Sat, Jan 4, 1:41 PM CST
Subject: Gamma Correction Woes with Transparency maps
jura11 ( ) posted Tue, 12 May 2015 at 1:18 PM · edited Sat, 04 January 2025 at 1:38 PM
Hi guys
Not sure if this has been covered over here,but here are my last woes with GC and Transparency maps
Here are attached the pictures of two renders,both has been rendered with same textures and same V4  and same light setup
This one has been rendered with GC on with no postwork
Second render has been rendered with GC off with no postwork
As you can see on the attached renders,there are differences with transparency maps on the Emotional II,textures are from R3D(Temptation for Emotional II http://www.renderosity.com/mod/bcs/temptation-for-emotional-ii/92897 ),this does happen with several other textures not only with those when you are using GC
I've tried to lower transparency to 0.4-0.5 or even lower,which doesn't helps at all
Not sure what is best way to cure this or what is best way how to deal with those issues
Thanks,Jura
WandW ( ) posted Tue, 12 May 2015 at 1:26 PM · edited Tue, 12 May 2015 at 1:27 PM
If you are using Poser 10/PP2014, the latest SR is supposed to automatically correct the gamma for transparency maps. One can also use theChangeGamma script under MaterialMods on the Scripts menu; enter a value of 1.0 for all props and figures and "all of the above"...
vilters ( ) posted Tue, 12 May 2015 at 1:41 PM
Render settings should Always be with IDL and GC ON, and at 2.2
Color maps like diffuse textures loaded with "Render settings" or GC at 2.2
Black and white textures like transparancy, bump, and displacement maps, HAVE to be loaded in the material room at Gamma Correction set at 1.000
jura11 ( ) posted Tue, 12 May 2015 at 1:42 PM
Hi WandW I'm using PP2014 with latest SR and those renders has been done in PP2014 and all trans maps have 1.0 what I know and what I've check'd last time when I've done those renders
But on other hand I've tried to postwork those GC renders and looks like adding more contrast will cure this issue,strange
Thanks,Jura
jura11 ( ) posted Tue, 12 May 2015 at 1:44 PM
Hi there I'm only rendering with IDL,GC
Color maps are with GC 2.2 and all trans and bump maps are set 1.0
Thanks,Jura
jura11 ( ) posted Tue, 12 May 2015 at 1:47 PM
Hi guys
Is possible something like contrast control per texture ?
Hopefully Bagginsbill knows how to control contrast
Thanks,Jura
vilters ( ) posted Tue, 12 May 2015 at 1:52 PM
You can add a HSV node between the texture and the channel.
H = Hue
S = Saturation
V = Value
Or add a Color_Math node to increase or reduce contrast?
primorge ( ) posted Tue, 12 May 2015 at 2:36 PM · edited Tue, 12 May 2015 at 2:42 PM
Maths:Gain for contrast. AFAIK.
BB might have a more correct solution.
http://www.castleposer.co.uk/articles/maths_gain.html
jura11 ( ) posted Tue, 12 May 2015 at 4:37 PM
Thanks that's worked pretty well Thanks,Jura
jura11 ( ) posted Tue, 12 May 2015 at 4:44 PM
OK here are few renders
First one is Sexy Dress II with R3D textures as you can see transparency are again over the place
Here is same render but postworked with PS(I've adjusted only levels)
Third render and there I've plugged between the transparency map Math_Function ,set this to Gain and under Value_2 I've put 0.8 and transparency now looks like should
Same above(3rd) render,but now has been postworked in PS(levels only)
Thanks,Jura
