Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 7:23 pm)
I'm pretty sure you probably just need a re-install if you haven't tried that yet. I'm running PP2014 on a Mac with only 2 gigs of memory. And mine works just fine. I'd kill for 16 gigs of memory. Anyway, try the re-install and see how that goes.
Also, make sure all your drivers and software is up to date.
Did you notice this line?
Quote - Graphics hardware encountered an error and was reset
Sometimes hardware drivers are released with bugs and the software blames the hardware when it's the software that is broken.
If you google search that phrase, you'll find it's not unique to Poser and it's not unique to you.
Anyway - can you disable GPU acceleration in Poser and/or osx and see if that helps?
I've only ever had one driver problem on my Mac interestingly enough, but that was a printer problem. The only problem I ever had with Poser was never enough memory, and that was around version 4. Then Apple allowed you to assign part of your hard drive to virtual memory and Poser perked up like a horse after a colonic.
Disabling OpenGL and activating SreeD seemed fix the issue. Thanks again to everyone.
Since everyone here seems far more MAC Savvy then me, maybe someone has a suggestion for another issue having with my V4 morphs. When I apply wither Morphs ++ or Elite to my V4 character, they don't take. I go tot he Parameters tab and none of the morph dials are visible.
Any suggestions are greatly appreciated!
Thanks
I recently loaded Poser 10 on a Macbook Pro. It installed successfully and I was able to start the program and load a character. However, the program locks up and crashes each time I click the Materials tab. I am brand new to Mac, but have been a casual Poser user for years. The Mac is Running Mavericks. It has an i7 processor an 16 GBs of RAM. Poser was installed from a disk and not a download. Below is a sample of output error I see. Any suggestions would be greatly appreciated.
Process: Poser 10 [379]
Path: /Applications/Poser 10/Poser 10.app/Contents/MacOS/Poser 10
Identifier: com.SmithMicro.Poser9
Version: 10.0.3.26066 (10.0.3.26066)
Code Type: X86 (Native)
Parent Process: launchd [154]
Responsible: Poser 10 [379]
User ID: 501
Date/Time: 2014-10-04 22:39:52.816 -0700
OS Version: Mac OS X 10.9.5 (13F34)
Report Version: 11
Anonymous UUID: 3A9CCB2B-154A-8F03-0466-ECFC571EE587
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
abort() called
Application Specific Signatures:
Graphics hardware encountered an error and was reset: 0x00000000
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x918e9952 __pthread_kill + 10
1 libsystem_pthread.dylib 0x95e8b167 pthread_kill + 101
2 libsystem_c.dylib 0x97ee329c abort + 155
3 libGPUSupportMercury.dylib 0x90101005 gpusKillClient + 137
4 libGPUSupportMercury.dylib 0x901024dc gpusSubmitDataBuffers + 454
5 com.apple.driver.AppleIntelHD5000GraphicsGLDriver 0x40349005 IntelCommandBuffer::getNew(GLDContextRec*) + 43
6 com.apple.driver.AppleIntelHD5000GraphicsGLDriver 0x40345386 GenContext::prepareCommandBuffer() + 32
7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver 0x40348e69 intelSubmitCommands + 216
8 com.apple.driver.AppleIntelHD5000GraphicsGLDriver 0x40356581 glrIntelBeginPrimitiveBuffer + 389
9 GLEngine 0x94c192c2 gleFlushPrimitiveTCLFunc + 726
10 GLEngine 0x94ba18ee glDrawElementArrayAPPLE_Exec + 857
11 libGL.dylib 0x97a33af8 glDrawElementArrayAPPLE + 45
12 MEngineUI.dylib 0x03925046 MUISceneDrawEngineGL::DrawQuads(int, unsigned int*, unsigned int*) + 278
13 MEngineBase.dylib 0x038b79f8 MESceneDrawEngine::DrawSortedElements(MEGeom*, MEMaterial*, MEMaterial*, MEScene*) + 2088
14 MEngineBase.dylib 0x038b657e MESceneDrawEngine::DrawScenePolys(MEScene*) + 670
15 MEngineUI.dylib 0x0395753e MUIShadowMapping::RenderShadowMap(MELight*, int) + 3886
16 MEngineUI.dylib 0x0391c037 MUISceneDrawEngineGL::UpdateShadowMaps() + 711
17 MEngineUI.dylib 0x0391bce3 MUISceneDrawEngineGL::ProcessSceneLights(MEScene*) + 4675
18 MEngineBase.dylib 0x038b5320 MESceneDrawEngine::DrawScene(MEScene*, float () [4]) + 464
19 MEngineBase.dylib 0x038b2fe1 MEScene::Draw(float () [4]) + 273
20 com.SmithMicro.Poser9 0x005d78e9 PUIWXViewCanvasGL::OnPaint(wxPaintEvent&) + 1417
21 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02967d3e wxAppConsoleBase::HandleEvent(wxEvtHandler*, void (wxEvtHandler::)(wxEvent&), wxEvent&) const + 42
22 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02967d81 wxAppConsoleBase::CallEventHandler(wxEvtHandler, wxEventFunctor&, wxEvent&) const + 59
23 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a4cb30 wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) + 106
24 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a50a95 wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 321
25 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a54bec 0x295f000 + 1006572
26 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a50b15 wxEvtHandler::ProcessEventLocally(wxEvent&) + 27
27 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a4fd8b wxEvtHandler::ProcessEvent(wxEvent&) + 177
28 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a4e24e wxEvtHandler::SafelyProcessEvent(wxEvent&) + 34
29 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02bf0549 wxWindowBase::HandleWindowEvent(wxEvent&) const + 27
30 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a7e226 wxWindow::MacDoRedraw(long) + 976
31 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02b24f1b wxWidgetCocoaImpl::drawRect(void*, NSView*, void*) + 601
32 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02b25c94 0x295f000 + 1862804
33 com.apple.AppKit 0x9b018298 -[NSView _drawRect:clip:] + 3816
34 com.apple.AppKit 0x9b016ccf -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1829
35 com.apple.AppKit 0x9b016ffc -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2642
