Sun, Feb 16, 3:02 PM CST
Subject: Render DAZ Genesis 3 in Poser!!!!!! Now you can-FREE!
willdial ( ) posted Mon, 03 October 2016 at 7:23 PM
MistyLaraPrincess posted at 5:15PM Mon, 03 October 2016 - #4285471
wonder if this could work for getting g3 into carrara >.<
I looked at the possibility, but the technique uses features that are in Poser 11 for the expressions. I'm not sure it would work. I heard that Carrara uses are not happy about this.
DocMatter ( ) posted Thu, 13 October 2016 at 5:38 PM
Okay, I finally got Poser Pro 11 but I'm still having trouble with this. First off... is DSON already installed in Poser 11? If not, the DAZ installer won't let me install it because it says it can't find the file path to PP 2014 (why 2014?). I have a DSON folder in 2014, but not one in Poser 11, so I don't know where to save the G3 figure DSON files to.
RHaseltine ( ) posted Fri, 14 October 2016 at 8:27 AM
Online Now!
The Current version of the Daz Install manager should allow you to set a path for Poser 11 - click the gear icon to open preferences, then go to the Applications tab and click the + button to add a new application, set it to Poser, 11 (or 11 Pro), 64 or 32 bit, and then click the ... button to set the path. If that si done try setting an application as Poser pro 2014, and use the path to Poser 11, but I don't think the DSON Importer is flagged as Poser 2014 or earlier only.
DocMatter ( ) posted Fri, 14 October 2016 at 12:06 PM
I tried that but the installer still wouldn't do it. I ended up just downloading it for manual installation and put it where I wanted. I really do not like the DAZ installer!
DocMatter ( ) posted Sat, 15 October 2016 at 10:01 AM
Okay, I've run through every step, but when I finally get G3 open in Poser 11, she has no morphs at all. None of the body morphs (or expression morphs) even show up. The movement morphs are there, but nothing else. The morphs are all there in DAZ before the conversion, but not in Poser. I'm also making sure both DAZ and Poser 11 are pointing the same runtime (in this case "MyDaz3d Library" folder.G3NoMorphs.jpg
willdial ( ) posted Sat, 15 October 2016 at 3:45 PM
Genesis 3 morphs are all Full Body Morphs and the individual morphs in the body parts are hidden.
DocMatter ( ) posted Sat, 15 October 2016 at 3:58 PM
Then where are they hidden? They're not under the FBMs as you can see here, or under the individual parts (as in the previous image), so where are they?G3NoMorphs2.jpg
RHaseltine ( ) posted Sun, 16 October 2016 at 8:45 AM ยท edited Sun, 16 October 2016 at 8:46 AM
Online Now!
They should be under Actor. Do you have the morph packs? If not there will not be many shapes.
DocMatter ( ) posted Sun, 16 October 2016 at 11:54 AM
All I see under Actor are a few FBMs, which is what I expected. But I'm still not seeing any of the other body morphs anywhere (chest, head, face, etc...) that show up in DAZ.
RHaseltine ( ) posted Sun, 16 October 2016 at 1:47 PM
Online Now!
Do you have the morph packs? Are they installed to the same content directory as the rest of the figure (DS can combine assets from multiple content directories on loading).
DocMatter ( ) posted Sun, 16 October 2016 at 2:28 PM
I'm not going to buy any of the morph packs until I get this crazy thing working. The morphs I'm talking about are the ones shown here that show up in DAZ but are nowhere to be found once I import her over to Poser (after following all the steps described). I've looked under "actor", the various body parts, everywhere... and they're just not there.G3NoMorphs3.jpg
RHaseltine ( ) posted Mon, 17 October 2016 at 9:00 AM
Online Now!
Most of those are ERC links to bones, rather than true morphs - isn't that what the conversion tool is meant to fix? Have you run that?
DocMatter ( ) posted Mon, 17 October 2016 at 9:35 AM
Yep. And even on the new "updated" G3, no morphs are showing up.
RHaseltine ( ) posted Mon, 17 October 2016 at 1:46 PM
Online Now!
Sorry, I don't know what further to suggest.
