I'm such a square.
DarkEdge ( ) posted Fri, 27 June 2014 at 11:33 AM
Finals are usually 2500x1406
shvrdavid ( ) posted Fri, 27 June 2014 at 11:46 AM
For me, it usually depends on what it is for.
The highest resolution monitor I have is 3840x2160**, **but I do not always render at that size. For animations I sometimes do the final output size, and sometimes render them twice as large then run all the frames thru filters and then size them down.
aRtBee ( ) posted Fri, 27 June 2014 at 1:27 PM
for final print, 7000x5000
for final wallpaper, 2560x1280
for final web gallery, 1280x1024
bigger is not better. Matching the purpose is best.
hornet3d ( ) posted Fri, 27 June 2014 at 1:47 PM
I usually render at 2500 X 1750 the reasoning here is that it generally renders fairly fast and I can scale up to 4961 X 3508 with very little loss in detail.  Seems odd but at 300dpi that is correct for ISO page size A3.  Most years I do an A3 photobook with the work from that year and a record of, hopefully, my progress.  With the monitor correctly calibrated the printed page looks good and it forms a nice record.
obm890 ( ) posted Fri, 27 June 2014 at 2:16 PM
4500x3200  - big enough for print but not so big as to make my photoshop files unmanageable (I usually have a million postwork layers which really bloats them).
Miss Nancy ( ) posted Fri, 27 June 2014 at 2:40 PM
poser limit = ~22K X 22K (in case anybody asks).
seachnasaigh ( ) posted Fri, 27 June 2014 at 2:50 PM
     Usually I render at wallpaper size, 1920x1200 for laptop, 2560x1600 for workstation, or occasionally double width 5120x1600 for laying across an extended desktop (two monitors).
     Sometimes for demo/test renders, I aim for a size suitable for posting in the forum.
     For animations, I generally use 720x480 (DVD widescreen) or 640x480 (DVD standard TV), but I may render smaller if the animation is especially processor-intensive or a lot of frames.