36 com.apple.AppKit 0x9b016ffc -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2642
37 com.apple.AppKit 0x9b016ffc -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2642
38 com.apple.AppKit 0x9b016ffc -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2642
39 com.apple.AppKit 0x9b016ffc -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2642
40 com.apple.AppKit 0x9b016ffc -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2642
41 com.apple.AppKit 0x9b016ffc -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2642
42 com.apple.AppKit 0x9b015278 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 1264
43 com.apple.AppKit 0x9b0148f0 -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 290
44 com.apple.AppKit 0x9b011c57 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 3645
45 com.apple.AppKit 0x9afef72c -[NSView displayIfNeeded] + 1414
46 com.apple.AppKit 0x9b00d74c -[NSWindow displayIfNeeded] + 324
47 com.apple.AppKit 0x9b057365 _handleWindowNeedsDisplayOrLayoutOrUpdateConstraints + 1107
48 com.apple.AppKit 0x9b066459 -[NSWindow _delayedWindowDisplay:] + 24
49 com.apple.Foundation 0x95efba2b __NSFireTimer + 117
50 com.apple.CoreFoundation 0x9a8f5ea6 CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION + 22
51 com.apple.CoreFoundation 0x9a8f5863 __CFRunLoopDoTimer + 1395
52 com.apple.CoreFoundation 0x9a97006d __CFRunLoopDoTimers + 349
53 com.apple.CoreFoundation 0x9a8ad353 __CFRunLoopRun + 1779
54 com.apple.CoreFoundation 0x9a8ac9ea CFRunLoopRunSpecific + 394
55 com.apple.CoreFoundation 0x9a8ac84b CFRunLoopRunInMode + 123
56 com.apple.HIToolbox 0x94fc1b5d RunCurrentEventLoopInMode + 259
57 com.apple.HIToolbox 0x94fc1777 ReceiveNextEventCommon + 163
58 com.apple.HIToolbox 0x94fc16bd _BlockUntilNextEventMatchingListInModeWithFilter + 92
59 com.apple.AppKit 0x9aeb1349 _DPSNextEvent + 1602
60 com.apple.AppKit 0x9aeb0870 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
61 com.apple.AppKit 0x9aea315c -[NSApplication run] + 727
62 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02b0cc37 wxGUIEventLoop::DoRun() + 51
63 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02a2dcba wxCFEventLoop::Run() + 144
64 libwx_osx_cocoa-2.9.1.0.0.dylib 0x0296866b wxAppConsoleBase::MainLoop() + 157
65 libwx_osx_cocoa-2.9.1.0.0.dylib 0x02ab4516 wxApp::OnRun() + 30
66 libwx_osx_cocoa-2.9.1.0.0.dylib 0x029c579e wxEntry(int&, char**) + 110
67 com.SmithMicro.Poser9 0x003c24ad main + 429
68 com.SmithMicro.Poser9 0x000029b5 start + 53
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x918ea992 kevent64 + 10
1 libdispatch.dylib 0x97a03899 _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x97a03532 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x918ea046 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x95e8bdcf _pthread_wqthread + 372
2 libsystem_pthread.dylib 0x95e8fcce start_wqthread + 30
Thread 3:: JavaScriptCore::BlockFree
0 libsystem_kernel.dylib 0x918e97ca __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x95e8cd1d _pthread_cond_wait + 728
2 libsystem_pthread.dylib 0x95e8ebd9 pthread_cond_wait$UNIX2003 + 71
3 com.apple.JavaScriptCore 0x94007ae4 JSC::BlockAllocator::blockFreeingThreadMain() + 276
4 com.apple.JavaScriptCore 0x93ffee1c WTF::threadEntryPoint(void*) + 76
5 com.apple.JavaScriptCore 0x93ffedb0 WTF::wtfThreadEntryPoint(void*) + 16
6 libsystem_pthread.dylib 0x95e8a5fb _pthread_body + 144
7 libsystem_pthread.dylib 0x95e8a485 _pthread_start + 130
8 libsystem_pthread.dylib 0x95e8fcf2 thread_start + 34
Thread 4:: JavaScriptCore::Marking
3 com.apple.JavaScriptCore 0x940084eb JSC::GCThread::waitForNextPhase() + 123
4 com.apple.JavaScriptCore 0x94008378 JSC::GCThread::gcThreadMain() + 88
5 com.apple.JavaScriptCore 0x93ffee1c WTF::threadEntryPoint(void*) + 76
6 com.apple.JavaScriptCore 0x93ffedb0 WTF::wtfThreadEntryPoint(void*) + 16
7 libsystem_pthread.dylib 0x95e8a5fb _pthread_body + 144
8 libsystem_pthread.dylib 0x95e8a485 _pthread_start + 130
9 libsystem_pthread.dylib 0x95e8fcf2 thread_start + 34
Thread 5:: JavaScriptCore::Marking
Thread 6:: JavaScriptCore::Marking
Thread 7:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x918e9ace __select + 10
1 com.apple.CoreFoundation 0x9a8fdae6 __CFSocketManager + 1158
2 libsystem_pthread.dylib 0x95e8a5fb _pthread_body + 144
3 libsystem_pthread.dylib 0x95e8a485 _pthread_start + 130
4 libsystem_pthread.dylib 0x95e8fcf2 thread_start + 34
Thread 8:
3 com.SmithMicro.Poser9 0x004b929c PUIWXFLC_ScanFolderPopThread::DoRepeatedly() + 92
4 SMArtSkinBase.dylib 0x0357afbd sThreadStarter(void*) + 125
5 libsystem_pthread.dylib 0x95e8a5fb _pthread_body + 144
6 libsystem_pthread.dylib 0x95e8a485 _pthread_start + 130
7 libsystem_pthread.dylib 0x95e8fcf2 thread_start + 34
Thread 9:
1 libmongoose.dylib 0x02920a06 master_thread + 534
Thread 10:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x918e4f7a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x918e416c mach_msg + 68
2 com.apple.CoreFoundation 0x9a8adbf9 __CFRunLoopServiceMachPort + 169
3 com.apple.CoreFoundation 0x9a8ad1d1 __CFRunLoopRun + 1393
6 com.apple.Foundation 0x95efe355 +[NSURLConnection(Loader) _resourceLoadLoop:] + 381
7 com.apple.Foundation 0x95efe1ce -[NSThread main] + 45
8 com.apple.Foundation 0x95efe126 NSThread__main + 1426
9 libsystem_pthread.dylib 0x95e8a5fb _pthread_body + 144
10 libsystem_pthread.dylib 0x95e8a485 _pthread_start + 130
11 libsystem_pthread.dylib 0x95e8fcf2 thread_start + 34
Thread 11:
6 com.apple.AppKit 0x9b05ab88 _NSEventThread + 283
Thread 12:: BackgroundThread
3 com.macromedia.FlashPlayer-10.6.plugin 0x1a2a68ec 0x19f14000 + 3746028
4 com.macromedia.FlashPlayer-10.6.plugin 0x19f23553 0x19f14000 + 62803
5 com.macromedia.FlashPlayer-10.6.plugin 0x1a2a6713 0x19f14000 + 3745555
6 com.macromedia.FlashPlayer-10.6.plugin 0x1a2a674a 0x19f14000 + 3745610
7 com.macromedia.FlashPlayer-10.6.plugin 0x1a2a6495 0x19f14000 + 3744917
8 libsystem_pthread.dylib 0x95e8a5fb _pthread_body + 144
