Wed, Feb 26, 4:49 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Forum Moderators: Lobo3433 Forum Coordinators: bwsupport
Blender F.A.Q (Last Updated: 2025 Feb 23 7:55 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Import Poser Scene to Blender 2.79 - Alpha Trans and Image
jartz ( ) posted Mon, 28 January 2019 at 2:23 AM · edited Wed, 26 February 2025 at 4:45 PM
I have managed, through trial and error to send some of my Poser figures to Blender 2.79 (I've been enjoying 2.80, btw). Doing transparency is another matter altogether. I wanted to try to send a Poser hair figure to Blender and put its textures w/ transparency. Been rattling my brain on what node I should use: I brought the transparency node, but I can't connect a color or image texture in it. Can someone figure this out?
Thanks,
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Lobo3433 ( ) posted Tue, 29 January 2019 at 9:16 AM
Forum Moderator
Going to give this a shot but still learning nodes myself but from looking at the set as it is currently your texture color should be plugged into the Diffuse BSDF the Alpha channel is fine plugged into the Transparent node in stead of a Mix RGB node ise a Mix shader node plug the diffuse into color 1 transparent into color 2 then the mix shader node into material output again this is suggestion hope it helps
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
jartz ( ) posted Tue, 29 January 2019 at 11:49 AM
Thanks, Lobo3433. I'll check it out.
Lobo3433 ( ) posted Tue, 29 January 2019 at 1:24 PM
Forum Moderator
Hopefully someone else will chime in who has a better grasp of nodes if what I suggested does not work keep us posted
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
MaNae ( ) posted Tue, 29 January 2019 at 11:45 PM
Hey =)
.. just a VERY basic Diffuse-/Transparency-Nodesetup for Cycles: bcbasicdifftrans.jpg
~ it's always darkest before the dawn will show ~
jartz ( ) posted Wed, 30 January 2019 at 3:39 AM
Thanks MaNae. That just might do the trick. And, to Lobo3433, I appreciate that.
jartz ( ) posted Wed, 30 January 2019 at 4:10 AM
Since I couldn't edit my post...
UPDATE: Just as MaNae suggested and it was SUCCESSFUL! I really appreciate it. I'm just learning something every day. Blender is coming along a bit better with every version.
Cheers,
JB
Lobo3433 ( ) posted Wed, 30 January 2019 at 8:44 AM
Forum Moderator
I am glad to hear that MaNae suggestion worked nodes is still something I do not have a full grasp of so thansk for sharing your knowledge MaNae. I know Tony Vilters has some excellent Poser to Blender and back to Poser tutorials you might also find of some interest here is his channel https://www.youtube.com/channel/UCiiFNpMB2ENEiUuctAUObmg
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
MaNae ( ) posted Wed, 30 January 2019 at 10:59 AM
@jartz
btw.. do you know mcj's Teleblender-for-Poser? Combined with 3doutlaws Poser OBJ Export to Cycles script for Poser can it make some export/import-things a lot easier. ^^
Lobo3433 ( ) posted Wed, 30 January 2019 at 8:06 PM
Forum Moderator
`From what I last heard yes it can but there is a bit of fine tuning you have to go thru with the textures also not sure when the scripts were last updated I tried them once myself and following the guide on mcj's site and from outlaw worked well but again some fine tuning was still needed
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
incantrix ( ) posted Sun, 03 February 2019 at 3:51 PM
Another way that I quite often used which depended on the quality of the trans map in poser was to convert it to png and then create an RGBA image in photoshop from it and use the use the alpha channel. I'm not sure why but this always seemed to give me a bit better control.
Incantrix
