Fri, Jan 10, 11:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Render preview window
BowlingKaz ( ) posted Wed, 05 November 2014 at 4:11 PM · edited Mon, 23 December 2024 at 9:31 AM
 Anyone having trouble with the render preview window?  It is fragmented even though the actual render turns out fine.
hornet3d ( ) posted Thu, 06 November 2014 at 6:48 AM
 Is the fragmentation on every scene?  I have used 2014 and now game dev and I have not seen the problem but I have noticed it does not handle some effects well.  Also it renders at a longer focal length than the actual render so is there anything close to the camera that might be to blame.
piersyf ( ) posted Thu, 06 November 2014 at 4:15 PM · edited Thu, 06 November 2014 at 4:16 PM
If you want to check the full scene, using the same focal length and framing at the full size of the final render, go to scripts>partners>dimension3D>render firefly and on the left side of the box under 'quality' there is a check box for progressive mode. Tick that. Hit render. Cancel render when you have seen enough. You get a good sense of lighting distribution and texturing in a few seconds. If happy, just untick that box and render as normal.
false1 ( ) posted Mon, 10 November 2014 at 11:47 AM
Pro 2014 has that option built in. I just found out about it recently and it's changed my life :-)
________________________________
My DeviantArt Gallery
My Website
false1 ( ) posted Mon, 10 November 2014 at 11:52 AM
My Website
narsil ( ) posted Fri, 14 November 2014 at 1:51 PM
What graphics card have you got?
I have had the same problem with with the PREVIEW  window
there is a work around  if you have an AMD card -
