Virtual World Dynamics F.A.Q (Last Updated: 2024 Dec 10 3:45 pm)
Hello 3doutlaw,
Sorry for these videos in French. I promise you to make the new videos in English even if my accent will be horrible. I think this solution will help more.
If you want to simulate a blanket with a thickness, I think you can generate two meshed planes separated by a small distance. Then you can rigidify these planes as you want and then, you can use a rigidification by neighborhood using a distance that will only link the vertices of the two planes, 2 by 2 with a very low value (0.001 for instance).
The simulation will simulate the 2 planes like one but will keep the distance between the two planes.
Tell me your results, I will make some tests myself.
____________________________________________
Follow me on Twitter : @VWDynamics
Watch demo videos on Youtube
OK, I am new to using this, but I will try to do something like that. The Quilt/Blanket was just to give the idea.
Ideally what I am after is to use dynamics on a hair that has thickness, like these...so they don't flatten out when a simulation is run
http://www.sharecg.com/v/81780/related/11/Poser/bob-Hair-for-STAR%21-POSER#
For me, there is no problem. One of the videos have been made with hair which has a mesh like the one you gave me as link.
I will tell you the name of this hair.
I you want to try, it is necessary to use a rigidification by neighborhood but with high value (low rigidification), perhaps 0.3.
This hair is "Melitte hair". You have to look at the mesh to see its structure.
The video link is : https://www.youtube.com/watch?v=NUOEuCBLC6Y
Is it possible in VWD to animate a thick object? For example, if I modeled a quilt as a blanket that had some thickness to it, can I drape it, without losing the thickness? I think there may be a solution in this video, https://www.youtube.com/watch?v=zggjPFzI6XQ, using the chain, since the chain links must have some thickness, and they do not flatten when the simulation is run...but I can only watch and not understand what he is saying.
Thanks!
