Sat, Jan 25, 3:31 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
Subject: very white and light
atpo ( ) posted Fri, 07 September 2018 at 8:59 PM ยท edited Sun, 12 January 2025 at 3:22 AM
I assigned material and did uv then import to DAZ ,but obj is very white and light. verywhite.jpg
chrisf ( ) posted Sat, 08 September 2018 at 10:49 AM
What is the Ambient Color?
atpo ( ) posted Sat, 08 September 2018 at 6:34 PM
Thanks. Ambient Color is black.But I think no relation.Because I add material in blender.
atpo ( ) posted Sun, 09 September 2018 at 8:20 PM
I checked that Ambient Color is very white.But for why? I didn't add no ambient in other software. Thanks chrisf .
chrisf ( ) posted Sat, 15 September 2018 at 10:58 AM
I have had the same issue with some props I've imported to Daz Studio even though I set the ambient color to black before importing. I do not know why, I adjust the ambient color in Daz and continue.
atpo ( ) posted Sat, 15 September 2018 at 7:36 PM
Thanks chrisf .
centriq ( ) posted Sun, 16 September 2018 at 5:10 PM
I'm assuming you are using the Nvidia Iray Engine (in render settings)? As your screen shot indicates, the imported object's surface material by default uses the Daz Studio default surface/shader/material. Select the object. Select the Surface. Go to: Content Library > Shader Presets > Iray > DAZ Uber and double click on !Iray Uber Base. Hope that helps.
Oh, and save your eyes ๐Ÿ˜ƒ change your interface color scheme to something more neutral and legible
atpo ( ) posted Sun, 16 September 2018 at 6:25 PM
Thanks.But centriq DAZ4.6 has no Iray,this is in 4.6 version to open.
centriq ( ) posted Sun, 16 September 2018 at 6:35 PM
Ah, thanks for clarifying. Yes, then as Chris suggested.
atpo ( ) posted Tue, 25 September 2018 at 5:31 PM
Thanks.
