Sat, Feb 1, 9:55 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Subject: PhilC: Poser Tool Box crashes Poser new update (11.1)
smallspace ( ) posted Wed, 20 December 2017 at 1:21 PM · edited Sat, 01 February 2025 at 9:53 PM
As soon as I launch the script, Poser crashes and closes.
Kazam561 ( ) posted Wed, 20 December 2017 at 7:41 PM
I don't know if PhilC's updated it but usually he's very good about free updates. I'd contact him through the store, or through his website.
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
Boni ( ) posted Thu, 21 December 2017 at 7:34 AM
You can also contact him through facebook, he posts regularly there.
Boni
NanetteTredoux ( ) posted Thu, 28 December 2017 at 2:01 AM
I am having the same problem with Poser Toolbox and Poser Pocket Knife
Poser 11 Pro, Windows 10
FVerbaas ( ) posted Thu, 28 December 2017 at 9:08 AM
Forum Coordinator
Did it work on Windows10 before? Did you changfe location of Runtimes? I found win10 less sloppy in access rights than win7 and before were. That is a good thing, but old school organisation like writing into a runtime in the program files folder may not work. Poser itself has solved this but of course older plug-ins can still rely on yesterday's innocence. Try to run Poser as administrator. This is not a good permanent solution but it may help you out on occasions.
NanetteTredoux ( ) posted Fri, 29 December 2017 at 1:12 AM · edited Fri, 29 December 2017 at 1:16 AM
Running Poser as administrator does not solve the problem. It worked on Windows 10 before. But obviously, Windows has updated itself several times since then.
raven ( ) posted Fri, 29 December 2017 at 5:20 AM
I don't have Windows 10, I use 7. Poser Tool Box crashes my PoserPro11.1 on my machine too, but is still working in PoserPro11 sr8.
Khai-J-Bach ( ) posted Fri, 29 December 2017 at 3:33 PM · edited Fri, 29 December 2017 at 3:34 PM
More than likely the new poser update has a new python version, meaning that the toolbox will need to be recompiled to work.
(infact 99% certain this is the issue.. We've seen it happen before with poser upgrades and patches....)
FVerbaas ( ) posted Sat, 30 December 2017 at 10:45 AM
Forum Coordinator
Khai-J-Bach posted at 5:36PM Sat, 30 December 2017 - #4321214
More than likely the new poser update has a new python version, meaning that the toolbox will need to be recompiled to work. (infact 99% certain this is the issue.. We've seen it happen before with poser upgrades and patches....)
Unlikely: Poser 11.1 uses Python version 2.7.1 (r271:34759, Dec 13 2017, 03:10:36) [MSC v.1800 64 bit (AMD64)] Poser 11 used 2.7.1 also, but of course earlier build. Changes should not lead to the effects reported.
