DAZ|Studio F.A.Q (Last Updated: 2024 Oct 22 8:45 am)
Make sure and check your download path and the installation path in DIM is correct.
The manifest and download should be in the same top folder of the Install manager folder.
I suspect you can cautiously move the manifest folder over and then delete the main folder from your C: drive.
And just double check when you download something new to make sure it's going into the correct folder from then on.
Let us know how you go
Crud. Swing-and-a-miss!
DIM now shows that I have '0" items insatalled, and there is no Smart Content anymore.
I moved everything back to how it was, and it's still broken. Must be like Poser. I specified that IT install the Download Manager to 'D', but it insists on C: > Users. I argued with customer support but when I gave up, it was left with me not knowing what a path is. :)
Well...I guess I'll uninstall everything and try again. In hind site, I wish I would've went with the 500GB SSD since I'm finding out that even IF you're given a choice of where to install things, they might not end up there.
I have no trouble with downloads (and manifests, using the ini file edit) on a different drive. Download location can be set in the DIM preferences, to set the manifests location (they are small files, I move them to keep them safe if I have to reinstall Windows) go to C:UsersYOUAppDataRoamingDAZ 3DInstallManagerUserAccounts and edit the OverrideManifestDir= and optionally (if you download the thumbnails for DIM) the OverrideThumbnailDir= lines in the Account.ini file. Use forward slashes /, not back slashes , as the folder separator. Move your existing manifests/downloads/thumbnails to the new location.
I'm a Poser user trying to dabble with DAZ. I can't install anything on my C: Drive (eenie-weenie SSD), and I have all my programs and User Account on D:
I have 'D's' path specified in the DIM, yet look at the pics. What's going on? What to do? C & D are duplicates as far as the Download Folder; C has a Manifest Folder; D doesn't. I don't suppose it can be as easy as moving the Manifest Folder over to 'D', and deleting 'C's' Download Folder??
(D Download Folder)
(C Download Folder)
** (C Manifest Folder)**
Thank you