DocMatter ( ) posted Mon, 17 October 2016 at 2:01 PM
That's okay, thanks for trying to help. Guess I'll just start from scratch... again, and see if anything changes.
willdial ( ) posted Mon, 17 October 2016 at 8:15 PM
Those control morphs are listed under Pose Controls group in the Body of Genesis 3. There are sub groups for body parts, like Head, Torso, and Arms. What do you see?
flibbits ( ) posted Sun, 23 October 2016 at 2:31 PM
The title of this thread is misleading. Please change to "You Still Can't".
arrow1 ( ) posted Thu, 03 November 2016 at 11:14 PM
I have just created a Genesis 3 Male character in DAZ Studio converted it and sent to Poser.When I go to open it in Poser Pro 11 it keeps asking me for .PMD files.What are these and where do I find them? I haven't come across this problem before! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OSย Windowsย 11 64 Bitย Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate.ย 4 xย 2 Terrabyte Hard Drivesย and 2 xย 2ย Terrabyteย external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5ย Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.ย  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
willdial ( ) posted Sat, 05 November 2016 at 10:53 AM
arrow1 posted at 8:50AM Sat, 05 November 2016 - #4288814
It looks like the DSON Importer did not create the PMD file. It's a file that holds all the morphs. I recommend clearing out the DSON cache and try again.
arrow1 ( ) posted Sat, 05 November 2016 at 3:03 PM
Thank you for replies.Can tell me where I go to clean out the DSON cache? Cheers
Synpainter ( ) posted Sat, 19 November 2016 at 8:00 AM
Any update on the MAC version of this?
willdial ( ) posted Mon, 21 November 2016 at 6:22 PM
I'm sorry, but I have no ability to create a MAC native version of the tool. MAC users have used WineBottler to the tool.
shante ( ) posted Wed, 23 November 2016 at 12:13 PM
What I really want and NEED is a tool that will allow me to open/import D/S environments, props and hair products so I can use in Poser. As much as it is nice being able to work with the G3 figures this way and appreciated, one of the reasons I have not gotten any of them is the new re-investment in yet another figure. I just want product line of the same quality created for D/S now as good as it is for Poser. All the set and environment and prop and hair creators seem to be migrating to D/S functionality and when i have asked if it can also be made for Poser users I am told to MOVE ON! Well and good for them but not so for those of use so heavily invested in Poser tech as well as the stuff for it. I am sure this tool does not solve that problem....does it?
RHaseltine ( ) posted Wed, 23 November 2016 at 3:43 PM
Online Now!
The basic DSON Importer will if there are PoserCFs (Poser library files to launch the importer, and hopefully apply Poser material settings). If there are no PoserCFs it may still be possible to import, using Dimension3D's script to launch the importer with a file browser http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader but materials would then have to be redone (and some items just won't work in Poser).
Cyberdene ( ) posted Sun, 27 November 2016 at 1:17 AM ยท edited Sun, 27 November 2016 at 1:18 AM
I thought about just downloading DAZ 4 already and switch back and forth, I'll pass on buying Poser 11, I heard it's ass from a lot of people that use it. I might try Poser Pro 2014 but render wise, I'm investing in Octane eventually. Forget firefly, that weak ass shit is elderly slow. And they call themselves innovators. Octane uses the graphic card, mine is a GTS 950, if I got 1050 oh yeah stupid fast renders.
EClark1894 ( ) posted Mon, 28 November 2016 at 3:02 PM
Hey Willdial, just out of curiosity, what language did you use to write this program?
willdial ( ) posted Mon, 28 November 2016 at 6:09 PM
EClark1894 posted at 5:06PM Mon, 28 November 2016 - #4291233
I wrote it in C#. I own a copy of Visual Studio 2008 that's why it needs .Net 3.5.
EClark1894 ( ) posted Mon, 28 November 2016 at 8:49 PM
I'm assuming that's actually C++. I never heard of C hashtag, or pound sign or whatever. I was just curious. I haven't actually messed with any coding for 15 years and I was just learning then. I think I wrote one word mini-program for the mac and then quit.
Razor42 ( ) posted Tue, 29 November 2016 at 3:37 AM
C# is pronounced as C Sharp
EClark1894 ( ) posted Tue, 29 November 2016 at 7:23 AM
Thanks, Razor. Still never heard of it, but I'll look it up.
Boni ( ) posted Tue, 29 November 2016 at 3:01 PM
Let's not trash the software guys. If you prefer not to use it fine. But NO trashing!!
Boni
EClark1894 ( ) posted Tue, 29 November 2016 at 6:25 PM
Boni posted at 7:23PM Tue, 29 November 2016 - #4291384
Umm, if you're talking to me Boni, all I did was ask what language the program was written in.
Boni ( ) posted Tue, 29 November 2016 at 10:31 PM
Sorry Clark, not aimed at you ... just some earlier posts ... you are fine ... it was just getting on the edge.I came in a little late.
Boni
45Cool ( ) posted Thu, 29 December 2016 at 3:36 PM
Hello, I have been reading through all the thread about DSON Importer. And have been unable to locate DSON 1.1.3.x Beta. I would like to know where to find this version. At this time I have DSON Importer for Poser that is available for download. That's all I can find and I have looked everywhere.....Please help! Cheers, Pat
FYI: I have Poser 11 Pro and Daz 4.9 64 bit systems.
