Sat, Jan 11, 5:20 AM CST
Subject: Problem importing G3M Clothes in Poser 2014/11
taiuri ( ) posted Tue, 29 May 2018 at 5:31 PM · edited Thu, 09 January 2025 at 4:36 AM
Hi Guys! I have a problem importing G3M Clothes into Poser Pro 2014/11. I followed the procedure I attach (first export it as an obj file in the Geometry Folder from Poser Runtime and after export it as a cr2 file in the Characters Folder from the Poser Library). When I load and conform it, it seems to be correct, but when I try to move the Figure, the cloth stays in the same place and it gets distorted like I show in the pictures attached.
I have to say I don't have this problem when I export G2 Clothes in Poser. These ones are G3M clothes autofitted to a G2M Figure, thanks to the Autofit Plugin. In Daz Studio it's fitted correctly, the problem is in Poser when it's exported.
RobZhena ( ) posted Tue, 29 May 2018 at 6:05 PM
I didn’t think you could export G3 items as cr2’s to Poser because the rigging is different, unless you use Willdial’s utility. G2 cr2’s convert fine I’m Poser.
taiuri ( ) posted Tue, 29 May 2018 at 6:25 PM
In the 2016, I got to do it successfully, the problem is my pc crashed and when I reinstalled all my programs, I have these results. My frustation is knowing before I could get it and now I can't.
RobZhena ( ) posted Tue, 29 May 2018 at 7:16 PM
Do you change the cr2 to point to the obj? I'm pretty sure I tried that without success, but maybe I'm wrong.
taiuri ( ) posted Tue, 29 May 2018 at 7:24 PM
I just followed the same procedure I did before, which it's explained in the screencaps, previously I can do it without problems, but now I have this issue. I've tried everything, but I have the same result. :(
Nails60 ( ) posted Wed, 30 May 2018 at 5:34 AM
I've never tried this on imported genesis 3 clothing but maybe you could just run it through the fitting room. When I have problems with content not conforming properly or moving correctly I just take it into the fitting room (together with the character) don't actually run a fitting session just create a character including regrouping.
RedPhantom ( ) posted Wed, 30 May 2018 at 6:31 AM
Site Admin
Try copy joint zones in poser.
infinity10 ( ) posted Wed, 30 May 2018 at 12:33 PM
I am guessing that the autofit from G3 to G2 is not being correctly translated. Can you import just the OBJ into Poser and see if the shape is G2 ? If not, then I suspect that the autofit magnets or whatever technology DS is using, has not been passed over to the Poser-compatible CR2.
Eternal Hobbyist
jeffnlkpt2 ( ) posted Wed, 30 May 2018 at 1:27 PM
What I do is do an autofit in DAZ and then save the object as a figure asset. I then create a poser companion file with DSON. I have converted a lot of clothes this way and has never had an issue.
taiuri ( ) posted Wed, 30 May 2018 at 3:22 PM
Nails60 posted at 3:22PM Wed, 30 May 2018 - #4330819
I tried, unfortunately it didn't work :(
taiuri ( ) posted Wed, 30 May 2018 at 3:23 PM
RedPhantom posted at 3:23PM Wed, 30 May 2018 - #4330820
Could you explain me how to do that, please?
taiuri ( ) posted Wed, 30 May 2018 at 3:26 PM
infinity10 posted at 3:24PM Wed, 30 May 2018 - #4330869
When I import the cloth, it looks bigger than the figure, but if I conform, it fits correctly, the problem is the traslation like I showed in the pictures attached :(
taiuri ( ) posted Wed, 30 May 2018 at 3:38 PM
jeffnlkpt2 posted at 3:37PM Wed, 30 May 2018 - #4330875
I tried, but it didn't work :(
taiuri ( ) posted Wed, 30 May 2018 at 4:09 PM
RedPhantom posted at 4:09PM Wed, 30 May 2018 - #4330820
I tried it and didn't work either :(
taiuri ( ) posted Wed, 30 May 2018 at 5:27 PM
Any other idea guys?
RedPhantom ( ) posted Wed, 30 May 2018 at 6:34 PM
Site Admin
you might try adjusting the weight maps or inner matspheres (depending on how the figure is rigged) with the joint editor window.
taiuri ( ) posted Wed, 30 May 2018 at 7:03 PM
RedPhantom posted at 7:02PM Wed, 30 May 2018 - #4330891
I tried and neither i worked :( There is something that Daz is not exporting to Poser, but what? what could it be?
taiuri ( ) posted Wed, 30 May 2018 at 7:26 PM
This really strange, if I export directly the G3M Figure and his cloth to Poser, it's not exported complete:
Could you do a favor? If you have Daz Studio, Poser and Genesis 3 Figures and some G3 Clothes, could try to export it to Poser following the method I explained before and tell me your results please? Problably it must be a Plugin or something like that I need for Poser.
I'll be waiting your results. Thank you guys.
infinity10 ( ) posted Wed, 30 May 2018 at 10:49 PM
jeffnlkpt2 posted at 11:47AM Thu, 31 May 2018 - #4330875
Theoretically, this seems the correct methodology. Also, I suspect one issue with all solutions not working is to start with a new scene. poser memory gets very bad when the same scene is used to re-import Daz Studio content either via ObJ and CR2 or by DSON.
Eternal Hobbyist
taiuri ( ) posted Thu, 31 May 2018 at 3:41 PM
infinity10 posted at 3:40PM Thu, 31 May 2018 - #4330894
Could you try by yourself in your pc and let me know if you have this issue too. I have to know if the problem is general or only mine.
taiuri ( ) posted Thu, 31 May 2018 at 7:24 PM
If I create a DSON for the Figure and the Clothes, it worked, but I prefer the Cr2 Exporter method. I don't like to import them through DSON. Could someone here try to export a Genesis 3 Figure to Poser by the Cr2 Exporter Method please? I need to know if the problem is general or only mine.
taiuri ( ) posted Sat, 02 June 2018 at 9:26 PM
So guys? Did you get to export them in Poser using the Cr2 Exporter successfully?
FVerbaas ( ) posted Sun, 03 June 2018 at 2:07 AM
Forum Coordinator
The one thing I have not heard mention in this discussion is Fitting Room. That would be the tool of choice for this operation.
taiuri ( ) posted Sun, 03 June 2018 at 1:44 PM
FVerbaas posted at 1:44PM Sun, 03 June 2018 - #4331029
I tried with the Fitting Room too and it didn't work :(
taiuri ( ) posted Sun, 03 June 2018 at 2:09 PM
A friend told me the problem the clothes get distorted is a bone binding problem and it's necessary to synchronize pants and body bones, but I don't know how to do it Poser. Do you know something about how to do it? Could you explain me guys, please?
FVerbaas ( ) posted Sun, 03 June 2018 at 2:38 PM
Forum Coordinator
taiuri posted at 9:34PM Sun, 03 June 2018 - #4331064
That is odd. Did you use the AutoGroup function?
taiuri ( ) posted Sun, 03 June 2018 at 3:52 PM
FVerbaas posted at 3:52PM Sun, 03 June 2018 - #4331067
Yes, I did :(
taiuri ( ) posted Mon, 04 June 2018 at 1:50 PM