9 libsystem_pthread.dylib 0x95e8a485 _pthread_start + 130
10 libsystem_pthread.dylib 0x95e8fcf2 thread_start + 34
Thread 13:: BackgroundThread
Thread 14:: BackgroundThread
Thread 15:: BackgroundThread
Thread 16:: CVDisplayLink
1 libsystem_pthread.dylib 0x95e8cd8a _pthread_cond_wait + 837
2 libsystem_pthread.dylib 0x95e8d042 pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreVideo 0x9a3ee33d CVDisplayLink::waitUntil(unsigned long long) + 287
4 com.apple.CoreVideo 0x9a3ed42e CVDisplayLink::runIOThread() + 662
5 com.apple.CoreVideo 0x9a3ed180 startIOThread(void*) + 159
Thread 17:: ScriptTimeout
2 libsystem_pthread.dylib 0x95e8ec25 pthread_cond_timedwait$UNIX2003 + 71
3 com.macromedia.FlashPlayer-10.6.plugin 0x1a2a6963 0x19f14000 + 3746147
4 com.macromedia.FlashPlayer-10.6.plugin 0x1a0f405b 0x19f14000 + 1966171
Thread 18:: CoreLoop
4 com.macromedia.FlashPlayer-10.6.plugin 0x1a230274 0x19f14000 + 3261044
Thread 19:
3 com.SmithMicro.Poser9 0x009dfd62 IlmThread::Semaphore::wait() + 130
4 com.SmithMicro.Poser9 0x009df3e6 IlmThread::(anonymous namespace)::WorkerThread::run() + 54
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x05191800 ecx: 0xbfff945c edx: 0x918e9952
edi: 0xa07c11a8 esi: 0x00000006 ebp: 0xbfff9478 esp: 0xbfff945c
ss: 0x00000023 efl: 0x00200206 eip: 0x918e9952 cs: 0x0000000b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x0ba52000
Logical CPU: 0
Error Code: 0x00080148
Trap Number: 132
Binary Images:
0x1000 - 0xd35fff +com.SmithMicro.Poser9 (10.0.3.26066 - 10.0.3.26066) <4BAB602D-3222-36F7-BFDC-9C54A6B41DD2> /Applications/Poser 10/Poser 10.app/Contents/MacOS/Poser 10
0x171c000 - 0x185afff +org.python.python (2.7.2, [c] 2004-2011 Python Software Foundation. - 2.7.2) <AE3E09BC-9AEF-5EAD-14C3-4914DA14B965> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/Python
0x1908000 - 0x198ffff +BulletCollision (???) <04FC785B-A2C9-3445-8AC5-085D1097F366> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/BulletCollision.framework/Versions/2.79/BulletCollision
0x1a1b000 - 0x1a59ffb +BulletDynamics (???) <A9CD818D-AEF8-348F-9F0C-A4079166C9B9> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/BulletDynamics.framework/Versions/2.79/BulletDynamics
0x1a87000 - 0x1ab7ffb +BulletSoftBody (???) <42F56D83-D5D6-372A-9D3C-6143DB3128B0> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/BulletSoftBody.framework/Versions/2.79/BulletSoftBody
0x1add000 - 0x1af0ff7 +LinearMath (???) <26E5B3E1-7C77-3158-B6DD-BDD78C821D58> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/LinearMath.framework/Versions/2.79/LinearMath
0x1b00000 - 0x1b4bff5 +Clothlib.dylib (1) <13D6D378-6156-91FE-D53C-2AD2FEC156AE> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Clothlib.dylib
0x1b5c000 - 0x1c65ff3 +libfreeimage.dylib (1) <4E0B3AD1-61A9-3EDB-A528-29C0B127C69E> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/libfreeimage.dylib
0x1ce1000 - 0x226ffe3 +Cg (0) /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Cg.framework/Versions/1.0/Cg
0x291e000 - 0x292aff7 +libmongoose.dylib (1) <575E25E0-0885-3DF6-9377-51683129F03D> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/libmongoose.dylib
0x2932000 - 0x2951ffb +libexpat.dylib (1) <4B4948C9-A85A-3BDA-951D-68DC3F2DDF39> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/libexpat.dylib
0x295f000 - 0x328bfeb +libwx_osx_cocoa-2.9.1.0.0.dylib (1) <969BCBFA-FE09-378B-A9BA-E749F3EC9657> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/libwx_osx_cocoa-2.9.1.0.0.dylib
0x34ef000 - 0x34f9fff +libwx_osx_cocoa_gl-2.9.1.0.0.dylib (1) <7B60AD91-9565-350B-B658-A788459F1628> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/libwx_osx_cocoa_gl-2.9.1.0.0.dylib
0x3507000 - 0x37c1fff +SMArtSkinBase.dylib (1) <69D7F233-30D0-3FF8-8FBB-40C473B09A4A> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/SMArtSkinBase.dylib
0x3891000 - 0x38d9ff7 +MEngineBase.dylib (1) <47E3B720-B8C5-3BC7-847D-6DADEA4274FD> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/MEngineBase.dylib
0x3914000 - 0x3969ff7 +MEngineUI.dylib (1) <F5DA3865-FEED-3020-9B07-F133C1BAD5A1> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/MEngineUI.dylib
0x39aa000 - 0x3a89ff7 +SMArtSkinUI.dylib (1) <DDC3227A-B3EF-3963-BE14-4CB51426AAB8> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/SMArtSkinUI.dylib
0x3afa000 - 0x3b34ffb +libcurl.dylib (1) <736EBA98-A8A7-3EAA-908A-80D7ECDAC463> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/libcurl.dylib
0x3df6000 - 0x3df6ff7 +_bisect.so (???) <2A68A2E0-ED73-B5F2-143E-4B5E60B463F1> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_bisect.so
0xa935000 - 0xa938ff7 +operator.so (???) <E2DF234A-E945-8596-C007-FB5B4CC22CA9> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/operator.so
0xa940000 - 0xa941ff7 +_functools.so (???) <ADEA349C-F47A-1620-9A8C-0BB44D335983> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_functools.so
0xa947000 - 0xa948ff7 +_locale.so (???) <9AAA5A4A-C0EF-66E1-7D12-8EF081DD3700> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_locale.so
0xaa4e000 - 0xaa52ff7 +_dotblas.so (???) <513294CD-E38E-3745-A9DC-6B35EDED11FB> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/core/_dotblas.so
0xaa58000 - 0xaa59ff7 +cStringIO.so (???) <4C3BEA03-0FCB-FA7B-626F-56089D88B9F4> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/cStringIO.so
0xabc3000 - 0xabc4ff5 +cl_kernels (???) <5D30F9A5-7455-4C77-8760-65455949AB87> cl_kernels
0xabc6000 - 0xabc9ff3 +com.SmithMicro.poserplugin.FileFormatDXF (10.0.3.26066) <367EDD0C-C979-3866-AE83-8CE29D7F3E3F> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/FileFormatDXF.arp/Contents/MacOS/FileFormatDXF
0xabd2000 - 0xabd3fff +cl_kernels (???) <65D36793-7AF7-4B4F-BAA5-2D0435CCCADB> cl_kernels
0xabd5000 - 0xabdefff +com.smithmicro.P2-MPQuickTime (1.0 - 1) <004BEF1B-94E4-3733-B5BB-0ADB42E660A1> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/P2_MPQuickTime.pmp/Contents/MacOS/P2_MPQuickTime
