DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
I've not heard of this issue before so I expect it's not a bug with the figure but something going wrong in your workflow for creation of the new morph.
I suspect you are exporting the base figure with Mouth Realism HD and Naval morph on. These two morphs load on a default Genesis 3 Female figure. You can check if the Navel morph is the source of the issue by dialling out that morph when you have your new morph applied and see if the look returns to normal.
Before exporting remember to check the Currently Used section on the parameters tabs it will show all the morphs applied to the loaded figure
Hello inthesky, Razor 42 is right, It is a common mistake with Genesis3 when morphing. Navel, mouth HD are set to 100% on the character. Before exporting your geometry for morph, be sure to set shape to Zero in the parameter tab and check that everything (navel and mouth) are well set to zero, then turn your geometry at subd level 0 in order to get a proper character to morph. If you have a look at your current character, you will certainly notice that when you open the mouth, teeth are not in the correct shape also.... It is not a bug, just that when you apply your morph, DAZ is calculating the geometry, adding navel at 100% + 100% of your morph. It happened many time on my side, so, i knowwhat I'm talking about :-)
Hope it helps,
Best regards,
Hi there I'm haveing an issue with Genesis 3 Female im working on a character to sell. but im haveing problems with G3F belly button. So i've made the morphs in hexagon and sent them to Daz studio via bridge. But each time I add the morphs the belly button on G3F becomes more inverted. I used the standard G3F figure (no morphs) to make my morphs and I haven't made any changes to the navels geometry or used any morphs and its not the skin texture. Can anyone help me