Dkgoose ( ) posted Sun, 01 January 2017 at 9:51 AM
Is there a way to speed up DSON, it takes 5 min at least to load Genesis 3 Female? And I think I'm missing something in the tutorials, I keep getting an error when using Genesis 3 poser updater on the poser saved figure
willdial ( ) posted Mon, 02 January 2017 at 5:18 PM
satan14755 posted at 4:08PM Mon, 02 January 2017 - #4294105
DSON Importer creates a CR2 on load. The more morphs you have, the longer it takes. I have not been able to speed it up.
Here is a video to a video tutorial
Dkgoose ( ) posted Tue, 03 January 2017 at 12:58 AM
Awesome thanks I'll have to watch it. I purchased lululee's video tutorials and those are great, I own a lot of morphs :/. It's fun anyway your program is great so thank you, it was one of the things that pushed me into updating to Poser Pro 11.
Dkgoose ( ) posted Wed, 18 January 2017 at 1:09 PM
Lululee, Are the corsets used in the video tutorials available for purchase here?
45Cool ( ) posted Tue, 24 January 2017 at 2:26 PM
Hello, Having a small problem here. Has anyone had this happen to them where Poser didn't respond loading G3F.Screenshot_12 DSON.png
ssgbryan ( ) posted Mon, 06 February 2017 at 1:57 AM
willdial posted at 12:32AM Mon, 06 February 2017 - #4294194
The way to speed it up is restructuring the data folder.
DS builds the figure from scratch EVERY SINGLE TIME you load it. It will also load every morph it has visibility on. So limit what it can see. The way I do it is by building separate runtimes for my figures - only load what you need. As an example my g2f runtimes are broken out as follows:
Base - everything I want in all characters (Base Morphs, - I also keep hair, poses and such here - they don't interfer with generating a character). If there is a particular character morph I want available for all characters, I'll also move it from it's original location to here. Example: I have a couple of Nail morphs I want available for any figure, I dump them here. G2F Characters - all of my characters that do not use a specialty sculpt (Victoria, Aiko, Lillith, etc) Each G2 Sculpt - each of these (Aiko 6, Victoria 6, Olympia 6, etc) are separate runtimes - If I know I'm not going to need any Lillith morphs, I don't load that runtime.
A more extreme version of this is deciding what morphs you are going to use and pop those in and out of your data/DAZ 3D/Genesis #//Morphs/Vendor Ego Folder/ folder.
ErickL88 ( ) posted Fri, 10 March 2017 at 6:22 AM ยท edited Fri, 10 March 2017 at 6:23 AM
Not wanting to start a new thread, but did anyone have success, of getting a G3 hair figure (transmapped) ported to Poser11? If so, is there a discussion or a help topic related to this already, please?
shante ( ) posted Thu, 13 April 2017 at 5:03 PM
I am just curious will this work with props and nature sets and other non HUMAN characters which has of late been made exclusively for D/S? I am not interested in the G3+ figures but animals and sets/environments/props etc. are a must have for me and not being able to use them frustrates the hell out of me when so much better stuff than anything made in the past for Poser is made of late for D/S only.
hgrender ( ) posted Tue, 10 October 2017 at 4:59 AM
McGrandpa posted at 11:57AM Tue, 10 October 2017 - #4257386
Nevermind, I got it I got it! I messed up something in the saving process from DS. I deleted my mistakes and started fresh, following the Userguide PDF to the letter and it worked. Now I have a G3F loaded in PP 11 with Skin, morphs and posing. Time to go buy Fred Winklers Livia! McG.
What exactly did you do with the saving process? Give me some more Details, please. Thank you in advance.
TaishoBee ( ) posted Mon, 07 May 2018 at 11:47 PM
Hi all! I get this error now with DSON. Genesis 1, but I hoped someone could help. THANK YOU for the help with the grid issue!! I'm dealing with that on G1 too. I'm on Windows 10, up to date. Traceback (most recent call last): File "C:Program FilesSmith MicroPoser 11RuntimePythonposerScriptsScriptsMenuDSON SupportTransfer Active Morphs.py", line 2, in dson.dzdsonimporter.generateConformingMorphs() UnicodeDecodeError: 'utf8' codec can't decode byte 0xeb in position 4: unexpected end of data
Poser Pro 11 (always updated to current version available) . Laptop Specs: Intel Core i7-7700 CPU @ 3.60GHz 3.60 GHz :: 16 GB Ram :: Windows 10 Pro