0xabec000 - 0xabf6fff +com.SmithMicro.poserplugin.FileFormat3DS (10.0.3.26066) <63C45D3A-A15E-3E66-8EBD-1AAF8142BCD3> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/FileFormat3DS.arp/Contents/MacOS/FileFormat3DS
0xb659000 - 0xb744ff7 unorm8_bgra.dylib (2.3.58) <73AEEEF2-DF38-33F9-994C-2BB7A76EB027> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0xb770000 - 0xb77fffb +com.SmithMicro.poserplugin.FileFormatLWO (10.0.3.26066) <B71B809D-A457-3DEB-8997-AF9308243B9A> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/FileFormatLWO.arp/Contents/MacOS/FileFormatLWO
0xb78b000 - 0xb791ff7 +com.SmithMicro.poserplugin.FileFormatVRML (10.0.3.26066) <C9840C5A-A3DF-35B2-B299-DDD015A8575B> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/FileFormatVRML.arp/Contents/MacOS/FileFormatVRML
0xb799000 - 0xb7a2ff3 +com.SmithMicro.poserplugin.FileFormatWavefront (10.0.3.26066) <0492CF9E-680C-3EB3-9CF9-7AB54391E2AE> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/FileFormatWavefront.arp/Contents/MacOS/FileFormatWavefront
0xb7aa000 - 0xb7bfff3 +_sort.so (???) <4C506A08-6A40-38EF-9E77-7A82EDED9D8A> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/core/_sort.so
0xb7ca000 - 0xb7caff7 +grp.so (???) <835D2EE6-F3A1-C35B-1515-2D72A8365C69> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/grp.so
0xbdc9000 - 0xbdd7ff7 +cPickle.so (???) <D8C66E1A-7E30-6074-B210-AC4CA555399B> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/cPickle.so
0xbde1000 - 0xbde4ff7 +_collections.so (???) <8CE0A82F-FA19-545B-65DE-FA8442A7CF10> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_collections.so
0xbdeb000 - 0xbdecff7 +_heapq.so (???) <012FB207-F23A-C6E0-FCEE-55A0DC6B2A5A> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_heapq.so
0xc5fb000 - 0xc617ffc +scalarmath.so (???) <12A0E374-4A28-3748-B620-8F9BE439F457> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/core/scalarmath.so
0xce3b000 - 0xce3eff7 +strop.so (???) <88E63641-5779-421C-FE9C-FD41691ABBFC> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/strop.so
0xd145000 - 0xd14aff7 +itertools.so (???) <D9D50FE1-0A87-CCD6-2C60-9EA6B4D56696> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/itertools.so
0xd155000 - 0xd156ff7 +time.so (???) <0451B73B-98C9-3F24-D9B2-FAA5F42753B1> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/time.so
0xd15d000 - 0xd161ff7 +math.so (???) <376C16E7-9682-1934-9477-9E18DA2CE594> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/math.so
0xd169000 - 0xd16cff7 +_compiled_base.so (???) <8FA00CC6-E392-301D-8B51-175333A0718C> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/lib/_compiled_base.so
0xd172000 - 0xd175ff3 +lapack_lite.so (???) <60589E04-8CB8-355D-8636-751C48BEE0F7> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/linalg/lapack_lite.so
0xd1c5000 - 0xd1ccff7 +fftpack_lite.so (???) <77C7188F-CD25-3BEF-A113-0EF5EC060DBD> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/fft/fftpack_lite.so
0xd1d2000 - 0xd1e4ffb +_ctypes.so (???) <7BABB7D7-48F3-4F6C-C15C-0932D456E1DB> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_ctypes.so
0xd1f5000 - 0xd1f8ff7 +_struct.so (???) <DF86B56B-4E06-7865-5F3F-B2F324FB2A42> /Applications/Poser 10/Poser 10.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_struct.so
0xd445000 - 0xd481ffa +umath.so (???) <50C4BC90-7830-306D-8910-915029A2183C> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/core/umath.so
0xd505000 - 0xd533ff4 +mtrand.so (???) <DB24F75D-961E-3452-9A03-2A014E8157C8> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/random/mtrand.so
0xd805000 - 0xd95bff3 +core.so (???) <E7774532-33DB-3907-9794-E4A67004D539> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa/wx/core.so
0xd9f8000 - 0xdae4ffb +gdi.so (???) <F0AE6D26-2C34-32B5-9D93-E6E21877904D> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa/wx/gdi.so
0xdb54000 - 0xdc29ff7 +windows.so (???) <8B3D470B-28D5-3CB9-B4BA-EC1183D97F2C> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa/wx/windows.so
0xdcab000 - 0xddcdffb +controls.so (???) <5FC1BBBF-5AC4-369A-8118-E87D0E57FCA4> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa/wx/controls.so
0xde5f000 - 0xdf3eff7 +misc.so (???) <4938257B-B814-3E85-82B3-034C9A80650D> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa/wx/misc.so
0xdfb0000 - 0xe06eff9 +multiarray.so (???) <A806D8D8-666A-31BA-AC12-616F5E1470B1> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/numpy/core/multiarray.so
0xe3c0000 - 0xe463fff +_stc.so (???) <59F60BC9-94B2-30C9-B9E4-B82C8AD6FBFC> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa/wx/_stc.so
0xe4b4000 - 0xe53aff7 +_aui.so (???) <F328125B-C018-38EB-A7B6-CC91A5C2917C> /Applications/Poser 10/Poser 10.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa/wx/_aui.so
0xf8a6000 - 0xf8b1fff com.apple.CommerceCore (1.0 - 42) <D28DD970-4B69-3848-9BCC-3C67323B3D9C> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x11cfa000 - 0x11cfaffb libpcreposix.0.dylib (7) <7746001E-D745-3BDD-B196-3AD1F879194F> /usr/lib/libpcreposix.0.dylib
0x13cbf000 - 0x13f2aff3 +Collada (0) <44CA2695-1F6F-3529-8253-E5C5414A0851> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/Collada.rwy/Contents/MacOS/Collada
0x140c4000 - 0x140f0fff libpcre.0.dylib (7) <55B57A17-C925-3F70-8890-DAA6A3733B51> /usr/lib/libpcre.0.dylib
0x140f5000 - 0x140fffff +GoZ (???) <9171A3B6-BC28-3B36-AAAE-18B6A067402E> /Applications/Poser 10/Poser 10.app/Contents/PlugIns/GoZ.rwy/Contents/MacOS/GoZ
0x14196000 - 0x14199ff6 +com.macromedia.Flash Player.plugin (15.0.0.152 - 15.0.0.152) <2DE9734D-6F85-381C-8491-09643FA219D8> /Library/Internet Plug-Ins/Flash Player.plugin/Contents/MacOS/Flash Player
