Forum Moderators: Lobo3433 Forum Coordinators: bwsupport
Blender F.A.Q (Last Updated: 2025 Feb 23 7:55 pm)
Going to give this a shot but still learning nodes myself but from looking at the set as it is currently your texture color should be plugged into the Diffuse BSDF the Alpha channel is fine plugged into the Transparent node in stead of a Mix RGB node ise a Mix shader node plug the diffuse into color 1 transparent into color 2 then the mix shader node into material output again this is suggestion hope it helps
Lobo3433
Thanks, Lobo3433. I'll check it out.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Hopefully someone else will chime in who has a better grasp of nodes if what I suggested does not work keep us posted
Lobo3433
Thanks MaNae. That just might do the trick. And, to Lobo3433, I appreciate that.
Since I couldn't edit my post...
UPDATE: Just as MaNae suggested and it was SUCCESSFUL! I really appreciate it. I'm just learning something every day. Blender is coming along a bit better with every version.
Cheers,
JB
I am glad to hear that MaNae suggestion worked nodes is still something I do not have a full grasp of so thansk for sharing your knowledge MaNae. I know Tony Vilters has some excellent Poser to Blender and back to Poser tutorials you might also find of some interest here is his channel https://www.youtube.com/channel/UCiiFNpMB2ENEiUuctAUObmg
Lobo3433
@jartz
btw.. do you know mcj's Teleblender-for-Poser? Combined with 3doutlaws Poser OBJ Export to Cycles script for Poser can it make some export/import-things a lot easier. ^^
~ it's always darkest before the dawn will show ~
`From what I last heard yes it can but there is a bit of fine tuning you have to go thru with the textures also not sure when the scripts were last updated I tried them once myself and following the guide on mcj's site and from outlaw worked well but again some fine tuning was still needed
Lobo3433
I have managed, through trial and error to send some of my Poser figures to Blender 2.79 (I've been enjoying 2.80, btw). Doing transparency is another matter altogether. I wanted to try to send a Poser hair figure to Blender and put its textures w/ transparency. Been rattling my brain on what node I should use: I brought the transparency node, but I can't connect a color or image texture in it. Can someone figure this out?
Thanks,
JB
