Forum Moderators: RedPhantom
For what it's worth, my iMac has a very modest nVidia graphics card (GT 650M) which does support GPU rending in Poser 11, but I don't even use it - CPU rendering is faster for me. Of course it depends on what you need to do, but for a 'hobbyist' like me it's fine.
Poser Preview rendering uses OpenGL, which should be well supported by the integrated Intel graphics.
Izi
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
If you have about $400 to $500 to spare you can upgrade to a decent nVidia Video Card and Power Supply A GTX970 with 4GB is about $350, this is a mid end card with 1600 cudas, Unless you have a decent Powersupply you ,may need to fork out another $150 for a platinum 80 certified, 850W power supply
The performance is significant. That configuration is nowhere near pro. My dream rig is $3500 (two Titan Xs with 12 Gb each) which should be about 3 times faster than my current rig
I don't render in Superfly yet, but I've been rendering in Octane. I've tried Reality and Iray with CPU render option switch on... It was no way near the speed of GPU renders.
You can't really compare apple with oranges. If you have a lower end nVidia card with only a few hundred CUDAs it will not give you the speed you expected. The GTX970 has 1600 cudas. the Titan X 3300 cudas. I have two older GTX760's they each have 1100 cudas so combined 2200 cudas.
As with CPU,rendering if you have an older single or dual threads CPU with lower speed it won't give you fast results. You probably have to invest in a ,multi threads / multi core CPU to get the result similar to a Mid end Video Card. Or you could build a renderfarm with multiple computers. Of course, there is a matter of cost.
So, no mater how you slice it...whether GPU or CPU rendering, If you want speed, you gotta pay.
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
You can get a lot of info off the web by googling blenders cycles. Just double check super fly rules. I never caught if Poser 11 can use both CPU or GPU.
If you can build your own PC's or If you have a PC shop or know some local PC savvy dudes. They might be able to build you a killer PC cheaper.
Real time render engines are very affordable.
============================================================Â
The
Artist that will fight for decades to conquer their media.
I just picked up a 4GB nVidia GTX 960 card for $200, and it made a huge difference in Superfly (I had a Radeon card before, which didn't contribute to Superfly, obviously). I have a 500W power supply on an AMD Phenom II X6 system, it seems adequately powered (the card draws 128 watts), although if I make my bucket size bigger than 128, the render sometimes fails, but it may be lack of memory ; 4GB isn't a lot for a big scene. The biggest scene I've rendered thus far contained 2 fully clothed Genesis 2 figures in a furnished room.
I can't Link to it , but it's an EVGA GeForce GTX 960 04G-P4-1962-KR 4GB SC GAMING with the stable Drivers from the nVidia site.. I got it at NewEgg...
PS; I should add that nicely accommodates my analog secondary monitor...
"Oh - the manual says that? I have never read the manual - this must be why."JVRenderer posted at 9:05AM Tue, 23 February 2016 - #4256813
No doubt. You have to take stock of what you are doing with the computer. I play keyboards and use my computer as the center of my recording setup. I would rather spend money on the CPU than the video card. If all you are doing is 3D art then the mondo video card makes more sense in that situation.
My computer has integrated graphics and an nVidia card. I found poser 10 virtually unusable in hardwire preview mode using integrated graphics due to really strange material effects. I've just checked P11 and the problem seems to have been overcome, but I've only checked a figure in the default P11 scene, so I'd be a bit concerned about relying on integrated graphics
Nails60 posted at 3:03PM Tue, 23 February 2016 - #4256899
Were you using Open GL or Sree3D mode?