0x14586000 - 0x145abff9 com.apple.framework.familycontrols (4.1 - 410) <A33A97EE-C735-38BA-9B49-5D78DAA3DEDA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x148d1000 - 0x148d5ffd com.apple.audio.AppleHDAHALPlugIn (2.6.3 - 2.6.3f4) <FF6AD1A0-09F4-3D20-A2F4-F4F0AE10CE12> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x19f14000 - 0x1b0b9fd7 +com.macromedia.FlashPlayer-10.6.plugin (15.0.0.152 - 15.0.0.152) <E06E6F7E-0EC9-350B-92A2-9ACC34A170F8> /Library/Internet Plug-Ins/Flash Player.plugin/Contents/PlugIns/FlashPlayer-10.6.plugin/Contents/MacOS/FlashPlayer-10.6
0x40000000 - 0x4045fff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (8.28.32 - 8.2.8) <E98BAE1C-BA6D-36AE-B76C-9FDD40BA1236> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x8fe72000 - 0x8fea4417 dyld (239.4) <0F2176BD-4239-3506-BA41-3B885269520E> /usr/lib/dyld
0x90008000 - 0x90012ff7 com.apple.DirectoryService.Framework (10.9 - 173.90.1) <A0D07BF7-31DF-3575-A02F-BEB90006DC74> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x900c8000 - 0x900fefff com.apple.IconServices (25 - 25.17) <A4B5242B-765E-3D58-B066-BBEDB5947AAD> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x900ff000 - 0x9010afff libGPUSupportMercury.dylib (9.6.1) <4733F91D-0778-3DA3-965E-624DD53D0C9C> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x9010b000 - 0x90116ffb libcommonCrypto.dylib (60049) <F8E60C43-22EE-3E0B-9546-3365056901F1> /usr/lib/system/libcommonCrypto.dylib
0x90117000 - 0x90118fff liblangid.dylib (117) <F18F76C6-7E4B-34AD-AE81-C1C031BF2F7D> /usr/lib/liblangid.dylib
0x90119000 - 0x90151fff com.apple.LDAPFramework (2.4.28 - 194.5) <4399D209-B119-3ACC-97AF-F2E14DD207CB> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x90152000 - 0x901a5fff com.apple.htmlrendering (77 - 1.1.4) <408FA30F-4FE9-3162-9FFD-677E8569C1EA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x901a6000 - 0x901b3fff com.apple.AppleFSCompression (56.92.1 - 1.0) <D2E7A2DF-9E5B-35E6-9CCD-0D40ADA7E021> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x901b4000 - 0x901bbfff libMatch.1.dylib (19) <3B3680FC-2AC9-37CC-B262-5ACE2CF8939A> /usr/lib/libMatch.1.dylib
0x901bc000 - 0x901bdfff libSystem.B.dylib (1197.1.1) <BAD8FCD7-5116-31E8-94A8-A571E12E7E5A> /usr/lib/libSystem.B.dylib
0x901be000 - 0x901c6ff7 libCGCMS.A.dylib (599.35.4) <63B0F606-94B1-3355-909A-01C6F26A91F7> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x901c7000 - 0x901f2ff7 libpcap.A.dylib (42) <66FBEAD3-FE91-3A89-8706-FB95229068AC> /usr/lib/libpcap.A.dylib
0x90226000 - 0x90311ff4 com.apple.DiskImagesFramework (10.9 - 371.1) <79F56F62-902E-32A2-A747-C57CCE03E1AB> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x90312000 - 0x9031dfff com.apple.CrashReporterSupport (10.9 - 539) <10FE9B2D-404F-32B8-B3CA-CBA3524B4CFF> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x9031e000 - 0x90322fff com.apple.CommonPanels (1.2.6 - 96) <E7CA63C6-CEE9-3F0A-93A7-C12C653FFB80> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9033a000 - 0x90344fff com.apple.bsd.ServiceManagement (2.0 - 2.0) <B84F3916-236A-347B-9C1F-3DE571496737> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x90345000 - 0x90455fed com.apple.MediaControlSender (2.0 - 200.34.4) <48A88743-4EB7-364B-968F-43C17FFCEB97> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x90461000 - 0x904b1fff com.apple.opencl (2.3.59 - 2.3.59) <CE95AA26-7AE6-3692-8291-8268BBB976D1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x904b2000 - 0x904b6fff libheimdal-asn1.dylib (323.92.1) <DD8BAEED-28AC-389E-9DC4-E32DA60CB05A> /usr/lib/libheimdal-asn1.dylib
0x904b7000 - 0x904c2ff6 com.apple.NetAuth (5.0 - 5.0) <3B2E9615-EE12-38FC-BDCF-09529FF9464B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x904c3000 - 0x904d6fff com.apple.ImageCapture (9.0 - 9.0) <63D5C96F-1893-3F35-ADFB-EE451AFD87E6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x904d7000 - 0x90541ff7 com.apple.framework.CoreWiFi (2.0 - 200.21.1) <13EE6C12-B981-3132-864A-D493B91AE37E> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x90542000 - 0x9055bfff com.apple.Kerberos (3.0 - 1) <91F17EB2-C70C-359C-B09D-96B52D2A9C9F> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9055c000 - 0x90566ff7 com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <C4CC55E5-6CC4-307E-9499-AF89A6463AF4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x90567000 - 0x906bdff0 libBLAS.dylib (1094.5) <74310C2F-4FDB-3995-A01A-5AFB83010A43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x906be000 - 0x9155fffb com.apple.WebCore (9537 - 9537.78.1) <7EC105C0-8B27-369A-8976-4334A09D0376> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x91560000 - 0x91623ff1 com.apple.CoreText (367.20 - 367.20) <42445623-3BDD-3678-8B46-845C441B6251> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x91624000 - 0x91624fff com.apple.Carbon (154 - 157) <6C29C608-97B4-306E-AEC5-6F48EDF7EFB5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x91625000 - 0x918a1fe7 com.apple.QuickTime (7.7.3 - 2826.24) <47052198-D890-3D54-80C6-953FE23AD04F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x918d2000 - 0x918efff4 libsystem_kernel.dylib (2422.115.4) <011434BC-0EFD-35E9-B76D-A22B76DC83DC> /usr/lib/system/libsystem_kernel.dylib
0x918f0000 - 0x91946ff6 com.apple.ScalableUserInterface (1.0 - 1) <2C81641B-FA30-32FF-8B3E-3CB9BF53B2D9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x91947000 - 0x9196fff7 libRIP.A.dylib (599.35.4) <6E3B8709-162D-331E-8722-81D12B0A4BDB> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x91970000 - 0x91998fff libsystem_info.dylib (449.1.3) <BB68E8CC-422F-3121-8C86-D0F766FB696D> /usr/lib/system/libsystem_info.dylib
0x91999000 - 0x919a0ff2 com.apple.NetFS (6.0 - 4.0) <915AA303-C02B-3B0C-8208-D8AAA4350DB4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x919a1000 - 0x919ffffd com.apple.AE (665.5 - 665.5) <54F2F247-160C-3A22-A6E3-5D49655A67AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91a00000 - 0x91dc5ff6 libLAPACK.dylib (1094.5) <E6286E68-3501-31AC-813E-75B3B3968011> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x926ed000 - 0x926f1ffa libGIF.dylib (1044) <075D0A69-DEEC-3712-93F7-DC78FECCC0FF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x92700000 - 0x92817ffb com.apple.WebKit (9537 - 9537.78.2) <525C4DF6-81DE-3D49-900A-0CDA821F9B86> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9281f000 - 0x92820fff libremovefile.dylib (33) <ED35EA79-EB06-3B84-A6D4-B1A9D6B8648D> /usr/lib/system/libremovefile.dylib
