Sun, Dec 22, 5:29 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Q: use sss for transparency?
colorcurvature ( ) posted Mon, 25 September 2017 at 4:14 AM · edited Sun, 22 December 2024 at 12:51 PM
Is it possible to control transparency with SSS somehow? So the material becomes transparent when it gets very thin? The scatter nodes seem to not be plugable into the transparency nodes
Boni ( ) posted Mon, 25 September 2017 at 6:21 AM
This would be a good test for bagginsbill. If this were to work it would definitely need a math node to calculated at what depth the material becomes transparent.
Boni
seachnasaigh ( ) posted Wed, 27 September 2017 at 1:48 PM
If you're making water, colored glass, fog, translucent plastic, etc., then use a ScatterVolume node. It will inherently be more see-through where the geometry is thinner, and more opaque where the geometry is thicker. No math node tricks needed for this.
seachnasaigh ( ) posted Wed, 27 September 2017 at 2:00 PM
seachnasaigh ( ) posted Wed, 27 September 2017 at 2:52 PM
Oh, and if you're using one of the scatter nodes (there are several) with the PoserSurface root, plug the scatter into the root's Alternate_Diffuse socket, not Transparency.
ironsoul ( ) posted Thu, 28 September 2017 at 2:15 AM
Looking at the question in a slightly different way "is there a way to calculate the distance that a light ray traveled through an object" If using Superfly possibly the following may be of interest using ray length
