DAZ|Studio F.A.Q (Last Updated: 2025 Feb 04 3:20 pm)
There are two programs in existence that can do that. DAZ3D does sell one but the name escapes me ATM. There is a freebie that can do that also. However, you need to generate those install files manually first in order to use them with DIM. The freebie I have used and it does work very well for converting typical zips to DIM ready zips. But it is a hassle to attempt conversions of many files, too time-consuming.
With DIM, there are special files that must be in the zip. I don't want to convert the zips to DIM installable zips. I just want to install them.
Ok, so looks like I'll start writing an app that does this. Let's get some requirements. Ability to specify more than one content folder is a must. So for each content folder, you'll create a zip store folder. You dump your zips in the respective folder and run the app and it'll put the files in the proper content folder.
Next, I need a list of folders to look for in the zip that will be copied to the content folder since each zip has a different nesting level (ex Content)
By default, these will be copied (user can configure this): runtime, data, people, presets, shader presets, environments
Ignore folders: documentation
Any unrecognized folders will prompt the user whether to copy to content folder or ignore.
Will need conflict resolution options when overwriting files.
A list of what's been installed and ability to uninstall (and restore any overwritten files). Log file.
I think that should be a good start. If you have ideas or features you want to see, let me know.
hborre posted at 2:13PM Sun, 11 June 2017 - #4307031
https://www.daz3d.com/content-package-assist is the one sold at Daz 3D. It does exactly what it says on the tin, it is quick and painless.
Note it does one, less obvious thing, it adds the product to the DS Smart Content Product list, making creation of smart content for the product much easier.
This is why I still use DS 4.8. I didn't know there was a tool that would put my Poser content into the Smart Content list (Thanks hborre!)
My problem is that when I tried 4.9 it would not let me create new directories my own way which is infuriating. There are always things that don't fit with the "official" system and I need the choice of moving things around for a variety of reasons.
Prof_Null posted at 2:44PM Sun, 18 June 2017 - #4307771
Directories or categories? Content installed "the old way" (via DIM or manually) behaves i the same way as before; content installed Via Connect is tied to its default locations, though you can place shortcuts in other locations (drag-and-drop) outside the Connect virtual folders. Categories, it is suggested you set up your own category tree parallel to the default tree.
bhoins posted at 12:03PM Thu, 22 June 2017 - #4307310
Thanks! I've added that to my Wishlist, and will try it ASAP! I have WAY too much money invested in third party software to simply abandon all of it!
Prof_Null posted at 6:26PM Thu, 22 June 2017 - #4307909
So (RHaseltine) you are saying that it should work just the same as it did in DS 4.8? Note that I don't use Smart Content - only the Content Library where I have everythiing under "Categories". Okay, I will try again installing 4.9 over the weekend and see if it works now.
Yes, with one exception, the database got an update in 4.9 to make it more stable so it will take a moment longer to launch the first time you load up 4.9. (How much longer depends on how much content you have.)
I'd love to see something like that for the Mac.
Merging files manually is slow and if you make one tiny mistake, it wipes out everything with no option to undo. I know from recent experience. I guess I didn't hold down the ALT key long enough and it overwrote Data, People and Runtime.
Now I have to reinstall everything non-Daz store manually and that is going to take forever.
Gods forbid I make another mistake, or I will have to then start all over again.
Howy2012: I use a small app called dittoGUI that will put all your stuff in the right folders - I'm on a Mac too. there is a small fee for it. You still need to load one folder at a time (basically one unzipped downloaded item from Renderosity) but it's a lot better than having to copy ever single item one at a time. I recommend it. Also, I suggest putting all of your content on a seperate drive and (of course) backing up regularly.
Prof_Null posted at 9:23AM Wed, 05 July 2017 - #4308822
Hey Prof! You may have just saved my life! (or, at least many. many hours of it!) Many, many thanks! (and yes, learned my lesson - external drive and a backup!) Thanks again, Howy
Howy2012 posted at 2:19PM Wed, 18 July 2018 - #4308816
Some day I'll write up a full tutorial on this, but for now this tip should be helpful to Mac users:
If you download and extract the zip file on a USB thumb drive or other external drive, you will get the option to "merge folders" (if applicable) when you copy a product's subfolders into the relevant folders in your Poser runtime. That way you don't have to remember to hold down any keys, nor do you have to copy items at the subfolder level.
For example, let's say I just got a new product by Cybertenko (and I already have several of his installed). From the unzipped download file (which is on a thumb drive), I would just choose the Cybertenko folder in Geometries and drag it to the Geometries folder on my internal drive. I'll get the option to "merge," and all new folders and sub-folders will be merged with the existing ones, with nothing deleted. Same with the Textures folder.
My Poser library is so heavily customized/organized that no automatic installer would ever suit my needs, and I also like to know exactly what I'm installing, so I do it manually. But I have a system worked out that makes it fast and fairly painless. The key (at least for Mac users) is to install content from an external drive, not from the same drive that holds your Poser runtime.
TOOLS: MacBook Pro; Poser Pro 11; Cheetah3D; Photoshop CC
FIGURES: S-16 (improved V4 by Karina), M4, K4, Mavka, Toons, and Nursoda's people
GOALS: Stylized and non-photorealistic renders in various fantasy styles
perpetualrevision posted at 8:46AM Thu, 26 July 2018 - #4333363
Thanks for the response! Yep, that is what I have started doing as well. Seems to work well!
As the title says. If not, I might create one (you'll still have to manually download the zips though). But if one already exists, I'd rather do that.