0x92821000 - 0x92836ff3 com.apple.AppContainer (3.0 - 1) <017FED4F-AD6E-3A56-806B-A2D33E69EFF9> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x92837000 - 0x92853ff9 com.apple.Ubiquity (1.3 - 289) <1CEDC83D-7282-3B4D-8CF7-4FE045012391> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x928c3000 - 0x929afff7 libxml2.2.dylib (26) <32040145-6FD6-3AD2-B98B-39F73BF9AC47> /usr/lib/libxml2.2.dylib
0x929b0000 - 0x929dbff5 com.apple.ChunkingLibrary (2.0 - 155.1) <50BBBBF8-F30B-39EA-A512-11A47F429F2C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x929dc000 - 0x92a1efff libGLU.dylib (9.6.1) <0655104D-2F22-36CE-955B-52A533CA70D5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92a1f000 - 0x92a23fff com.apple.IOAccelerator (98.23 - 98.23) <305E0437-D56C-3D47-8152-C501B1F22E9C> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x92a24000 - 0x92ac0fff com.apple.QD (3.50 - 298) <F73FD4D4-17A4-37D6-AC06-7CA5A8BA1212> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x92ac1000 - 0x92b38ffb com.apple.framework.IOKit (2.0.1 - 907.100.13) <D1308EE0-96AA-3442-A27B-264F58AE12B4> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x92b63000 - 0x92bedff7 com.apple.CoreSymbolication (3.0.1 - 141.0.5) <A33D0598-8699-39AC-A1DD-37079F423269> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x92bee000 - 0x92c26ff7 com.apple.MediaKit (15 - 709) <82E0F8C0-313C-379C-9994-4D21587D0C0C> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x92c27000 - 0x92c7cff7 com.apple.QuickLookFramework (5.0 - 622.7) <215A2C74-801A-39AE-85E4-A1E5031CFD38> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x92d29000 - 0x92d2eff6 libcompiler_rt.dylib (35) <9924DF2E-D80B-3A21-920D-544A4597203F> /usr/lib/system/libcompiler_rt.dylib
0x92d2f000 - 0x92d32ffe com.apple.LoginUICore (3.0 - 3.0) <6FE961A4-3C17-3004-B50B-FD78FDC28350> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x92d33000 - 0x92d38ff3 libsystem_platform.dylib (24.90.1) <0613F163-9A7A-3908-B30B-AC1627503933> /usr/lib/system/libsystem_platform.dylib
0x92f04000 - 0x92f59ff3 com.apple.ImageCaptureCore (5.0 - 5.0) <69A007AE-4654-3C79-9AF6-5EC8F173F225> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x92f5a000 - 0x92f89ff7 com.apple.framework.SystemAdministration (1.0 - 1.0) <1BD6205B-7C66-3B7B-AC8C-11BE34F7CF6B> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x92f8a000 - 0x92f93fff com.apple.AppleSRP (5.0 - 1) <6B946F4B-7DC4-3E82-BF2C-BE0930E3CF47> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x92f94000 - 0x92fa6fff libbsm.0.dylib (33) <1BE92DB5-0D2F-3BB5-BCC6-8A71EF2A3450> /usr/lib/libbsm.0.dylib
0x92fa7000 - 0x92faaffb libutil.dylib (34) <B496031E-E763-3DEB-84D2-85C0F3DF2012> /usr/lib/libutil.dylib
0x92fab000 - 0x92fb4fff com.apple.audio.SoundManager (4.1 - 4.1) <68B7CEB7-AF09-3E24-8548-6ABF065B5186> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92fb5000 - 0x93133ff0 libGLProgrammability.dylib (9.6.1) <26DFAFFB-1706-3BEF-91D9-06F1655880EE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x93134000 - 0x93158fff libJPEG.dylib (1044) <8501702E-37C9-35F6-8342-037337CCD837> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9391a000 - 0x93931ff4 com.apple.CoreMediaAuthoring (2.2 - 947) <958EE809-D21F-3C88-8D87-B3A5E4C3FCA6> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x93932000 - 0x939f9ff7 com.apple.DiscRecording (8.0 - 8000.4.6) <84A7EC09-3BBD-3E04-A88C-6D3B724448FF> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x939fa000 - 0x93cefffc com.apple.CoreImage (9.4.0) <33696A53-9E18-32D6-844F-28098DB7E426> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x93cf0000 - 0x93ff1ffb com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <02C72D54-E3D3-32B0-A081-E85A7038489D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x93ff2000 - 0x93ff5ffa libCGXType.A.dylib (599.35.4) <12865AFC-BF83-36AB-A42E-331D39C8FD68> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x93ff6000 - 0x9431dffb com.apple.JavaScriptCore (9537 - 9537.78.1) <920DDDBE-17FF-3E62-8E21-03554BF7EDC0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9431e000 - 0x94348fff libxslt.1.dylib (13) <249D54AB-1D82-38FE-ABEC-0D575450C73B> /usr/lib/libxslt.1.dylib
0x94349000 - 0x943b4fff com.apple.Heimdal (4.0 - 2.0) <D6465D74-9351-3FF3-9561-AC149AEDB86F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9441c000 - 0x944adfff com.apple.ColorSync (4.9.0 - 4.9.0) <8366AE10-0396-3100-B87A-A176E8ECE7B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x944ae000 - 0x944d2ff7 libxpc.dylib (300.90.2) <5ACBBE2C-74EB-3E88-BCBF-C573095318A5> /usr/lib/system/libxpc.dylib
0x944d3000 - 0x94600ff3 com.apple.avfoundation (2.0 - 651.12.1) <6A8A6D6F-87E0-3514-BB0C-E3659542A857> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x94601000 - 0x94611ff5 com.apple.LangAnalysis (1.7.0 - 1.7.0) <71DE7754-0A47-3F35-B1BF-B1FE7E1311E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x94612000 - 0x94637ff7 com.apple.quartzfilters (1.8.0 - 1.7.0) <FCF52905-85B1-375C-B0AA-B8251B614D2D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x94638000 - 0x94639ffd libunc.dylib (28) <22A126A1-DCFB-3BE5-A66B-C973F0A5D839> /usr/lib/system/libunc.dylib
0x9463a000 - 0x94655ff5 com.apple.openscripting (1.4 - 157) <5C161A52-8D2F-3D56-A988-05727BED7A59> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x946ac000 - 0x946d6fff libsandbox.1.dylib (278.11.1) <A55CE36C-8E1A-3E3E-BBA1-DEFD3911CBDD> /usr/lib/libsandbox.1.dylib
0x946d7000 - 0x946d8ffa libsystem_sandbox.dylib (278.11.1) <DA875837-A5C2-3004-8117-65F378E4BD03> /usr/lib/system/libsystem_sandbox.dylib
