Mon, Jan 20, 11:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Do freebie makers need/want some seamless tiles?
moriador ( ) posted Sun, 19 April 2015 at 1:47 AM · edited Mon, 20 January 2025 at 11:08 AM
In the midst of all the forum troubles, I'll try to offer something positive... :D :D
I've been playing with Filter Forge, learning how to make filters, etc. (It uses a node based system, so it looks quite familiar in many respects). The kaleidoscope node makes for some truly addictive processing. So in the process, I've generated thousands of seamless texture tiles, mostly for fabric, upholstery, wallpaper, floor tiles, that sort of stuff. Range is from the mundane to cute to wild to utterly outlandish (Timothy Leary meets Rorschach). I actually might want to attempt to sell some of them if people like them, but I have way too many to put together into packages.
I know a lot of merchant resources, even freebie ones, don't let you use them to texture freebie models, so I wonder if this would be useful? I can also generate pretty basic stuff like denim, plaid, linen, etc, if there's a need for it.
I understand that the freebie section is rather bungled at present, and I was going to suggest that I (and anyone else who wants to play) just post them in the forums. But then I remembered that the forum does some weird stuff with compression. I guess there's always ShareCG.
What do you think? Do you guys want them? (Most are 1024 or 2048px, so the pattern size range is pretty big).
Examples:
file_fc221309746013ac554571fbd180e1c8.jp
file_f899139df5e1059396431415e770c6dd.jp
file_2b24d495052a8ce66358eb576b8912c8.jp
RedPhantom ( ) posted Sun, 19 April 2015 at 6:19 AM
Site Admin Online Now!
Those look good. It's very generous of you to offer them.
hborre ( ) posted Sun, 19 April 2015 at 6:19 AM
Those look beautiful.  Of course, any seamless, well-made textures would truly be welcome.
parkdalegardener ( ) posted Sun, 19 April 2015 at 6:28 AM
These are very nice. I really like the second, green, tile pattern. I would be interested in your textures.
pumeco ( ) posted Sun, 19 April 2015 at 7:46 AM · edited Sun, 19 April 2015 at 7:48 AM
I don't need it for anything, but I like that second one, looks very retro-70's!
And cool to see more people using Filter Forge!
vilters ( ) posted Sun, 19 April 2015 at 8:09 AM
Hello moriador, thanks a lot for the work so far.
And all look very well made.
But question :
Why not stick with the default square surface?
Most 3D apps work best with square textures at 512x512 up to and often including 8192x8192
For tiled textures?
I would opt for 512x512, 1024x1024.
Even 2048x2048 is on the big side tor tiled textures.
Just a thought.
moriador ( ) posted Sun, 19 April 2015 at 10:52 AM · edited Sun, 19 April 2015 at 10:55 AM
Cool! Thanks! I'll get a bunch together and get them online.
(The middle one is my fav of those three, too. :) I've got a bunch that are similar.)
Vilters, I probably wasn't clear (as usual) -- the tiles are mostly 1024 x 1024 and 2048 x 2048. I do agree that 2048 is BIG, especially for fabric, but I rendered some of them that size so that I could get close details. Some of the crazy patterns are very, very intricate, so one might want to use a single tile at U/V size 1.000 (though most are best on fabric at about 0.1, depending on whether you want a big, bold print or a little one). And if you're using it for wallpaper, well, some walls are quite large. Also better to be too big than too small. Easy to reduce a texture size; not so easy to increase it. But I may just upload everything at 1024 x 1024, in the interest of saving people's bandwidth. :)
Pumy, I've got some pretty wicked looking textures that Roxie might like. Blood red. :D (I call the set "Vampire Castle" but it could just as easily be "Roxie Red".)
I'll post a link soon as they're up. :)
pumeco ( ) posted Sun, 19 April 2015 at 12:25 PM
Sounds good, Moriador, and just as well really cause Roxie is in a really bad mood just lately, she even pulled her avatar!
Boni ( ) posted Mon, 20 April 2015 at 4:59 PM
What a lovely gesture.  Thank you so very much.  Many people can use these. :)
Boni
Boni
NanetteTredoux ( ) posted Tue, 21 April 2015 at 7:01 AM
Thank you for offering - I make some of my own textures with Gliftex and Genetica, but it is always refreshing to work with something different. Very nice work.
Poser 11 Pro, Windows 10
FVerbaas ( ) posted Tue, 21 April 2015 at 11:50 AM
Forum Coordinator
They sure look good and will go perfectly on designs with Marvelous Designer's flat UV mapping.
I have quite a number of clothing items for Roxie and Antonia I would be happy to share, but then as you say many vendors do not allow redistribution unless worked, and yet the whole point of models with flat UV's and seamless textures is that they are made to be used without working them: simply cut the patterns from the tiled surface.
Thank you for offering.
