Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:18 am)
72 views n not one response.why no responses ?
Did you not understand what I'm asking ? or something else ?
let me know
Thanks
The
Artist that will fight for decades to conquer their media.
For me... Viewing images on Pinterest, where I am not a member, is a pain in the arse, because of the annoying "sign up now" box that appears in the middle of a darkened screen.
I don't know which, of all the page full of images, you are asking about.
I don't fully understand what you mean about "Very smooth". If you mean high-ish poly, then yes, they are by and large what people are looking for. There are a few here who would disagree but not many. Given the size and power of most users' rigs now, low poly is not really necessary. Anyhow, blocky figures with obvious poly areas look butt ugly. If you mean something else, then what?
Keep in mind that one can easily convert a lo-poly figure to Poser Unimesh, and subdivide as needed...
"Oh - the manual says that? I have never read the manual - this must be why."WandW posted at 2:28AM Mon, 27 June 2016 - #4273826
I hear what ya saying about the SubD's and it is a option.
Guess the options are
1 make characters modeled like Rosetta
2 make characters modeled like V3
3 make characters modeled like V5
4 make characters modeled like V5 low poly count mesh n SubD it.
the problem is to make characters like these are a trick n every time you add hi poly count or SubD's makes them way more complicated and a lot more time to make.& requires a lot more skill.
The
ghostship2 posted at 11:06AM Mon, 27 June 2016 - #4273882
Those two images look more like they are Photoshop paintings rather than 3d renderings.
a lot of pinterest ,deviant art is multiple mediums but wouldn't it be cool to have monsters something like that for Poser ?
The
RorrKonn, why are you using crap like Pinterest when you already have a DA page? There's a reason they block images unless you sign up (datamining) :-P
Anyway, about your question. Some of the software out there is so good now that it seems to be more like a choice between what you're making than anything else. If it's a close-up of a nude you'll want smooth no doubt. But for things like monsters, beasts, and warriors with spikey-looking armour you can easily get away with the low poly stuff now I reckon. Especially since Vector Displacement technology arrived. It's pretty amazing how much detail you can get from a low-poly when using stuff like Vector Displacement.
I would like to try those models, but that would mean that someone would have to rig them. I guess that they don't work in Poser yet?
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
TheRealWorld posted at 6:53PM Mon, 27 June 2016 - #4273917
I singed up to Pinterest cause when I google ,monsters,warriors,babes etc etc a lot of the .jpgs where on Pinterest. I know it's data mining but they have links to the mined sights . Led me to some cool sights.
Vector Displacement is killer but i'm not sure what versions of Poser n Daz support it ,if any version . there normals n displacements could be improved ;)
ya making nude girls ,not on the top of my to do list being we all ready have at least 10 all ready.
The
bantha posted at 7:19PM Mon, 27 June 2016 - #4273941
For Poser ,If they where only as smooth as 1 or 2 would you still want them ? or do all your models half to be as smooth as 3 ?
The
Load obj files in Poser with Smoothing set at crease angle 180° on all groups. Then set the Subd to level1. The result is all smooth flowing obj files.
I am working on a tutorial on how to get high to ultra high sculpted figures in low to medium poly Poser figures. Once you know the trick? it is dead simple to do so. And at render time? Yu can set the figures that are close to the camera to fine detail, and the figures in the distance to low detail to keep render time under control..
tonyvilters posted at 9:14AM Tue, 28 June 2016 - #4273982
Feel free to post your tutorial ,right here :)
The
RorrKonn posted at 12:03PM Tue, 28 June 2016 - #4273956
Sounds like a fun project, so don't forget to post the result :-D
I think 3D-Coat and ZBrush have Vector Displacement, but I'm not sure which others have it.
Poser can use:
Bump maps and Normal maps. => These give only a "visual 3D effect", as they actually do nothing in 3D. Displacement maps => that actually move the mesh IN and OUT at map pixel level. => the higher resolution the map, the more detail one can get. But a displacement map can come through poking clothing.
For all maps there are the same limitations. You really do not see that well whet you are doing until render time. And? You have to work around the seams. And some of these maps have issues with one or more render engines.
What I am working on is a "GAME CHANGING PROCEDURE", that works in all of Posers render engines, from Preview to SuperFly.
The end uses has FULL control during the creation, and afterwards also FULL CONTROL in Poser. And? ? ? ? They are dead easy to adapt if required, AND they go in clothing if required.
Here is the link to the video, but I will start a new tread. Higher detail on Poser figures: The easy way.
If I got any of this wrong ,Correct me. but It goes some thing like this.
zBrush created Displacement maps 2001,Sméagol from LOTR was are introduction to Displacement maps .
MudBox created Vector Maps in 2014.
Vector Displacement: Zbrush, Mudbox & Maya Workflow Explained
Vectors Maps are colored n have under cuts. Displacement Maps are black n white n cant do under cuts.
Cool tutorial tonyvilters.
TheRealWorld Where starting with boots ,they say you can't start at the top ;) .First post Friday n all other versions will follow. Where experimenting with polycount n maps for your all's approval or disapproval.
The
And here a follow-up video demo: Detailing Poser figures, combining 2 different procedures.
Best regards and have fun using the Poser tools.
tonyvilters posted at 3:12AM Thu, 30 June 2016 - #4274102
Cool Stuff Tony ,This will be helpful :)
The
jura11 posted at 9:24PM Fri, 15 July 2016 - #4275896
Not sure there,but I would suspect they're as above been painted or they're used ZBrush for modelling them,over on Pixologic or Polycount forums there are WIP and some their works are just awesome there
Hope this helps
Thanks,Jura
I'd like to make some awesome characters for us. :)
The
I wanted to look at the video Tony but it isn't there. Can you tell us more about your new system? Love esther
I aim to update it about once a month. Oh, and it's free!
Content Advisory! This message contains nudity, profanity, violence
This is complicated for me to try n explain what I'm asking ,so bear with me.
I have some boards of other Artist at https://www.pinterest.com/rorrkonn/ and I see stuff I've never seen here. Especially on the games ,mage ,monsters ,scifi ,warrior. boards.
Not the old game characters but the newer game characters are pretty smooth.
Poser characters are very smooth.
So here's my question.
Do we only accept very smooth characters ?
or
Do we accept pretty smooth characters,If they cool ,original , ?
https://www.pinterest.com/pin/243687029817092000/
https://www.pinterest.com/pin/243687029816910215/
https://www.pinterest.com/pin/243687029817092018/
https://www.pinterest.com/pin/243687029817092006/
https://www.pinterest.com/pin/243687029816997634/
https://www.pinterest.com/pin/243687029817092108/
https://www.pinterest.com/pin/243687029817089328/
https://www.pinterest.com/pin/243687029817020952/
https://www.pinterest.com/pin/243687029817020944/