0x946d9000 - 0x946f1ff7 com.apple.CFOpenDirectory (10.9 - 173.90.1) <7F3A0094-3A24-302C-9B64-C32C65750EDE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x946f2000 - 0x9470fffb libresolv.9.dylib (54) <3EC12A7F-6BA1-3976-9F1F-6A4B76303028> /usr/lib/libresolv.9.dylib
0x94710000 - 0x94786ff3 com.apple.securityfoundation (6.0 - 55122.3) <DFA5E047-2B68-3CE8-B9C3-D19E6F2461CB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x94787000 - 0x94788fff libsystem_blocks.dylib (63) <2AC67D5E-ECD4-3644-A53C-9684F9B7AA33> /usr/lib/system/libsystem_blocks.dylib
0x94789000 - 0x947bbffb com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <30CF0E7B-3511-318F-AC31-06C29EDC111E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x947bc000 - 0x947beffe libCVMSPluginSupport.dylib (9.6.1) <C2071F9E-72A1-360C-BF7E-286F9681922F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x947bf000 - 0x947e3ff3 libc++abi.dylib (49.1) <43A04ACF-97A5-35ED-B454-6B5C0CF0F99D> /usr/lib/libc++abi.dylib
0x947e4000 - 0x947edfff com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <CF8E5706-F744-3139-8A51-D52BF055D19F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x947ee000 - 0x947f5ffe com.apple.agl (3.2.3 - AGL-3.2.3) <808BEF15-F413-34AD-8932-E0655519E2E0> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x947f6000 - 0x94a5aff7 com.apple.CoreData (107 - 481.3) <8EB45FB9-CF78-36E1-919C-E976AE4C8146> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94a5b000 - 0x94a5dffb libRadiance.dylib (1044) <6713977E-A33A-395A-9933-719F72DF1A98> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94a5e000 - 0x94ad1fff com.apple.SearchKit (1.4.0 - 1.4.0) <6F607AB6-7553-37BA-BEC5-98FD7C27FAD7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94ad2000 - 0x94aeaff7 libsystem_malloc.dylib (23.10.1) <CB52555E-0F5B-31E3-A42A-FD4F930E2192> /usr/lib/system/libsystem_malloc.dylib
0x94aee000 - 0x94af6fff libcopyfile.dylib (103.92.1) <9B62DDFE-FEFD-31CA-989F-9BE0AB606C49> /usr/lib/system/libcopyfile.dylib
0x94af7000 - 0x94c99ff0 GLEngine (9.6.1) <6E7FF87C-BDE5-3FAA-9943-050C2FCA956F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x94d8a000 - 0x94efafff com.apple.QTKit (7.7.3 - 2826.24) <A9375DC8-01FE-3BF1-87E6-5595EC22AB4E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x94f96000 - 0x9530bff9 com.apple.HIToolbox (2.1.1 - 698) <392738F0-322F-3C80-BEF7-138AFB124C35> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9530c000 - 0x95310ff7 libmacho.dylib (845) <D8E93E59-1F80-3413-B9CF-78B848F6E873> /usr/lib/system/libmacho.dylib
0x95367000 - 0x9550f4af libobjc.A.dylib (551.1) <31CBE178-E972-30D1-ADC6-4B8345CAE326> /usr/lib/libobjc.A.dylib
0x95510000 - 0x95520ff7 libsasl2.2.dylib (170) <CA1C07F6-8E17-315E-AE49-AB696DDE6707> /usr/lib/libsasl2.2.dylib
0x95521000 - 0x9554cff7 libsystem_network.dylib (241.3) <71EBA489-386D-3608-ADE6-CB50EBD1AB1B> /usr/lib/system/libsystem_network.dylib
0x9554d000 - 0x9555bff7 libz.1.dylib (53) <858B4D9F-D87E-3D81-B07A-DF9632BD185F> /usr/lib/libz.1.dylib
0x9555c000 - 0x95560ffc libpam.2.dylib (20) <50623D44-795F-3E28-AA85-23E0E7E2AE0E> /usr/lib/libpam.2.dylib
0x95561000 - 0x9556dff7 com.apple.OpenDirectory (10.9 - 173.90.1) <D50773D6-A261-390E-B159-0C161EA7C457> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9556e000 - 0x9556efff com.apple.Accelerate (1.9 - Accelerate 1.9) <C85070A7-D942-3CFA-981F-5864480788C8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95572000 - 0x95642fef libvDSP.dylib (423.32) <E2FA7230-A001-3F6B-9ACF-6998C51AD7DC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x95643000 - 0x95681ff7 com.apple.NavigationServices (3.8 - 215) <A093AAF0-248E-313E-BA82-01F69E269895> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x95682000 - 0x95684fff libsystem_configuration.dylib (596.15) <E49AAD29-35C2-3EE2-AF4D-59514C4B478F> /usr/lib/system/libsystem_configuration.dylib
0x95685000 - 0x95687fff libquarantine.dylib (71) <EE3B510E-1AEC-3171-8A1A-D6A5A42CF35C> /usr/lib/system/libquarantine.dylib
0x95688000 - 0x95756ff7 com.apple.backup.framework (1.5.4 - 1.5.4) <C09AF796-385F-34DB-B551-68967989E9CB> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x95757000 - 0x95757ffd libOpenScriptingUtil.dylib (157) <4D06E8ED-D312-34EA-A448-DFF45ADC3CE5> /usr/lib/libOpenScriptingUtil.dylib
0x9578a000 - 0x9578cff2 com.apple.EFILogin (2.0 - 2) <C41A6C38-8DB8-3923-90C2-CD1F9F4AA0BA> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x9578d000 - 0x9578dfff libodfde.dylib (20) <98FC02AE-C596-3ED5-80D1-C502FF6115ED> /usr/lib/libodfde.dylib
0x9578e000 - 0x95a07ff2 com.apple.security (7.0 - 55471.14.18) <7A58D9DE-D68B-37F7-87EF-4A3575DA09B7> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x95a08000 - 0x95a71ffa com.apple.datadetectorscore (5.0 - 354.5) <CB793FA7-B873-39A9-855F-D86AB0C35298> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x95a72000 - 0x95b66fff libFontParser.dylib (111.1) <D8F9B2A4-41A6-3407-8D80-13A841F97BE5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x95b67000 - 0x95b67fff libkeymgr.dylib (28) <1B097DEA-011E-3B1C-86D5-6C7FAD5C765A> /usr/lib/system/libkeymgr.dylib
0x95b68000 - 0x95b9dff1 libssl.0.9.8.dylib (52) <B98A4DB3-5AB1-3FDE-8D49-F42EC60A8A65> /usr/lib/libssl.0.9.8.dylib
0x95b9e000 - 0x95e88fd2 com.apple.vImage (7.0 - 7.0) <256972F0-3DBC-3CE1-9EE8-B48243868729> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x95e89000 - 0x95e90ffb libsystem_pthread.dylib (53.1.4) <8B1B7B84-1B5D-32A8-AC0D-1E689E5C8A4C> /usr/lib/system/libsystem_pthread.dylib
0x95e91000 - 0x961beffe com.apple.Foundation (6.9 - 1056.16) <F4D43475-9915-3552-B8E1-4F3E1C9E5394> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x961bf000 - 0x961daff6 libPng.dylib (1044) <D90105D1-B8AD-3649-A798-DA567D1C5B3A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x961db000 - 0x961dcfff libDiagnosticMessagesClient.dylib (100) <B936B1D4-90BB-395D-8EA9-E1237608E7D0> /usr/lib/libDiagnosticMessagesClient.dylib
0x961f1000 - 0x961faff7 libsystem_notify.dylib (121.20.1) <4D3293AC-1CEF-347A-987F-2314AF3CC6EA> /usr/lib/system/libsystem_notify.dylib