JVRenderer posted at 11:42PM Tue, 23 February 2016 - #4256813
Hi there
For GTX 970 I would say 650W PSU is enough and 550W will be OK,those GPU doesn't eat too much power like Titan Z or Titan X,I'm running Titan X with GTX780,both are Overclocked plus I'm running older Xeon X5670 which is OC to 4.2GHz and my PSU is 850W,Titan X usually eats around 250W when renders and GTX780 eats around the same as Titan X 250W
GTX970 is great card,but have slower 0.5GB VRAM which can affect render speeds,just have look over on Blender forums and regarding Titan X there,if you are really want to render only with Superlfy,I wouldn't get Titan X,its great card with lots of VRAM,but 980Ti is slightly slower than Titan X in Superlfy and my old GTX780 still have reasonable render times,slightly slower than Titan X,as I pointed in one thread over on RDNA I think Superfly is not optimized for new Maxwell cards and due this I would go with older GTX780 6GB which cost lot less than Titan X and same has been with Octane when Octane performed poorly with Maxwell cards(Titan X,GTX980 etc),but at least Otoy optimized the renderer for new cards...
If you are using for rendering GPU then I would invest,but still I would bit wait until new Pascal and Polaris will be out and plus Octane 3 will have in future OpenCL and then you can go route of the AMD card
If you render with Octane then I would probably go with Titan X,but still if its worth hard to say,price is still too high for Titan X
Hope this helps
Thanks,Jura
WandW posted at 12:04AM Wed, 24 February 2016 - #4256841
I can't Link to it
Hi there
I'm surprised its crashing on yours when you render,if its possible can you post yours render settings there ?
And do you have enabled Branched Path Tracing,if yes please disable this,this can make render to crash and if you have enabled Subdiv(I usually set Subdivision at 1 with Genesis) plus maps etc this can take lots of VRAM,i would export Genesis as OBJ and export them again to Poser and if you missing SSS then you can apply on them too SSS via EZSkin there too
Hope this helps
Thanks,Jura
Letterworks posted at 8:39PM Tue, 23 February 2016 - #4256903
Thanks for the replies folks. I'mean really rethinking this... Mostly I play with Zbrush, Silo and Poser... I've also been trying to learn Daz Studio, so I'm planning on a better Nvidia card. Maybe I'll lower the ram and get a better card first, let need to look at things...
If you run multiple app's I swear one wants RAM the other bigger GPU the others quad CPUs. My PC quad 64 bit .you can upgraded from time to time more RAM ,bigger GPU. etc etc. Got 8 RAM ,GeForce GT 620. Witch was all just fine till I got Substance Live. GeForce GT 620 works but not the best choice for Substance Live. So guess I alt to get a bigger GPU.
and the mother board n monitor is from 2013 so I know I'll need to replace them soon also. PC's last me about 3 years ,if I'm lucky ;)
The
Nails60 posted at 12:13AM Wed, 24 February 2016 - #4256899
Hi there
You are not alone there with HW preview mode who have issues,I've tried too like my R9 290 or R9 390X or even Titan X or GTX780 with all of them I've run to issues,in new PP11 I've now issue with OpenGL again same as with AMD when AMD abandon atiogl.xml like in this thread
http://forum.runtimedna.com/showthread.php?97726-Poser-Pro-2014-problems-again
Now this does happen with Titan X too sometimes,its not frequent,but does happen too
SreeD is CPU only and OpenGL is hybrid CPU/GPU,this preview renderer is only preview and usually I don't care how it looks,I do real fast quick render and check if lights are correct etc and I would rather to recommend to use Raytrace preview which will give you idea how yours scene will looks when you will be rendering etc
Hope this helps
Thanks,Jura
jura11 posted at 7:17AM Fri, 26 February 2016 - #4256952
Hi there
Hi Jura,
I haven't had any issues when I set the Superfly Render settings in the render settings dialogue instead of the included Render Firefly script (yes, I know It's Superfly, but the script allows one to chose Superfly as the renderer, so it has obviously been updated for P11), which apparently needs fixed. Thanx!
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi, I'm looking for a bit of advice and/or the answer to a question.
I am going to buy a new computer with very appealing specs except for one thing, it uses the integrated Intel HD Graphics 350 for graphics. I intend to buy a good Nvidia card at some point in the future but buy the computer will about break my budget for the moment. So, I'm looking for any advice as to performance with Poser Pro 11. Is it going to be a serious issue or just a minor set back not having the Nvidia Cuda?
Thanks for any help