0x961fd000 - 0x96201ffe libCoreVMClient.dylib (58.1) <0EB8FFD7-AFED-3A63-810E-29629831D43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x96202000 - 0x96205ff9 com.apple.TCC (1.0 - 1) <A5FCF7AA-3F56-3A19-9DF1-661F1F02F79D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x96206000 - 0x96213fff com.apple.Librarian (1.2 - 1) <F85681E3-3398-327B-829B-1D8078C38C22> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x96214000 - 0x96583fff com.apple.MediaToolbox (1.0 - 1273.54) <46C11BBD-7F31-3227-9441-6087FAA3B477> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x965eb000 - 0x965f4fff com.apple.DiskArbitration (2.6 - 2.6) <92F7575A-AA20-34D9-BB26-2CC8C3CCAFEB> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x965f5000 - 0x96768ffb com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <4248C0FE-F872-34AB-9402-0045D5CD0CC1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x96769000 - 0x967e9ff7 com.apple.CoreServices.OSServices (600.4 - 600.4) <DA7C0406-EC4A-3369-B1FE-F21FD814F2D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x967ea000 - 0x969b0ffb libicucore.A.dylib (511.35) <D14DF7FE-7DE3-36C6-A46D-18C3978827A5> /usr/lib/libicucore.A.dylib
0x969b1000 - 0x96a36ffc com.apple.CorePDF (4.0 - 4) <73557F2A-B0EF-3128-90FE-8EDD7824CE73> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x96a37000 - 0x96a3aff7 libdyld.dylib (239.4) <C03C330D-1757-3D0B-BDD1-913124973BC8> /usr/lib/system/libdyld.dylib
0x96ae7000 - 0x96aeaff3 com.apple.AppleSystemInfo (3.0 - 3.0) <4586B503-A0A8-3654-AA48-D2F9FA0188CB> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x96aeb000 - 0x96aebfff com.apple.ApplicationServices (48 - 48) <7967F6FA-2984-3CC3-AD9A-7B9AEC562A2A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x96aec000 - 0x96b61ff1 com.apple.ApplicationServices.ATS (360 - 363.3) <FD423680-01A1-357A-89A7-33910A87DE65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96b62000 - 0x96b62fff com.apple.quartzframework (1.5 - 1.5) <5BB3FDD4-4727-3D1B-9582-C96F36DA1542> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x96b63000 - 0x96b64ffc com.apple.TrustEvaluationAgent (2.0 - 25) <064B485D-56E0-3DD7-BBE2-E08A5BFFF8B3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x96b65000 - 0x96b6dffe libGFXShared.dylib (9.6.1) <632989B3-36C2-302E-8A85-A02125A9C5D6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x96b6e000 - 0x96b76fff libsystem_dnssd.dylib (522.92.1) <7E36B79E-6BF4-3462-9A84-C0744D029636> /usr/lib/system/libsystem_dnssd.dylib
0x96b77000 - 0x96bbdff7 libcurl.4.dylib (78.94.1) <0EBB0049-F944-3A3F-ACBF-80D742C4945B> /usr/lib/libcurl.4.dylib
0x96c4c000 - 0x97071fe3 com.apple.VideoToolbox (1.0 - 1273.54) <63E19724-B43E-3552-8D1F-87D0688DF593> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x97072000 - 0x9714cff6 com.apple.QuickLookUIFramework (5.0 - 622.7) <6F9C5661-0D7D-3B54-AC34-55E1A24EC05A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x9714d000 - 0x97167ff7 com.apple.GenerationalStorage (2.0 - 160.3) <D39634C9-93BF-3C74-828B-4809EF895DA0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x97168000 - 0x97170fee libcldcpuengine.dylib (2.3.58) <E4953C29-9F6B-30DF-9C10-20854D5DE4BF> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x971a4000 - 0x971f8fff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <68D53493-CC1E-3036-BF67-B2A0F6E1A905> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9721a000 - 0x97280ffb com.apple.CoreUtils (2.0 - 200.34.4) <F14AAB3C-1C8A-37D7-85BE-76646F9F6098> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x97281000 - 0x97283fff com.apple.securityhi (9.0 - 55005) <5DD5A71D-48BA-3CA5-AFCB-28686A9EFB71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x97284000 - 0x9736afff com.apple.coreui (2.2 - 231.1) <17E75125-8D14-30EF-B7A7-662A56B0F4B3> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9736b000 - 0x973b3fff com.apple.PerformanceAnalysis (1.47 - 47) <5C6FA727-EAC9-3924-8662-AF01090A9EF4> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x973d3000 - 0x973dcffc com.apple.CommonAuth (4.0 - 2.0) <99219CEB-D340-3E1F-9C04-FD0FA700BD67> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x973dd000 - 0x973ddfff com.apple.CoreServices (59 - 59) <06747539-5035-3307-8645-9BC4E7F89023> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9773f000 - 0x9773ffff com.apple.Cocoa (6.8 - 20) <407DC9E6-BBCE-3D34-9BBB-00C90584FFDF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x97740000 - 0x977deff5 com.apple.PDFKit (2.9.2 - 2.9.2) <FBCB8D20-2990-314B-A93C-830CB3CD8581> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x977df000 - 0x9798bfff com.apple.QuartzCore (1.8 - 332.3) <DA347693-5E26-3E47-A2B3-3824C52EB08B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x97992000 - 0x97997ff7 com.apple.print.framework.Print (9.0 - 260) <A6C465F6-C5D1-353A-9F33-19B9CEDBBC2A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x97998000 - 0x979b1fff libAVFAudio.dylib (32.2) <A51776F2-0DCA-336D-8898-6876C63F8CDD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x979b2000 - 0x979befff libkxld.dylib (2422.115.4) <8B183287-E46E-3810-AA93-7A83E4BBEA2E> /usr/lib/system/libkxld.dylib
0x979bf000 - 0x979ffff7 com.apple.bom (14.0 - 193.1) <FFF1C8E5-41FF-357B-8681-69B21DCED2E4> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x97a00000 - 0x97a18ffd libdispatch.dylib (339.92.1) <7E7A88BF-74B3-363B-B534-6F757DF2DDE3> /usr/lib/system/libdispatch.dylib
0x97a24000 - 0x97a33fff libGL.dylib (9.6.1) <885E9C1F-11C7-347D-BE10-522A40A46596> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x97a34000 - 0x97a64ff7 com.apple.CoreServicesInternal (184.9 - 184.9) <999FEDEC-7657-3F32-A9AE-F29E0BE0AAF5> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x97a65000 - 0x97ce4ff7 com.apple.imageKit (2.5 - 774) <53C3FA27-3830-3A15-9707-AF7369119866> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x97dee000 - 0x97e1aff7 com.apple.DictionaryServices (1.
